script to supress notifications for period of time
Posted: Wednesday 30 October 2019 10:33
by snuiter
anyone has suggestions how to add a piece of code to my dzVents scripts to surpress notifications for a period of time. Trigger should be adjustable either receiving 5(x) notifications within 10 minutes(y), once this occured stop the notifications for 2 hours(z).
Reason behind this that I use a number of scripts for monitoring, scripts can be either triggered via device or timer, there are occassions the monitoring scripts keeps sending notifications and after a few notifications it becomes annoying.
Any suggestion is welcome.
Thank you
Re: script to supress notifications for period of time
Posted: Wednesday 30 October 2019 11:52
by BOverdevest
Maybe using some fuzzy logic?
Use a variable and add 1 to it for every notification send.
Use this variable as a condition to send the notification. So if the value is 10 or higher, do not Sent notification.
In a separate script, every 2 hours, reduce the variable by one.
Make a separate push button to reset the variable to 0. (Can push it from your phone).
The 10 mentioned above you could set in a separate variable or in a counter device, so you can tweak it easier and use the same across all scripts.
Even the period of removing 1 from the variable you could manage via a variable.
So, when the load is high you get 10 messages and then 1 (random) every 2 hours.
Push the reset button when things calm down or you sorted the problem
Tweak the parameters to get the behavior you want.
Hope this helps....
Posted: Wednesday 30 October 2019 22:01
by papoo
a 100% functional waaren script for this
https://www.domoticz.com/forum/viewtopi ... 42#p204958
