Heating multiple Zone
Posted: Sunday 03 November 2019 20:04
Hello everyone,
Cold is coming, and I'm a bit late in my heating system....
To resume the situation
I have X number of eurotronic valve, I can control them with a script to open and close as below. This script is link to a dummy called "heat_demand_X" which this one is triggered by the plugin virtual Thermostat. This work perfectly. https://www.domoticz.com/wiki/Plugins/S ... ostat.html
My problem is to be able to have multiple zone ON and other OFF in same time. I tried blocky but not luck. So I try now the same thing in dzvents.
Hers is the script
At this moment if I switch manually the dummy heat_demand_study for example, the boiler goes ON
, but also the heat_demand_saloon
Why? Because is first in the list...I might miss a separator or something.
I'm sure it is a stupid thing, but checked the forum which help me a lot alreday to get the script for the valve. But how to have a script with condition? So actually the boiler should be off only if all the zone are off. And if let say two zone are ON and one stop it should not send an off command to the boiler.
Please some help
devices = {
'heat_demand_saloon' extra comment this is not in the actual script (The idx is entered in the virtual thermostat)
if (device.active) then
domoticz.devices('Saloon valve mode').updateMode('Manufacturer Specific')
domoticz.devices('Heating Kitchen').switchOn()
domoticz.log('Valve open and Heater under kitchen ON!')
domoticz.devices('Saloon valve mode').updateMode('Off') .afterMin(5)
domoticz.devices('Heating Kitchen').switchOff() .afterMin(5)
domoticz.log('Valve closed and Heater under kitchen OFF!!')
}Hers is the script
devices = {
'heat_demand_saloon',
'heat_demand_study',
'heat_demand_parent',
'heat_demand_lilou',
'heat_demand_djimo',
'heat_demand_hall'
execute = function(domoticz, switch)
if
domoticz.devices('heat_demand_saloon').switchOn().checkFirst()
or
domoticz.devices('heat_demand_study').switchOn().checkFirst()
or
domoticz.devices('heat_demand_parent').switchOn().checkFirst()
or
domoticz.devices('heat_demand_lilou').switchOn().checkFirst()
or
domoticz.devices('heat_demand_djimo').switchOn().checkFirst()
or
domoticz.devices('heat_demand_hall').switchOn().checkFirst()
then
domoticz.devices('Boiler').switchOn().checkFirst()
domoticz.devices('Boiler').switchOff().checkFirst()
}Why? Because is first in the list...I might miss a separator or something.
Please some help
