I am running Domoticz (latest stable) with a Zwave USB stick and my first Qubino Flush ZMNHCD1.
The device is configured as Blinds Percentage Inverted.
The on and off commands result in (for me) unexpected behaviour.
I'll try to explain:
Note: 0%=Closed, 100%=Opened
Behaviour
State Off -> Select On -> results in fully opening
State On -> Select Off -> results in fully closing
State 50% -> select Off -> results in fully closing
State 50% -> select Off -> Select On -> results in opening to 50% -> select 99% -> results in fulling closing -> domoticz shows Off
State 50% -> Select On -> No reaction whatsoever
State 50% -> Select 99% -> Results in fully opened, Domoticz shows open
So any state % is somehow selected as upper limit ??
Anyone recognized this behaviour?
My current next step is to upgrade to the latest beta and see what happens.
Shutter switch Open / Close not working as expected
georon
- Domoticz version: Bèta
Re: Shutter switch Open / Close not working as expected
Upgrade to beta does not resolve my issue.
Switch logs are not helpful...
ronaldbro
- Domoticz version: 2020.2
I have the same modules and I don't recognize this behaviour. Although I did have some strange behaviour in combination with a Becker motor on my blinds. Had to set max waiting time for power consumption to 30. Sometimes the motor takes a little longer to start moving... Also need to recalibrate sometimes with this motor.
And with Somfy they work perfectly.
