Can anyone advise regarding compiling errors?
Posted: Wednesday 30 October 2019 19:49
Hello everyone,,
Because of some issues (well basically it doesn't work) with the prebuilt beta releases and some python plugins I want to use, I thought I'd have a go at compiling from source as some users have suggested. Unfortunately I've run into some problems and I'm hoping someone here will be able to point me in the right direction.So I've carefully followed the steps outlined in the wiki article but the final stage isn't completing. I have two Pi's, a production model 2, which I'd rather not mess about with, and a Pi 1 model B. I've made a clean Raspbian Stretch SD card (8 Gig), run the updates etc. and thats all stable. One one occasion the compile just errors out (no error massage just a crash), other times the Raspbian install just locks up completely requiring a hard restart, always at about the 20-25% mark.Last night,mobdro lucky patcher kodi I tried it again and left it overnight, when I reattached to the screen session I saw
So presumably it's a memory error.
In the wiki it mentions that you may need to use an older version of GCC and G++ because of memory, if I simply follow the wiki it seems to install GCC 6.3 so I thought if I uninstall GCC and G++
sudo apt-get remove GCC G++
and then auto remove and try installing 4.6
sudo apt-get install GCC-4.6 G++-4.6
then this seems to work but the cmake command errors out with 'can't find a compiler' message, so do I need to tell it explicitly to use 4.6 (presumably in usr/bin somewhere) or am I missing something completely obvious?
And last question, on a Pi B should I just use 'make' or add extra parameters to the command, and would the same apply if I were to run it on a Pi 2?
Many thanks in advance for any help and suggestions.
JimK.
cc1plus: out of memory allocating 4067280 bytes after a total of 43425792 bytes
CMakeFiles/domoticz.dir/build.make:470: recipe for target 'CMakeFiles/domoticz.dir/main/SQLHelper.cpp.o' failed
make[2]: *** [CMakeFiles/domoticz.dir/main/SQLHelper.cpp.o] Error 1
CMakeFiles/Makefile2:71: recipe for target 'CMakeFiles/domoticz.dir/all' failed
make[1]: *** [CMakeFiles/domoticz.dir/all] Error 2
Makefile:149: recipe for target 'all' failed
make: *** [all] Error 2In the wiki it mentions that you may need to use an older version of GCC and G++ because of memory, if I simply follow the wiki it seems to install GCC 6.3 so I thought if I uninstall GCC and G++
JimK.
