Changing remote
Posted: Sunday 27 October 2019 19:14
by jkimmel
Some time ago with the help of dannybloe I created this script
local masterSlave = {
['zza FB 11 Stehlampen Salon'] = 'FB 11 Stehlampen Salon',
['zza FB 12 Downlight Kamin'] = 'FB 12 Downlight Kamin',
['zza FB 13 Downlight Terrasse'] = 'FB 13 Downlight Terrasse',
['zza FB 14 Lampe Esstisch'] = 'FB 14 Lampe Esstisch',
['zza FB 21 Heizkreis Salon'] = 'FB 21 Heizkreis Salon',
['zza FB 23 Heizkreis Buero'] = 'FB 23 Heizkreis Buero',
['zza FB 31 Infrarot'] = 'FB 31 Infrarot',
['zza FB 32 Heizkreis Schlafzimmer'] = 'FB 32 Heizkreis Schlafzimmer',
['zza FB 33 Waermepumpe'] = 'FB 33 Waermepumpe',
['zza FB 41 Heizkreis Gaestebad'] = 'FB 41 Heizkreis Gaestebad',
['zza FB 42 Heizkreis Bad'] = 'FB 42 Heizkreis Bad',
['zza FB 43 Downlight Tresen'] = 'FB 43 Downlight Tresen',
['zza FB 44 Stehlampe Buero'] = 'FB 44 Stehlampe Buero'
active = true,
'zza FB *' -- you use prefix method here so no need to list them all individually, use the wildcard.
execute = function(domoticz, masterSwitch)
-- get the slave device using the lookup table above
-- but do some checking first to catch misstakes
if (masterSlave[masterSwitch.name] == nil) then
-- oops
domoticz.log(masterSwitch.name .. ' cannot be found in the lookup table. Check the names.', domoticz.LOG_ERROR)
-- now get the slave device and check if it exists
local slaveSwitch = domoticz.devices[masterSlave[masterSwitch.name]]
if (slaveSwitch == nil) then
-- oops again
domoticz.log('There is no slave device by the name ' .. masterSlave[masterSwitch.name] .. '. Check the names', domoticz.LOG_ERROR)
-- we're good to go.. we have a slave device
if (masterSwitch.state == 'On') then
slaveSwitch.switchOn()
slaveSwitch.switchOff()
Unfortunetly it isn't working anymore
The slave is not switching.
Re: Changing remote
Posted: Monday 28 October 2019 0:49
by waaren
jkimmel wrote: Sunday 27 October 2019 19:14
Unfortunetly it isn't working anymore. The slave is not switching.
You must have been using quite an old version... The usage of square brackets for domoticz.devices is no longer usable from dzVents 2.0
Please try again after changing the line
to
local slaveSwitch = domoticz.devices(masterSlave[masterSwitch.name])
Please include some text what is expected and what goes wrong when you report a problem including any relevant loglines next time. That will make it easier to help you.
Re: Changing remote
Posted: Tuesday 29 October 2019 16:36
by jkimmel
first thank you for your help.
The reason of this script:
My Remote was broke so the new remote - switching zza * switches - had to be arranged to replace the old one.
So p. e. zza FB 21 should switch FB 21
Even with the change you suggested the master switch is not switching yet.
Re: Changing remote
Posted: Tuesday 29 October 2019 19:39
by waaren
jkimmel wrote: Tuesday 29 October 2019 16:36
Can you try this one ?
And if still not working then please include some text what goes wrong and include any relevant loglines. That will make it easier to help you.
return
on = { devices = { 'zza FB*' }},
logging = { level = domoticz.LOG_DEBUG },
_G.logMarker = _G.moduleLabel -- Set marker to scriptname
local masterSlave =
['zza FB 44 Stehlampe Buero'] = 'FB 44 Stehlampe Buero',
if masterSlave[masterSwitch.name] == nil then
-- oops
return
if slaveSwitch == nil then
-- oops again
return
Re: Changing remote
Posted: Wednesday 30 October 2019 14:37
by jkimmel
Wow, it's working now.
Tx
Re: Changing remote
Posted: Thursday 07 November 2019 12:44
by jkimmel
Sorry, it's not working in one aspect which I didn't test earlier.
when pushing the remote button assigned to "zza FB 12" the script runs endless without any pause.
I have to disable DzVents and enable again to stop this.
I can't see any difference to other switches which are working.
Re: Changing remote
Posted: Thursday 07 November 2019 13:25
by waaren
jkimmel wrote: Thursday 07 November 2019 12:44
Sounds like the slave device somehow triggers the master device. Could be a number of things
- another script
- something defined in the on- or off Action area of the slave device
- something defined in the sub/slave area of the slave device
I added a dump() statement to below script to get some information on the slave device and add the option silent() to the switch commands. The option silent() does prevent any subsequent (script) events to be triggered.
Please try with this onw and collect all relevant loglines. The dump() command produce > 100 lines so to capture all you will have to log to an OS file or start domoticz from the CLI with
return
local masterSlave =
-- oops
return
-- oops again
return
if masterSwitch.name = 'zza FB 12 Downlight Kamin' then
slaveSwitch.dump()
slaveSwitch.switchOn().silent()
slaveSwitch.switchOff().silent()
Re: Changing remote [Solved] [Solved]
Posted: Thursday 14 November 2019 11:21
by jkimmel
Thank you.
Your hints already solved it.
it was about the slave area.
