Page 1 of 2
openURL error
Posted: Saturday 02 November 2019 13:56
by Maxx
Since the update to the latest Beta (4.11415 ) I am getting error messages with the openURL call. I made a test script:
		timer = {'every minute'},
	execute = function(dz, triggeredItem)
	        local string = 'http://192.168.1.231:8080//json.htm?type=command&param=udevice&idx=2001&nvalue=0&svalue=12'
	        dz.log(string)
            dz.openURL({
            url = string,
it gives the following error:
2019-11-02 13:54:00.895 Error: Error opening url: http://192.168.1.231:8080//json.htm?type=command&param=udevice&idx=2001&nvalue=0&svalue=12
it worked without problem before the update.
Did something change with the LUA update?
Re: openURL error
Posted: Saturday 02 November 2019 17:57
by waaren
Maxx wrote:Hi,
Can you try again but with only one / before the JSON ?
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
Re: openURL error
Posted: Saturday 02 November 2019 19:08
by Maxx
Same error:
2019-11-02 19:07:00.990 Error: Error opening url: http://192.168.1.231:8080/json.htm?type=command&param=udevice&idx=2001&nvalue=0&svalue=12
Re: openURL error
Posted: Sunday 03 November 2019 0:55
by waaren
Maxx wrote: Saturday 02 November 2019 19:08 Same error:
I checked this url with domoticz 4.11434 (dzVents 2.5.0) and domoticz 4.11454 (dzVents 2.5.0) but do not see any unexpected behavior
What do you see in the log if you execute this test script ?
		httpResponses = { 'testUrl*' },
	execute = function(dz, item)
		if item.isHTTPResponse then
			dz.utils.dumpTable(item)
			dz.log('Domoticz and dzVents version: ' .. dz.settings.domoticzVersion .. ', ' .. dz.settings.dzVentsVersion,dz.LOG_FORCE)
		    urls =
				["testUrl1"] = 'http://192.168.1.231:8080//json.htm?type=command&param=udevice&idx=109&nvalue=0&svalue=12',
				["testUrl2"] = 'http://192.168.1.231:8080/json.htm?type=command&param=udevice&idx=109&nvalue=0&svalue=12',
				["testUrl3"] = dz.settings['Domoticz url'] .. '//json.htm?type=command&param=udevice&idx=109&nvalue=0&svalue=12' ,
				["testUrl4"] = dz.settings['Domoticz url'] .. '/json.htm?type=command&param=udevice&idx=109&nvalue=0&svalue=12' ,
			for callback, url in pairs(urls) do
				dz.openURL({ url = url , callback = callback })
Re: openURL error
Posted: Sunday 03 November 2019 12:52
by Maxx
Here the log
I changed the device in 2001, wich is an existing device (Dummy custom sensor)
Something else, maybe related, I am using a second domoticz server and I use remote server to share variables. This works fine except with dummy devices. They do not appear in the main device list, all the others do.
The URL call in this case is also to a dummy device..
 2019-11-03 12:45:03.103 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-11-03 12:45:03.333 Status: dzVents: Info: Handling httpResponse-events for: "testUrl4"
2019-11-03 12:45:03.333 Status: dzVents: Info: ------ Start internal script: Script #2: HTTPResponse: "testUrl4"
2019-11-03 12:45:03.338 Status: dzVents: > baseType: httpResponse
2019-11-03 12:45:03.338 Status: dzVents: > isVariable: false
2019-11-03 12:45:03.338 Status: dzVents: > ok: true
2019-11-03 12:45:03.338 Status: dzVents: > isJSON: true
2019-11-03 12:45:03.338 Status: dzVents: > isSecurity: false
2019-11-03 12:45:03.338 Status: dzVents: > headers:
2019-11-03 12:45:03.338 Status: dzVents: > Pragma: no-cache
2019-11-03 12:45:03.338 Status: dzVents: > Cache-Control: no-cache
2019-11-03 12:45:03.338 Status: dzVents: > Content-Type: application/json;charset=UTF-8
2019-11-03 12:45:03.338 Status: dzVents: > Content-Length: 53
2019-11-03 12:45:03.338 Status: dzVents: > Access-Control-Allow-Origin: *
2019-11-03 12:45:03.338 Status: dzVents: > _contentType: application/json;charset=UTF-8
2019-11-03 12:45:03.338 Status: dzVents: > isGroup: false
2019-11-03 12:45:03.338 Status: dzVents: > statusText: OK
2019-11-03 12:45:03.338 Status: dzVents: > isHTTPResponse: true
2019-11-03 12:45:03.338 Status: dzVents: > isDevice: false
2019-11-03 12:45:03.338 Status: dzVents: > json:
2019-11-03 12:45:03.338 Status: dzVents: > status: OK
2019-11-03 12:45:03.338 Status: dzVents: > title: Update Device
2019-11-03 12:45:03.338 Status: dzVents: > isScene: false
2019-11-03 12:45:03.338 Status: dzVents: > trigger: testUrl4
2019-11-03 12:45:03.338 Status: dzVents: > callback: testUrl4
2019-11-03 12:45:03.338 Status: dzVents: > data: {
2019-11-03 12:45:03.338 "status" : "OK",
2019-11-03 12:45:03.338 "title" : "Update Device"
2019-11-03 12:45:03.338 }
2019-11-03 12:45:03.338 Status: dzVents: > statusCode: 200
2019-11-03 12:45:03.338 Status: dzVents: > isTimer: false
2019-11-03 12:45:03.338 Status: dzVents: > protocol: HTTP/1.1
2019-11-03 12:45:03.338 Status: dzVents: !Info: Domoticz and dzVents version: 4.11415, 2.4.29
2019-11-03 12:45:03.339 Status: dzVents: Info: ------ Finished Script #2
2019-11-03 12:45:03.340 Status: dzVents: Info: Handling httpResponse-events for: "testUrl2"
2019-11-03 12:45:03.340 Status: dzVents: Info: ------ Start internal script: Script #2: HTTPResponse: "testUrl2"
2019-11-03 12:45:03.340 Status: dzVents: > baseType: httpResponse
2019-11-03 12:45:03.340 Status: dzVents: > isVariable: false
2019-11-03 12:45:03.340 Status: dzVents: > ok: true
2019-11-03 12:45:03.340 Status: dzVents: > isJSON: false
2019-11-03 12:45:03.340 Status: dzVents: > isSecurity: false
2019-11-03 12:45:03.340 Status: dzVents: > headers:
2019-11-03 12:45:03.340 Status: dzVents: > _contentType:
2019-11-03 12:45:03.340 Status: dzVents: > isGroup: false
2019-11-03 12:45:03.340 Status: dzVents: > statusText: OK
2019-11-03 12:45:03.341 Status: dzVents: > isHTTPResponse: true
2019-11-03 12:45:03.341 Status: dzVents: > isDevice: false
2019-11-03 12:45:03.341 Status: dzVents: > isScene: false
2019-11-03 12:45:03.341 Status: dzVents: > trigger: testUrl2
2019-11-03 12:45:03.341 Status: dzVents: > callback: testUrl2
2019-11-03 12:45:03.341 Status: dzVents: > data:
2019-11-03 12:45:03.341 Status: dzVents: > statusCode: 200
2019-11-03 12:45:03.341 Status: dzVents: > isTimer: false
2019-11-03 12:45:03.341 Status: dzVents: > protocol: HTTP/1.1
2019-11-03 12:45:03.341 Status: dzVents: !Info: Domoticz and dzVents version: 4.11415, 2.4.29
2019-11-03 12:45:03.343 Status: dzVents: Info: ------ Finished Script #2
2019-11-03 12:45:03.344 Status: dzVents: Info: Handling httpResponse-events for: "testUrl3"
2019-11-03 12:45:03.344 Status: dzVents: Info: ------ Start internal script: Script #2: HTTPResponse: "testUrl3"
2019-11-03 12:45:03.344 Status: dzVents: > baseType: httpResponse
2019-11-03 12:45:03.344 Status: dzVents: > isVariable: false
2019-11-03 12:45:03.344 Status: dzVents: > ok: true
2019-11-03 12:45:03.344 Status: dzVents: > isJSON: false
2019-11-03 12:45:03.344 Status: dzVents: > isSecurity: false
2019-11-03 12:45:03.344 Status: dzVents: > headers:
2019-11-03 12:45:03.344 Status: dzVents: > _contentType:
2019-11-03 12:45:03.344 Status: dzVents: > isGroup: false
2019-11-03 12:45:03.344 Status: dzVents: > statusText: OK
2019-11-03 12:45:03.345 Status: dzVents: > isHTTPResponse: true
2019-11-03 12:45:03.345 Status: dzVents: > isDevice: false
2019-11-03 12:45:03.345 Status: dzVents: > isScene: false
2019-11-03 12:45:03.345 Status: dzVents: > trigger: testUrl3
2019-11-03 12:45:03.345 Status: dzVents: > callback: testUrl3
2019-11-03 12:45:03.345 Status: dzVents: > data:
2019-11-03 12:45:03.345 Status: dzVents: > statusCode: 200
2019-11-03 12:45:03.345 Status: dzVents: > isTimer: false
2019-11-03 12:45:03.345 Status: dzVents: > protocol: HTTP/1.1
2019-11-03 12:45:03.345 Status: dzVents: !Info: Domoticz and dzVents version: 4.11415, 2.4.29
2019-11-03 12:45:03.346 Status: dzVents: Info: ------ Finished Script #2
2019-11-03 12:45:03.346 Status: dzVents: Info: Handling httpResponse-events for: "testUrl1"
2019-11-03 12:45:03.346 Status: dzVents: Info: ------ Start internal script: Script #2: HTTPResponse: "testUrl1"
2019-11-03 12:45:03.346 Status: dzVents: > baseType: httpResponse
2019-11-03 12:45:03.346 Status: dzVents: > isVariable: false
2019-11-03 12:45:03.347 Status: dzVents: > ok: true
2019-11-03 12:45:03.347 Status: dzVents: > isJSON: false
2019-11-03 12:45:03.347 Status: dzVents: > isSecurity: false
2019-11-03 12:45:03.347 Status: dzVents: > headers:
2019-11-03 12:45:03.347 Status: dzVents: > _contentType:
2019-11-03 12:45:03.347 Status: dzVents: > isGroup: false
2019-11-03 12:45:03.347 Status: dzVents: > statusText: OK
2019-11-03 12:45:03.347 Status: dzVents: > isHTTPResponse: true
2019-11-03 12:45:03.347 Status: dzVents: > isDevice: false
2019-11-03 12:45:03.347 Status: dzVents: > isScene: false
2019-11-03 12:45:03.347 Status: dzVents: > trigger: testUrl1
2019-11-03 12:45:03.347 Status: dzVents: > callback: testUrl1
2019-11-03 12:45:03.347 Status: dzVents: > data:
2019-11-03 12:45:03.347 Status: dzVents: > statusCode: 200
2019-11-03 12:45:03.347 Status: dzVents: > isTimer: false
2019-11-03 12:45:03.347 Status: dzVents: > protocol: HTTP/1.1
2019-11-03 12:45:03.347 Status: dzVents: !Info: Domoticz and dzVents version: 4.11415, 2.4.29
2019-11-03 12:45:03.348 Status: dzVents: Info: ------ Finished Script #2
2019-11-03 12:45:03.225 Error: Error opening url: http://192.168.1.231:8080/json.htm?type=command&param=udevice&idx=5070&nvalue=0&svalue=983.9
2019-11-03 12:45:03.231 Error: Error opening url: http://192.168.1.231:8080/json.htm?type=command&param=udevice&idx=3617&nvalue=0&svalue=132;ZO;35;54;12.8;11.6
2019-11-03 12:45:03.232 Error: Error opening url: http://192.168.1.231:8080/json.htm?type=command&param=udevice&idx=3665&nvalue=0&svalue=0;0.9
2019-11-03 12:45:03.234 Error: Error opening url: http://192.168.1.231:8080/json.htm?type=command&param=udevice&idx=3749&nvalue=0&svalue=210
2019-11-03 12:45:03.236 Error: Error opening url: http://192.168.1.231:8080/json.htm?type=command&param=udevice&idx=3750&nvalue=0&svalue=26300
2019-11-03 12:45:03.238 Error: Error opening url: http://192.168.1.231:8080/json.htm?type=command&param=udevice&idx=3751&nvalue=82&svalue=
Re: openURL error
Posted: Sunday 03 November 2019 13:37
by Maxx
Hi Waaren,
This line works:
["testUrl4"] = dz.settings['Domoticz url'] .. '/json.htm?type=command&param=udevice&idx=2001&nvalue=0&svalue=22'
the others give an error:
 2019-11-03 13:35:01.529 Error: Error opening url: http://127.0.0.1:8080//json.htm?type=command&param=udevice&idx=2001&nvalue=0&svalue=15
2019-11-03 13:35:01.533 Error: Error opening url: http://192.168.1.231:8080/json.htm?type=command&param=udevice&idx=2001&nvalue=0&svalue=14
2019-11-03 13:35:01.554 Error: Error opening url: http://192.168.1.231:8080//json.htm?type=command&param=udevice&idx=2001&nvalue=0&svalue=16
Re: openURL error
Posted: Sunday 03 November 2019 13:48
by waaren
Maxx wrote: Sunday 03 November 2019 12:52 Here the log
I changed the device in 2001, which is an existing device (Dummy custom sensor)
What I see in the log is that the only testURL working is testUrl4. That url is targeted at the local system.
Is http://192.168.1.231 the same system ?
Re: openURL error
Posted: Sunday 03 November 2019 13:59
by Maxx
It is the same system.
I was thinking it may have something to do with authentication so I add the username and password but it still give an error
			["testUrl2"] = 'http://admin:[email protected]:8080/json.htm?type=command&param=udevice&idx=2001&nvalue=0&svalue=14',
error:
 2019-11-03 13:58:00.598 Error: Error opening url: http://127.0.0.1:8080//json.htm?type=command&param=udevice&idx=2001&nvalue=0&svalue=15
2019-11-03 13:58:00.601 Error: Error opening url: http://192.168.1.231:8080//json.htm?type=command&param=udevice&idx=2001&nvalue=0&svalue=16
2019-11-03 13:58:00.603 Error: Error opening url: http://admin:[email protected]:8080/json.htm?type=command&param=udevice&idx=2001&nvalue=0&svalue=14
2019-11-03 13:58:00.811 Error: dzVents: Error: (2.4.29) HTTP/1.1 response: 401 ==>> Unauthorized
Re: openURL error
Posted: Sunday 03 November 2019 14:11
by waaren
Maxx wrote: Sunday 03 November 2019 13:59 It is the same system.
can you try below test script after adding 192.168.1.* to the field [ Local Networks (no username/password):] in [system] [setup] [settings]
so that it look something like: 127.0.0.1;192.168.1.*
			dz.log('Domoticz url: ' .. dz.settings['Domoticz url'],dz.LOG_FORCE)
		    urls =
				-- ["testUrl1"] = 'http://192.168.1.231:8080//json.htm?type=command&param=udevice&idx=109&nvalue=0&svalue=12',
				-- ["testUrl2"] = 'http://192.168.1.231:8080/json.htm?type=command&param=udevice&idx=109&nvalue=0&svalue=12',
				-- ["testUrl3"] = dz.settings['Domoticz url'] .. '//json.htm?type=command&param=udevice&idx=109&nvalue=0&svalue=12' ,
Re: openURL error
Posted: Sunday 03 November 2019 14:21
by Maxx
Spot on, like magic. Works like a charm
What is the story behind this?
Re: openURL error
Posted: Sunday 03 November 2019 14:40
by waaren
Maxx wrote: Sunday 03 November 2019 14:21 Spot on, like magic. Works like a charm
By adding the 192.168.1.* you allow all systems from your home network to access domoticz API without a username / password.
Can only tell what the problem was if I know what was in this field before and what the content of your /etc/hosts is .
Re: openURL error
Posted: Sunday 03 November 2019 15:57
by Maxx
/etc/hosts content:
127.0.0.1	localhost
::1		localhost ip6-localhost ip6-loopback
ff02::1		ip6-allnodes
ff02::2		ip6-allrouters
127.0.1.1	raspberrypi
127.0.0.1 was in the field
Re: openURL error
Posted: Sunday 03 November 2019 17:10
by waaren
Maxx wrote: Sunday 03 November 2019 15:57 127.0.0.1 was in the field
And what was the logline produced by
Re: openURL error
Posted: Sunday 03 November 2019 17:23
by Maxx
2019-11-03 17:22:01.156 Status: dzVents: !Info: Domoticz url: http://127.0.0.1:8080
Re: openURL error
Posted: Sunday 03 November 2019 17:48
by waaren
Maxx wrote: Sunday 03 November 2019 17:23 2019-11-03 17:22:01.156 Status: dzVents: !Info: Domoticz url: http://127.0.0.1:8080
Only things I can think of why it works now and did not do previously is a funny character in the field. 127.0.0.1
or 127.0.1.1 in the /etc/hosts for raspberrypi.
I have this in my /etc/hosts where PI-2 is my 'production' domoticz and PI-6 is test
127.0.0.1       localhost
192.168.192.59          PI-2
192.168.192.109         PI-6
192.168.192.1           R7800
Re: openURL error [Solved]
Posted: Sunday 03 November 2019 18:15
by Maxx
Well, thanks for your time again.
I will have a closer look at the host file options, it looks interesting since I have a production and a test domoticz too
Re: openURL error
Posted: Friday 10 April 2020 17:56
by cjb75
I have a similar problem as mentioned in https://www.domoticz.com/forum/viewtopi ... 59&t=24453, my script is below:
if (item.isHTTPResponse and item.ok) then
             if (item.trigger == 'unifi_loggedin') then
                 dz.openURL({
                     url = controllerUrl .. 'api/s/defaultd/stat/sta',
                     method = 'GET',
                     callback = 'unifi_data'
2020-04-10 17:53:01.691 Status: dzVents: > ok: true
2020-04-10 17:53:01.691 Status: dzVents: > isScene: false
2020-04-10 17:53:01.691 Status: dzVents: > isHTTPResponse: true
2020-04-10 17:53:01.691 Status: dzVents: > statusText: OK
2020-04-10 17:53:01.691 Status: dzVents: > data: {"meta":{"rc":"ok"},"data":[]}
2020-04-10 17:53:01.691 Status: dzVents: > isHardware: false
2020-04-10 17:53:01.691 Status: dzVents: > isSystem: false
2020-04-10 17:53:01.691 Status: dzVents: > isDevice: false
2020-04-10 17:53:01.691 Status: dzVents: > protocol: HTTP/1.1
2020-04-10 17:53:01.691 Status: dzVents: > isJSON: true
2020-04-10 17:53:01.691 Status: dzVents: > json:
2020-04-10 17:53:01.691 Status: dzVents: > meta:
2020-04-10 17:53:01.691 Status: dzVents: > rc: ok
2020-04-10 17:53:01.691 Status: dzVents: > trigger: unifi_loggedin
2020-04-10 17:53:01.691 Status: dzVents: > baseType: httpResponse
2020-04-10 17:53:01.691 Status: dzVents: > isGroup: false
2020-04-10 17:53:01.691 Status: dzVents: > isCustomEvent: false
2020-04-10 17:53:01.691 Status: dzVents: > isSecurity: false
2020-04-10 17:53:01.691 Status: dzVents: > statusCode: 200
2020-04-10 17:53:01.691 Status: dzVents: > isXML: false
2020-04-10 17:53:01.691 Status: dzVents: > isVariable: false
2020-04-10 17:53:01.691 Status: dzVents: > isTimer: false
2020-04-10 17:53:01.691 Status: dzVents: > callback: unifi_loggedin
2020-04-10 17:53:01.691 Status: dzVents: > _contentType: application/json;charset=UTF-8
2020-04-10 17:53:01.691 Status: dzVents: > headers:
2020-04-10 17:53:01.691 Status: dzVents: > Set-Cookie: csrf_token=YLCVpUUrdJMNvLaX0mgpM3Hj7xlHETHj; Path=/; Secure
2020-04-10 17:53:01.691 Status: dzVents: > Date: Fri, 10 Apr 2020 15:53:01 GMT
2020-04-10 17:53:01.691 Status: dzVents: > Content-Type: application/json;charset=UTF-8
2020-04-10 17:53:01.691 Status: dzVents: > Access-Control-Expose-Headers: Access-Control-Allow-Origin,Access-Control-Allow-Credentials
2020-04-10 17:53:01.691 Status: dzVents: > Content-Length: 30
2020-04-10 17:53:01.691 Status: dzVents: > Access-Control-Allow-Credentials: true
2020-04-10 17:53:01.691 Status: dzVents: > vary: Origin
2020-04-10 17:53:01.691 Status: dzVents: > X-Frame-Options: DENY
2020-04-10 17:53:01.691 Status: dzVents: !Info: Domoticz and dzVents version: 2020.1, 3.0.1
2020-04-10 17:53:01.691 Status: dzVents: !Info: Domoticz url: http://127.0.0.1:8080
2020-04-10 17:53:02.315 Error: Error opening url: https://192.168.0.2:8443/api/s/default/stat/sta
2020-04-10 17:53:02.518 Error: dzVents: Error: (3.0.1) HTTP/1.1 response: 401 ==>> No reason returned!
My /etc/hosts file:
127.0.0.1       localhost
Any help would be really appreciated!
Re: openURL error
Posted: Friday 10 April 2020 18:57
by waaren
cjb75 wrote: Friday 10 April 2020 17:56
looks like you are not authorized.
What do you see when sending the same using curl ?
Re: openURL error
Posted: Friday 10 April 2020 19:23
by cjb75
I think I'm authorized since
and
seems to be true.
See code below:
if (item.isTimer or item.isDevice) then
             dz.openURL({
                 url = controllerUrl .. 'api/login',
                 method = 'POST',
                 postData = {
                     ['password'] = controllerPassword,
                     ['username'] = controllerLogin
                 callback = 'unifi_loggedin'
                 dz.log('Domoticz and dzVents version: ' .. dz.settings.domoticzVersion .. ', ' .. dz.        settings.dzVentsVersion,dz.LOG_FORCE)
                 dz.openURL({
                     url = controllerUrl .. 'api/s/default/stat/sta',
                     method = 'GET',
I'm not sure how to use curl but using the command:
curl --cookie /tmp/unifi_cookie --cookie-jar /tmp/unifi_cookie --insecure -X POST -d '{"password":"mypassword","username":"domoticz"}' https://192.168.0.2:8443/api/login
followed by:
curl --cookie /tmp/unifi_cookie --cookie-jar /tmp/unifi_cookie --insecure --data "json={}" https://192.168.0.2:8443/api/s/default/stat/sta
works for me
Re: openURL error
Posted: Friday 10 April 2020 20:44
by waaren
cjb75 wrote: Friday 10 April 2020 19:23 I think I'm authorized since
and
seems to be true.
You are authorized to send the first one but the error you see is the return of the seconds openURL. I never managed to send something to a URL where a cookie is required from domoticz using dz.openURL
Probably the quickest way to success here is to use os.execute(cmd) with the curl as cmd.
