Cannot install Domoticz on Raspberry pi.....need help
LoKo
Post by LoKo »
I am not able to install Domoticz on my RP3B.
I tried the easy way as mentioned on the website but the installation always stops at the same point.
It has to do with "Checking for libudev-dev." See:
pi@raspberrypi:~ $ curl -L install.domoticz.com | bash
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   194  100   194    0     0   2586      0 --:--:-- --:--:-- --:--:--  2621
100 16565  100 16565    0     0  72973      0 --:--:-- --:--:-- --:--:-- 72973
::: Script called with non-root privileges. The Domoticz installs server packages and configures
::: system networking, it requires elevated rights. Please check the contents of the script for
::: any concerns with this requirement. Please be sure to download this script from a trusted source.
::: Detecting the presence of the sudo utility for continuation of this install...
::: Utility sudo located.
::: You are root.
::: Verifying free disk space...
::: apt-get update has not been run today. Running now... done!
::: Checking apt-get for upgraded packages.... done!
::: Your system is up to date! Continuing with Domoticz installation...
:::    Checking for apt-utils... installed!
:::    Checking for whiptail... installed!
:::    Checking for git... installed!
:::    Checking for curl... installed!
:::    Checking for unzip... installed!
:::    Checking for wget... installed!
:::    Checking for sudo... installed!
:::    Checking for cron... installed!
:::    Checking for libudev-dev...pi@raspberrypi:~ $
As a newbie I don't know what to do now.... :(
Can someone help me out ?
ben53252642
Re: Cannot install Domoticz on Raspberry pi.....need help
Post by ben53252642 »
Try this command to start the installation with root privileges:
sudo curl -L install.domoticz.com | bash
LoKo
Post by LoKo »
Thanks but hat does'nt help...
I get exactly the same result.
CHMvR
Post by CHMvR »
FireWizard
Post by FireWizard »
Last edited by FireWizard on Thursday 07 November 2019 22:43, edited 1 time in total.
LoKo
Post by LoKo »
As a newbie, I do not understand the solutions in the links...
I have some information about my raspian :
pi@raspberrypi:~ $ lsb_release -a
No LSB modules are available.
Distributor ID:	Raspbian
Description:	Raspbian GNU/Linux 10 (buster)
Release:	10
Codename:	buster
I think this is OK.
But the installation stiil stops at the same point... :cry: :cry:
LoKo
Post by LoKo »
I think I have solved the problem. I costed me hours...
I think it all had to do with updates, upgrades, versions etc.
This is the story :
I also had another problem with my raspian desktop environment, so I decided to solve that during waiting for an answer of this forum.
I could not open the tab "Recommended Software" under "Preferences". It always stopped with an error like :
Error updating package data - E: Repository 'https://raspbain.raspberrypi.org/raspbain buster inRease' changed its 'Suite' value from 'testing' to 'stable'
Browsing the internet, I read that more people had this problem and I found the following solution for this:
sudo apt-get update --allow-releaseinfo-change
After this I did again :
sudo apt-get upgrade
This time the upgrade took longer then before and after this the "Recommended Software" tab was opening without the error ! :)
Now I had the feeling that I had a "better" update/upgrade then before (?) and I tried the install of Domoticz again :
curl -L https://install.domoticz.com | bash
And now for the first time the installation passed the point :
It took a little longer time then the other checkings, but the installation went to the end ! :D
So this --allow-releaseinfo-change addition seems very important and solved my problem.
Only a "sudo apt-get update" followed by "sudo apt-get upgrade" is probably not enough !
But as a newbie I don't know exactly what I did and why...
Can someone explain what happened ? Do I have to use this --allow-releaseinfo-change in future during updates or not ?
I assume I am not the only one with this issue, so I hope that this can help other people too.
Answers will be appreciated
dirkjan
Post by dirkjan »
I have exact this problem (RP3B) followed the solution presented, but with me it doesnot work. The installation stops at checking libudev etc. Anybody another solution??
Domoticz version: 2025.1
Did you follow this instruction to prepare your RPi? https://www.domoticz.com/wiki/Initial_R ... y_Pi_Setup
lslamp
Post by lslamp »
yes sir, that I did
I will delete the pi and start from scratch and see if that makes any difference
will update the results here
Lawrence
