checkFirst() with uservariable
Posted: Monday 28 October 2019 14:24
by dpcreel
I've been checkFirst() with a uservariable for a long time. Just noticed a lag and traced it back to error on line 45 and 91 of the script below.
(2019-10-28 08:16:00.511 Error: dzVents: Error: (2.4.29) ...icz/scripts/dzVents/generated_scripts/Garage Door V2.lua:91: attempt to call field 'checkFirst' (a nil value)
2019-10-28 08:17:30.026 Error: dzVents: Error: (2.4.29) An error occurred when calling event handler Garage Door V2
2019-10-28 08:17:30.026 Error: dzVents: Error: (2.4.29) ...icz/scripts/dzVents/generated_scripts/Garage Door V2.lua:45: attempt to call field 'checkFirst' (a nil value).
This script has been running for several years without an issue. In one section of the dzvents documentation it says it's OK to use with uservariables (2.3.0), in another it says its only for switch-like-devices (checkFirst(): Function. Checks if the current state of the device is different than the desired new state. If the target state is the same, no command is sent. If you do mySwitch.switchOn().checkFirst(), then no switch command is sent if the switch is already on. This command only works with switch-like devices. It is not available for toggle and dim commands, either.).
What am I missing? Thanks is advance.
The uservariable is an integer, I'm running the latest beta version on a pi3 B+ using a usb drive instead of an SD card (seems more reliable).
local function getMinutes(dTime)
    local raw = dTime.rawTime
    local a = {}
    local i = 0
    for v in string.gmatch(raw, "%d+") do
        a[i] = tonumber(v)
        i = i + 1
    local min = a[1] + a[0] * 60
    return min
local function canLights(dTime)
    local min = getMinutes(dTime)
    return (min >= dTime.sunsetInMinutes - 60 or min <= dTime.sunriseInMinutes + 60)
    --return true       --timing disabled for debugging purposes, when done comment out and uncomment out the above line to enable timing.
local function activateGarageLights(data,delay)
    data.devices('Garage Lights').cancelQueuedCommands()
    data.devices('Garage Lights').switchOn().checkFirst().silent()
    data.devices('Garage Lights').switchOff().silent().afterMin(delay)
		devices = {'Garage Door State','Garage Motion','Lights Group','Garage Lights'},
		timer = {'every minute'}
	execute = function(domoticz,item,triggerInfo)
        local tempDiff = 1.0       --Maximum satisfactory garage temperature differential (F)
        local lightDelay = 5        --Garage Light turn off delay
        if item.isDevice then    --Device change scripts go here
            domoticz.log('Script triggered on device change',domoticz.LOG_INFO)
            if item.name == 'Garage Door State' then
                --Turn on/keep on the garage lights if the door is Opening.
                if (item.text == 'Opening' and canLights(domoticz.time)) then
                    activateGarageLights(domoticz,lightDelay)
                    domoticz.log('Garage door opened, switching on the garage lights',domoticz.LOG_INFO)
                --Set close = 0 after the door is closed or someone may have closed the door manually.
                if item.text == 'Closed' then
                  domoticz.variables('autoCloseStatus').set(0).checkFirst().silent()
                   domoticz.devices('Door Auto-Close').switchOff().checkFirst().silent()
            elseif item.name == 'Lights Group' and item.active then
                --Turn on the Lights Group - pressing the number II buton on the garage door remote.
                if (getMinutes(domoticz.time) >= domoticz.time.sunsetInMinutes - 60 or getMinutes(domoticz.time) <= domoticz.time.sunriseInMinutes + 60) then --allow script to run if it is between a certian time.
                    domoticz.groups('Lights Group Group').switchOn().checkFirst().forMinutes(20) --had added .silent() but there was an issue with another script.
                    domoticz.log('Lights Group Group activated for 20 minutes.',domoticz.LOG_INFO)
            elseif item.name == 'Garage Motion' then
                if item.active then
                    --Abort the auto-close function is there is motion.
                    domoticz.devices('Door Auto-Close').cancelQueuedCommands()
                    --if motion is detected and is dark emough, turn on/keep on the garage lights for 5 min.
                    if canLights(domoticz.time) then
                        domoticz.log('Motion detected, switching on the garage lights',domoticz.LOG_INFO)
                elseif not item.active then
                    --Turn off lights if no motion detected after a while, after a delay
                    domoticz.devices('Garage Lights').cancelQueuedCommands()
                    domoticz.devices('Garage Lights').switchOff().checkFirst().silent().afterMin(lightDelay)
                    domoticz.log('No motion detected, turning garage lights off after ' .. lightDelay .. ' minutes', domoticz.LOG_INFO)
            elseif item.name == 'Garage Lights' and item.active then
                --set timer if light switch is manually activated
                domoticz.log('Manual activation of garage lights detected, switching off in ' .. lightDelay .. ' minutes if there is no motion',domoticz.LOG_INFO)
                --send an email an set a log event if the garage door auot close function has been on too long
                domoticz.log('<<<<<<<<<<<<<<<<<<<<<<<< No device events triggered! >>>>>>>>>>>>>>>>>>>>>>>>>>>>>',domoticz.LOG_INFO)
        elseif item.isTimer then    --Timed scripts go here
            --domoticz.log('Script triggered on timer',domoticz.LOG_INFO)
            --Check if we need to auto-close the garage door, based of house-garage temperature differential
            if (math.abs(domoticz.devices('Garage Temperature').temperature - domoticz.devices('House TempHum').temperature)) > tempDiff
                and (not domoticz.devices('Garage Motion').active)
                and (not (domoticz.devices('Garage Door State').text == 'Closing' or domoticz.devices('Garage Door State').text == 'Closed'))
                and domoticz.variables('autoCloseStatus').value == 0 then
                    local wait = domoticz.time.isDayTime and 30 or 15 --this is not wrong, it's LUA's ternary operation (A ? B : C) 25 or 10
                    domoticz.devices('Door Auto-Close').switchOn().checkFirst().silent().afterMin(wait)
                    domoticz.log('Garage door Auto-Close set for ' .. wait .. ' minutes from now',domoticz.LOG_INFO)
                    domoticz.variables('autoCloseStatus').set(1).checkFirst().silent() --this variable is also set in the BT Occupancy event.
            elseif (domoticz.devices('Door Auto-Close').lastUpdate.minutesAgo > 3) and domoticz.devices('Door Auto-Close').active then
                domoticz.log('Auto-Close timed error event',domoticz.LOG_INFO)
                domoticz.log('Garage Door Auto Close Error, Sending Email...',domoticz.LOG_ERROR)
                domoticz.email('Garage Door Auto Close Error!','Please check the garage door, it has tried to auto close too long unsuccessfully.','[email protected]')
Re: checkFirst() with uservariable
Posted: Monday 28 October 2019 16:47
by waaren
dpcreel wrote: Monday 28 October 2019 14:24 I've been checkFirst() with a uservariable for a long time.
I am not aware that checkFirst() was ever available in dzVents for uservariables. Domoticz does not provide the necessary underlying Lua commands. Having said that it quite simple to code a Lua snippet that emulates it.
if myVar.value  ~= newValue then myVar.set(newValue) end
and add .silent() or .afterXXX() methods to the set(newValue) when required. (NOT both as silent() does not work in combination with afterXXX() for uservariables
On a side note; is there a specific reason why you place your functions outside the execute = section ? By doing so you force dzVents to interpret all these functions every minute and on every device change. For performance it is best to place these functions inside the execute = section.
Posted: Monday 28 October 2019 20:08
by dpcreel
Waaren,
Check the dzvents documentation, everything is there. Section 2.3.0 it says: "Added more options to the various commands/methods: e.g. myDevice.switchOff().silent(), .forSec(), .forHour(), .afterHour(), .repeatAfterSec(), .repeatAfterMin(), .repeatAfterHour(), .withinHour() and .checkFirst(). This now works not only for devices but also scenes, groups and user variables. See documentation about command options."
I thought that only functions inside the execute= were interpreted based on the on =. I was just wanted to call on them as needed so that's why I did it that way. Please correct me if I'm mistaken. Myself and my son wrote this several years ago so I'm a little foggy on exactly why we did it that way.
I'm a hack at coding, I try my best but usually need help.
Re: checkFirst() with uservariable  [Solved]
Posted: Thursday 31 October 2019 0:49
by waaren
dpcreel wrote: Monday 28 October 2019 20:08 Check the dzvents documentation, everything is there. Section 2.3.0 it says: "Added more options to the various commands/methods: e.g. myDevice.switchOff().silent(), .forSec(), .forHour(), .afterHour(), .repeatAfterSec(), .repeatAfterMin(), .repeatAfterHour(), .withinHour() and .checkFirst(). This now works not only for devices but also scenes, groups and user variables. See documentation about command options."
Sorry if it is not clear for you.
e.g. is a Latin abbreviations. It stands for exempli gratia and means “for example.” In this text it is not meant in a sense that all options worked for all devices , scenes groups and user variables. In the documentation it is explained what works where.
checkFirst() never worked in dzVents for uservariables.
That is not how it works. You can try it yourself by add a
print('hey I am executed (again)....')
before the initial
line in one of your scripts and look what you see in the log
Posted: Thursday 31 October 2019 3:32
by dpcreel
Thanks for the clarification.
One question - if checkFirst() never work for uservariables then why has this script been running fine with no errors for several years? That's all I wanted to know from the beginning. Sorry for any problems caused, I just wanted an answer to my question. Thanks for your time and expertise.
If anyone else has any thoughts please let me know.
Posted: Thursday 31 October 2019 9:28
by waaren
dpcreel wrote: Thursday 31 October 2019 3:32 One question - if checkFirst() never work for uservariables then why has this script been running fine with no errors for several years? That's all I wanted to know from the beginning.
Sorry. I cannot answer that one conclusive because I do not have a pre dzVents 2.4 installation to test on but I do know that dzVents pré 2.4 used quite different techniques. So it could be that the checkFirst() was simply ignored on the versions where you did not saw this error.
