Item.state problem
Posted: Sunday 27 October 2019 18:57
by Hydci
Hello, I come to you for help I have a script that works perfectly but I have a problem with item.state I have two devices that can turn on to turn off
The devices are 'Jardin' and 'vacances scolaires'
I tried to do this but it does not work item.state('jardin') == 'Off'
Here is my code if you want to take a look
        on =
            timer     = { '25 minutes after sunset','15 minutes after sunset','at 7:45 on mon,tue,thu,fri','at 9:30 on wed,sat,sun','at 9:30 on mon,tue,thu,fri'},
            devices = {'Jardin','Bouton volet','vacances scolaires'},
    execute = function( dz, item)
        Cuisine = dz.devices('Volet cuisine')  -- racourci des devices
        Salon = dz.devices('Volet salon')
        if dz.time.matchesRule('15 minutes after sunset') then
        os.execute("sudo /home/pi/./alexa.sh -d Cuisine -e speak:'Fermeture des volets dans dix minutes'")
        if item.state == "1 Click" and dz.devices('Volet cuisine').state == 'Closed' and dz.devices('Volet salon').state == 'Closed' then
            Cuisine.switchOn().silent()
            Salon.switchOn().silent()
	    elseif item.state == "1 Click" and dz.devices('Volet cuisine').state == 'Open' and dz.devices('Volet salon').state == 'Open' then
	        Cuisine.switchOff().silent()
            Salon.switchOff().silent()
	    if item.state == "2 Clicks" and dz.devices('Volet cuisine').state == 'Closed' then
	    elseif item.state == "2 Clicks" and dz.devices('Volet cuisine').state == 'Open' then
	    if item.state == "3 Clicks" and dz.devices('Volet salon').state == 'Closed' then
	    elseif item.state == "3 Clicks" and dz.devices('Volet salon').state == 'Open' then
        if item.isDevice and item.state == 'Off' and dz.time.matchesRule('at nighttime') then  -- ferme les volets si le jardin pass en off
        if dz.devices('Volet cuisine').state == 'Open' then
        if dz.devices('Volet salon').state == 'Open' then
		if dz.time.matchesRule('25 minutes after sunset') and dz.devices('Jardin').state == 'Off' then --coucher du soleil protection lumière on attend le off pour fermer les volets
		if dz.time.matchesRule('at 7:45 on mon,tue,thu,fri') and dz.devices('vacances scolaires').state == 'Off' then -- lever du soleil
        if dz.devices('Volet cuisine').state == 'Closed' then
        if dz.devices('Volet salon').state == 'Closed' then
        if dz.time.matchesRule('at 9:30 on mon,tue,thu,fri') and dz.devices('vacances scolaires').state == 'On' then -- lever du soleil
		if dz.time.matchesRule('at 9:30 on wed,sat,sun') then -- lever du soleil
Re: Item.state problem
Posted: Monday 28 October 2019 1:39
by waaren
Hydci wrote: Sunday 27 October 2019 18:57 Hello, I come to you for help I have a script that works perfectly but I have a problem with item.state I have two devices that can turn on to turn off
Sorry but I don't understand what you mean and what does not work as intended.
I added some log statements so you can see what happens when the script executes and grouped the various parts.
If you cannot find why it is not working as designed the please explain in detail what you want and include the relevant loglines.
return
    on =
    logging =
        level = domoticz.LOG_DEBUG,
        _G.logMarker = _G.moduleLabel -- Set marker to scriptname
        Jardin = dz.devices('Jardin')
        Vacances = dz.devices('vacances scolaires')
        dz.log('State of Cuisine: ' .. Cuisine.state,dz.LOG_DEBUG)
        dz.log('State of Salon: ' .. Salon.state,dz.LOG_DEBUG)
        dz.log('State of Jardin: ' .. Jardin.state,dz.LOG_DEBUG)
        dz.log('State of Vacances: ' .. Vacances.state,dz.LOG_DEBUG)
        if item.isTimer then
            dz.log('Time trigger is: ' .. item.trigger,dz.LOG_DEBUG )
            elseif dz.time.matchesRule('25 minutes after sunset') and Jardin.state == 'Off' then --coucher du soleil protection lumière on attend le off pour fermer les volets
                if Cuisine.state == 'Open' then
                if Salon.state == 'Open' then
            elseif dz.time.matchesRule('at 9:30 on wed,sat,sun') then -- lever du soleil
                if Cuisine.state == 'Closed' then
                if Salon.state == 'Closed' then
            elseif dz.time.matchesRule('at 7:45 on mon,tue,thu,fri') and Vacances.state == 'Off' then -- lever du soleil
            elseif dz.time.matchesRule('at 9:30 on mon,tue,thu,fri') and Vacances.state == 'On' then -- lever du soleil
       elseif item.isDevice then
            dz.log(item.name .. ' ; state is ' .. item.state,dz.LOG_DEBUG)
            if item.state == "1 Click" and Cuisine.state == 'Closed' and Salon.state == 'Closed' then
            elseif item.state == "1 Click" and Cuisine.state == 'Open' and Salon.state == 'Open' then
            elseif item.state == "2 Clicks" and Cuisine.state == 'Closed' then
            elseif item.state == "2 Clicks" and Cuisine.state == 'Open' then
            elseif item.state == "3 Clicks" and Salon.state == 'Closed' then
            elseif item.state == "3 Clicks" and Salon.state == 'Open' then
            elseif item.state == 'Off' and dz.time.matchesRule('at nighttime') then  -- ferme les volets si le jardin pass en off
Posted: Monday 28 October 2019 7:09
by Hydci
Hello Waaren,
Thank you for your answer and for your optimization of my script.
My problem is at the code level, I have two devices 'Jardin' and 'vacances scolaire' who can go from that can switch on to turn off what triggers this code I would only like this code to be operated only by the garden device
I try this but it does not work item.state('Jardin')
          elseif item.state('Jardin') == 'Off' and dz.time.matchesRule('at nighttime') then  -- ferme les volets si le jardin pass en off
Posted: Monday 28 October 2019 8:11
by Hydci
I think I found a beginning answer is it corect if I write it like that? I'm not sure that parentheses is useful
if (item.isDevice and item.name == 'Jardin' and item.state == 'Off') and dz.time.matchesRule('at nighttime') then
Posted: Monday 28 October 2019 8:22
by waaren
Hydci wrote: Monday 28 October 2019 8:11 I think I found a beginning answer is it corect if I write it like that? I'm not sure that parentheses is useful
It's not incorrect but why not using ?
elseif Jardin.state == 'Off' and dz.time.matchesRule('at nighttime') then
compete code
return
    on =
    logging =
            elseif Jardin.state == 'Off' and dz.time.matchesRule('at nighttime') then  -- ferme les volets si le jardin pass en off
Posted: Monday 28 October 2019 9:17
by Hydci
I had not thought of this solution small question it will remain an actuator ie if the light goes out the code will be executed?
Re: Item.state problem  [Solved]
Posted: Monday 28 October 2019 10:56
by waaren
Hydci wrote: Monday 28 October 2019 9:17 I had not thought of this solution small question it will remain an actuator ie if the light goes out the code will be executed?
Yes, the script will be executed on every update to the devices mentioned in the devices = section and at the times mentioned in the timer = section
Posted: Monday 28 October 2019 11:44
by Hydci
I have one last question here in this code that the state of the light activates the code
And it checks the state it's not an actuator
so device.state little serve for both at once? or to check the condition I have to use something else?
Posted: Monday 28 October 2019 14:11
by waaren
Hydci wrote: Monday 28 October 2019 11:44
In this code this if statement only evaluates to true if the scriptTigger was a device and when the state of device Jardin is ' Off'' and the time is between sunset and sunrise.
In this code this if statement will only evaluate to true if the scriptTrigger was a timer and the time is 9:30 and it is monday, tuesday, thursday or friday and the state of device vacances scolaires is ' Off''.
I don't understand this question
The construct of the script and the nature of the 2nd level if / elseif rules is that only one of the if / elseif are true at the same time.
Hope this will answer your question. If not please clarify and include loglines. To point out what you intended and what dd not work as expected.
