Debug and Stack trace
Posted: Sunday 03 November 2019 19:07
I have a user who is getting randomly such message and a restart of Domoticz is required.
He is using the latest version of Domoticz, how can we debug that ?
2019-11-03 16:50:35.064 (Zigate) UpdateDevice - ( T° Buanderie) 0:23.8;57.3;1;994.8;4
2019-11-03 16:50:35.134 (Zigate) UpdateDevice - ( T° Buanderie) 0:23.8;55.9;1;994.8;4
2019-11-03 16:50:35.208 Error: Domoticz(pid:12260, tid:12269('PluginMgr')) received fatal signal 4 (Illegal instruction)
2019-11-03 16:50:35.208 Error: siginfo address=0x2fe4, address=0xb6de7fc0
2019-11-03 16:51:00.686 Status: EventSystem: Script event triggered: Time
2019-11-03 16:51:00.922 Error: Thread 4 (Thread 0xb4d56220 (LWP 12269)):
2019-11-03 16:51:00.922 Error: #0 _waitpid (options=0, statloc=0xb4d538b0, pid=17175) at ../sysdeps/unix/sysv/linux/waitpid.c:30
2019-11-03 16:51:00.922 Error: #1 _waitpid (pid=17175, statloc=0xb4d538b0, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
2019-11-03 16:51:00.922 Error: #2 0x00116d0c in dumpstack_gdb(bool) ()
2019-11-03 16:51:00.923 Error: #3 0x00117300 in signal_handler(int, siginfo_t*, void*) ()
2019-11-03 16:51:00.923 Error: #4 <signal handler called>
2019-11-03 16:51:00.923 Error: #5 raise (sig=4) at ../sysdeps/unix/sysv/linux/raise.c:50
2019-11-03 16:51:00.923 Error: #6 <signal handler called>
2019-11-03 16:51:00.923 Error: #7 0x00657000 in ecp_nistz256_precomputed ()
2019-11-03 16:51:00.924 Error: #8 0x00512000 in http::server::CWebsocketHandler::Handle(std::_cxx11::basicstring<char, std::char_traits<char>, std::allocator<char> > const&, bool) ()
2019-11-03 16:51:00.924 Error: #9 0x0050ed5c in http::server::CWebsocketHandler::OnDeviceChanged(unsigned long long) ()
2019-11-03 16:51:00.924 Error: #10 0x0020b1e8 in CWebSocketPush::OnDeviceReceived(int, unsigned long long, std::_cxx11::basicstring<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*) ()
2019-11-03 16:51:00.924 Error: #11 0x000fc394 in boost::signals2::detail::signal_impl<void (int, unsigned long long, std::_cxx11::basicstring<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*), boost::signals2::optional_last_value<void>, int, std::less<int>, boost::function<void (int, unsigned long long, std::_cxx11::basicstring<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*)>, boost::function<void (boost::signals2::connection const&, int, unsigned long long, std::_cxx11::basicstring<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*)>, boost::signals2::mutex>::operator()(int, unsigned long long, std::_cxx11::basicstring<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*) ()
2019-11-03 16:51:00.925 Error: #12 0x00495bf0 in Plugins::CDevice_update(Plugins::CDevice*, object*, object*) ()
2019-11-03 16:51:00.925 Error: #13 0xb602aaf8 in PyMethodDefRawFastCallKeywords () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2019-11-03 16:51:00.925 Error: #14 0xb602ba54 in PyCFunctionFastCallKeywords () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2019-11-03 16:51:00.925 Error: #15 0xb5e2b1d4 in PyEvalEvalFrameDefault () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2019-11-03 16:51:00.925 Error: #16 0xb5f5d298 in PyEvalEvalCodeWithName () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2019-11-03 16:51:00.926 Error: #17 0xb602b0f0 in PyFunctionFastCallKeywords () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2019-11-03 16:51:00.926 Error: #18 0xb5e28f9c in PyEvalEvalFrameDefault () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2019-11-03 16:51:00.926 Error: #19 0xb5f5d298 in PyEvalEvalCodeWithName () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2019-11-03 16:51:00.926 Error: #20 0xb602b0f0 in PyFunctionFastCallKeywords () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2019-11-03 16:51:00.926 Error: #21 0xb5e28f9c in PyEvalEvalFrameDefault () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2019-11-03 16:51:00.927 Error: #22 0xb5e2cdc8 in ?? () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
