How to swipe between screens on a Windows 10 touchscreen ?
Posted: Monday 28 October 2019 20:02
by Masure
Hi Dashticz community,
I'm giving a try at Dashticz and I love the simplicity and possibilities. I designed a 2 screens dashboard. When I'm testing it on my desktop, I "drag and drop" to switch between screens, fine.
I tested the same on my Teclast TBook T11 tablet running on Windows 10. No matter which web browser I use, Chrome, Firefox, Edge, swiping does not switch between screens.
I understand swiping on a touchscreen is simulating window scrolling and this could be the root cause why it does not swipe cause it requires a drag and drop.
I did not find anything at the OS level to change the touchscreen swipe behaviour.
Does anybody use a Windows 10 touchscreen and can provide some solution or workaround ?
Can dashticz react to "scroll event" to make the switch between screens possible ?
Re: How to swipe between screens on a Windows 10 touchscreen ?
Posted: Monday 28 October 2019 20:31
by jaaap
I had the same problem and solved it by enlarging the navigation buttons on the bottom, so I can click them easily and they take me to the next screen
Posted: Monday 28 October 2019 20:37
by Masure
I shouldn't have mentioned workaround as accepted in my request
Thanks for the suggestion though I'm looking for a working swipe
Posted: Monday 28 October 2019 21:01
by jaaap
Masure wrote: Monday 28 October 2019 20:37
Haha, to be honest: I would rather like a real solution as well. Following your topic!
Posted: Monday 28 October 2019 21:19
by Lokonli
jaaap wrote: Monday 28 October 2019 21:01
I don't have a win10 touch device. My Android tablet is working fine.
I expect the touch/mobile device detection doesn't work reliably. Dashticz uses a very old library for this.
Could you do some testing:
In the file js/main.js, line 478, (latest master and beta) you read:
if (md.mobile() == null || md.tablet() !== null) {
Can you change this into:
If this doesn't work then I guess we have to update the swiper component.
Posted: Monday 28 October 2019 21:59
by Masure
I just tried.
=> Gives the same result.
To see what is changing, I also tried
=> It puts the 2 screens visible with a scrollbar.
Posted: Tuesday 29 October 2019 22:25
by Masure
The latest swiper (4.5.1) fixes swiping on windows 10 tablet. I just made a drop in replacement of vendor\swiper folder.
The issue was referenced on the swiper github :
https://github.com/kidjp85/react-id-swiper/issues/230
However the navigation buttons are lost.
Posted: Saturday 09 November 2019 14:24
by Lokonli
Should be solved in the latest beta v3.2.0
Can you confirm?
Posted: Monday 11 November 2019 23:16
by jaaap
Lokonli wrote: Saturday 09 November 2019 14:24
Can you confirm?
Confirmed! Works perfect on my W10 tablet. Thanks!
