Howto compare the current energy consumption with the consumption yesterday at the same time
Posted: Saturday 02 November 2019 12:18
by steef27
I am looking for a possibility to compare the current energy consumption with the consumption yesterday at the same time.
I want to be able to determine whether the cumulated consumption is higher or lower than yesterday at the same time.
For now I have found scripts that calculate averages over 24 hours, but that is not what I am looking for.
Does anyone have an idea? Thanks in advance!
Re: Howto compare the current energy consumption with the consumption yesterday at the same time
Posted: Sunday 03 November 2019 10:52
by waaren
steef27 wrote: Saturday 02 November 2019 12:18
You could try withthe script below. It use the persistent historical data features of dzVents.
When not yet familiar with dzVents please start with reading
Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents disabled' is not checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
this dzVents script collects the current energy return / usage to enable compararisment with yestedays figures
return
on = { timer = { 'every 5 minutes ' }},
logging = { level = domoticz.LOG_DEBUG },
data = { power = { history = true, maxHours = 25, maxItems = 1000 }},
execute = function(dz, item)
_G.logMarker = _G.moduleLabel
local smartMeter = dz.devices('Power') -- change to name of your smartMeter
local counterDeliveredToday = smartMeter.counterDeliveredToday
local counterToday = smartMeter.counterToday
dz.log('counterDeliveredToday: ' .. counterDeliveredToday .. ': kwh',dz.LOG_DEBUG)
dz.log('counterToday: ' .. counterToday,dz.LOG_DEBUG)
dz.data.power.add -- Store current values in persistent historical data
['delivered'] = counterDeliveredToday,
['used'] = counterToday
local power, index = dz.data.power.getAtTime('24:00:00')
if not(power) then
dz.log('Not enough data collected yet. Taking oldest data to compare with',dz.LOG_FORCE)
power, index = dz.data.power.getOldest()
dz.log('delivery dailytotal at ' .. power.time.rawDateTime .. ': ' ..
power.data.delivered ..': kwh . ==> Delta (' .. dz.utils.round(( power.data.delivered - counterDeliveredToday ),4) .. ' kwh)',dz.LOG_DEBUG)
dz.log('usage dailytotal at ' .. power.time.rawDateTime .. ': ' ..
power.data.used ..': kwh . ==> Delta (' .. dz.utils.round(( power.data.used - counterToday ),4) .. ' kwh)',dz.LOG_FORCE)
Posted: Monday 04 November 2019 9:51
by steef27
I get an error:
2019-11-04 09:40:02.179 Status: dzVents: !Info: Not enough data collected yet. Taking oldest data to compare with
2019-11-04 09:40:02.180 Status: dzVents: Error (2.4.19): An error occured when calling event handler Log
2019-11-04 09:40:02.180 Status: dzVents: Error (2.4.19): /home/pi/domoticz/scripts/dzVents/generated_scripts/Log.lua:38: attempt to concatenate field 'rawDateTime' (a nil value)
Posted: Monday 04 November 2019 9:59
by waaren
steef27 wrote: Monday 04 November 2019 9:51
I get an error:
That is because rawDateTime is not available yet in 2.4.19. So use below script in which I used a combination of rawDate and rawTime or update to a recent Beta.
this dzVents script collects the current energy return / usage to enable comparing with yesterdays figures
return
on = { timer = { 'every 5 minutes' }},
if not(power) then
dz.log('delivery dailytotal at ' .. power.time.rawDate .. ' ' power.time.rawTime .. ': ' ..
power.data.delivered ..': kwh . ==> Delta (' .. dz.utils.round(( power.data.delivered - counterDeliveredToday ),4) .. ' kwh)',dz.LOG_FORCE)
dz.log('usage dailytotal at ' .. power.time.rawDate .. ' ' power.time.rawTime .. ': ' ..
Posted: Monday 04 November 2019 17:04
by steef27
Thanks! Works great.
Can I also add my Gasmeter in this script? Or do I need to create another script?
Re: Howto compare the current energy consumption with the consumption yesterday at the same time [Solved]
Posted: Monday 04 November 2019 18:04
by waaren
steef27 wrote: Monday 04 November 2019 17:04
Yes, not a problem but best to save this script with another name or remove datafile of current script.
Datafile to be found at <domoticz dir>/scripts/dzVents/data/__data_<scriptName>.lua
this dzVents script collects the current energy return / usage and gas usage to enable comparing with yesterdays figures
return
data = { energy = { history = true, maxHours = 25, maxItems = 1000 }},
local gas = dz.devices('Gas') -- change to name of your gasMeter
local gasToday = gas.counterToday
dz.log('Gas usage today: ' .. gasToday,dz.LOG_DEBUG)
dz.data.energy.add -- Store current values in persistent historical data
['used'] = counterToday,
['gas'] = gasToday,
local energy, index = dz.data.energy.getAtTime('24:00:00')
if not(energy) then
energy, index = dz.data.energy.getOldest()
dz.log('delivery dailytotal at ' .. energy.time.rawDate .. ' ' .. energy.time.rawTime .. ': ' ..
energy.data.delivered ..': kwh . ==> Delta (' .. dz.utils.round(( energy.data.delivered - counterDeliveredToday ),4) .. ' kwh)',dz.LOG_FORCE)
dz.log('usage dailytotal at ' .. energy.time.rawDate .. ' ' .. energy.time.rawTime .. ': ' ..
energy.data.used ..': kwh . ==> Delta (' .. dz.utils.round(( energy.data.used - counterToday ),4) .. ' kwh)',dz.LOG_FORCE)
dz.log('daily gas-usage at ' .. energy.time.rawDate .. ' ' .. energy.time.rawTime .. ': ' ..
energy.data.gas ..': m3 . ==> Delta (' .. dz.utils.round(( energy.data.gas - gasToday ),4) .. ' m3)',dz.LOG_FORCE)
