pipiche wrote: Thursday 22 October 2020 16:57
valideo wrote: Thursday 22 October 2020 16:55
Just set up my second PiZigate and portal is not launching. Already did on another PiZigate few months ago with domoticz on a raspberry4.
Here I'm using a Raspberry pi 3+.
I did the full set up and the interface is not launching (it may launch on 9440 but the port is even not open.
https://ibb.co/sRH2CXG
Any idea ?
Thanks !
a minimum of log please !
Here are the logs when I start domoticz :
2020-10-22 16:44:26.366 Sunrise: 14:06:00 SunSet: 01:18:00
2020-10-22 16:44:26.366 Day length: 11:12:00 Sun at south: 07:42:00
2020-10-22 16:44:26.366 Civil twilight start: 13:42:00 Civil twilight end: 01:43:00
2020-10-22 16:44:26.366 Nautical twilight start: 13:13:00 Nautical twilight end: 02:11:00
2020-10-22 16:44:26.366 Astronomical twilight start: 12:45:00 Astronomical twilight end: 02:39:00
2020-10-22 16:44:26.128 Status: Domoticz V2020.2 (build 12496) (c)2012-2020 GizMoCuz
2020-10-22 16:44:26.128 Status: Build Hash: f18fc9720-modified, Date: 2020-10-21 12:12:39
2020-10-22 16:44:26.128 Status: Startup Path: /home/valideo/domoticz/
2020-10-22 16:44:27.326 Active notification Subsystems: http (1/13)
2020-10-22 16:44:27.396 Starting shared server on: :::6144
2020-10-22 16:44:27.321 Status: PluginSystem: Started, Python version '3.7.3'.
2020-10-22 16:44:27.346 Status: WebServer(HTTP) started on address: :: with port 8080
2020-10-22 16:44:27.393 Status: WebServer(SSL) started on address: :: with port 443
2020-10-22 16:44:27.396 Status: TCPServer: shared server started...
2020-10-22 16:44:27.397 Status: RxQueue: queue worker started...
2020-10-22 16:44:29.397 Status: (Zigate) Started.
2020-10-22 16:44:29.397 Status: NotificationSystem: thread started...
2020-10-22 16:44:29.398 Status: EventSystem: reset all events...
2020-10-22 16:44:29.406 Status: EventSystem: reset all device statuses...
2020-10-22 16:44:29.449 Status: PluginSystem: Entering work loop.
2020-10-22 16:44:29.502 Status: Python EventSystem: Initalizing event module.
2020-10-22 16:44:29.502 Status: EventSystem: Queue thread started...
2020-10-22 16:44:29.502 Status: EventSystem: Started
2020-10-22 16:44:30.438 (Zigate) Debug Mode: -1, We do recommend to leave Verbors to None
2020-10-22 16:44:30.438 (Zigate) 'HardwareID':'2'
2020-10-22 16:44:30.438 (Zigate) 'HomeFolder':'/home/valideo/domoticz/plugins/Domoticz-Zigate/'
2020-10-22 16:44:30.438 (Zigate) 'StartupFolder':'/home/valideo/domoticz/'
2020-10-22 16:44:30.438 (Zigate) 'UserDataFolder':'/home/valideo/domoticz/'
2020-10-22 16:44:30.438 (Zigate) 'Database':'/home/valideo/domoticz/domoticz.db'
2020-10-22 16:44:30.438 (Zigate) 'Language':'fr'
2020-10-22 16:44:30.438 (Zigate) 'Version':'4.11'
2020-10-22 16:44:30.438 (Zigate) 'Author':'zaraki673 pipiche38'
2020-10-22 16:44:30.438 (Zigate) 'Name':'Zigate'
2020-10-22 16:44:30.438 (Zigate) 'Address':'0.0.0.0'
2020-10-22 16:44:30.438 (Zigate) 'Port':'9999'
2020-10-22 16:44:30.438 (Zigate) 'SerialPort':'/dev/serial0'
2020-10-22 16:44:30.438 (Zigate) 'Key':'Zigate'
2020-10-22 16:44:30.438 (Zigate) 'Mode1':'PI'
2020-10-22 16:44:30.438 (Zigate) 'Mode3':'True'
2020-10-22 16:44:30.438 (Zigate) 'Mode4':'9440'
2020-10-22 16:44:30.438 (Zigate) 'Mode6':'-1'
2020-10-22 16:44:30.438 (Zigate) 'DomoticzVersion':'2020.2 (build 12496)'
2020-10-22 16:44:30.438 (Zigate) 'DomoticzHash':'f18fc9720-modified'
2020-10-22 16:44:30.438 (Zigate) 'DomoticzBuildTime':'2020-10-21 12:12:39'
2020-10-22 16:44:30.438 (Zigate) Device count: 2
2020-10-22 16:44:30.438 (Zigate) Device: 1 - ID: 1, Name: 'Zigate - Zigate Status 2', nValue: 4, sValue: 'No Communication'
2020-10-22 16:44:30.438 (Zigate) Device ID: '1'
2020-10-22 16:44:30.438 (Zigate) Device Name: 'Zigate - Zigate Status 2'
2020-10-22 16:44:30.438 (Zigate) Device nValue: 4
2020-10-22 16:44:30.438 (Zigate) Device sValue: 'No Communication'
2020-10-22 16:44:30.438 (Zigate) Device LastLevel: 0
2020-10-22 16:44:30.438 (Zigate) Device Options: {}
2020-10-22 16:44:30.439 (Zigate) Device: 2 - ID: 2, Name: 'Zigate - Zigate Notifications 2', nValue: 0, sValue: ''
2020-10-22 16:44:30.439 (Zigate) Device ID: '2'
2020-10-22 16:44:30.439 (Zigate) Device Name: 'Zigate - Zigate Notifications 2'
2020-10-22 16:44:30.439 (Zigate) Device nValue: 0
2020-10-22 16:44:30.439 (Zigate) Device sValue: ''
2020-10-22 16:44:30.439 (Zigate) Device LastLevel: 0
2020-10-22 16:44:30.439 (Zigate) Device Options: {}
2020-10-22 16:44:30.439 (Zigate) DomoticzVersion: 2020.2 (build 12496)
2020-10-22 16:44:30.994 (Zigate) runmode_with_gpiocommand
2020-10-22 16:44:30.994 (Zigate) + Checkint GPIO PINs
2020-10-22 16:44:30.413 Status: (Zigate) Entering work loop.
2020-10-22 16:44:30.420 Status: (Zigate) Initialized version 4.11, author 'zaraki673 pipiche38'
2020-10-22 16:44:30.438 Status: (Zigate) Zigate plugin stable-4.11.007 started
2020-10-22 16:44:30.438 Status: (Zigate) Debug: -1
2020-10-22 16:44:30.439 Status: (Zigate) load PluginConf
2020-10-22 16:44:30.449 Status: (Zigate) enableWebServer set to 1
2020-10-22 16:44:30.450 Status: (Zigate) filename set to /home/valideo/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-02.json
2020-10-22 16:44:30.450 Status: (Zigate) pluginHome set to /home/valideo/domoticz/plugins/Domoticz-Zigate/
2020-10-22 16:44:30.450 Status: (Zigate) homedirectory set to /home/valideo/domoticz/plugins/Domoticz-Zigate/
2020-10-22 16:44:30.450 Status: (Zigate) pluginData set to /home/valideo/domoticz/plugins/Domoticz-Zigate/Data/
2020-10-22 16:44:30.450 Status: (Zigate) pluginConfig set to /home/valideo/domoticz/plugins/Domoticz-Zigate/Conf/
2020-10-22 16:44:30.450 Status: (Zigate) pluginOTAFirmware set to /home/valideo/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2020-10-22 16:44:30.450 Status: (Zigate) pluginReports set to /home/valideo/domoticz/plugins/Domoticz-Zigate/Reports/
2020-10-22 16:44:30.450 Status: (Zigate) pluginWWW set to /home/valideo/domoticz/plugins/Domoticz-Zigate/www/
2020-10-22 16:44:30.450 Status: (Zigate) pluginLogs set to /home/valideo/domoticz/plugins/Domoticz-Zigate/Logs/
2020-10-22 16:44:30.450 Status: (Zigate) Switching Heartbeat to 5 s interval
2020-10-22 16:44:30.450 Status: (Zigate) Python Version - 3.7.3 (default, Jul 25 2020, 13:03:44)
2020-10-22 16:44:30.450 [GCC 8.3.0]
2020-10-22 16:44:30.450 Status: (Zigate) DomoticzVersion: 2020.2 (build 12496)
2020-10-22 16:44:30.450 Status: (Zigate) DomoticzHash: f18fc9720-modified
2020-10-22 16:44:30.450 Status: (Zigate) DomoticzBuildTime: 2020-10-21 12:12:39
2020-10-22 16:44:30.450 Status: (Zigate) Opening DomoticzDB in raw
2020-10-22 16:44:30.460 Status: (Zigate) Plugin Database: DeviceList-2.txt
2020-10-22 16:44:30.471 Status: (Zigate) DeviceConf loaded
2020-10-22 16:44:30.876 Status: (Zigate) load ListOfDevice
2020-10-22 16:44:30.907 Status: (Zigate) Entries loaded from /home/valideo/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-2.txt
2020-10-22 16:44:30.907 Status: (Zigate) Transport mode: PI
2020-10-22 16:44:30.988 Status: (Zigate) Python version: ['3.7.3 (default, Jul 25 2020, 13:03:44) ', '[GCC 8.3.0]'] dist: ('debian', '10.6', '') linux_distribution: ('debian', '10.6', '') system: Linux machine: armv7l platform: Linux-5.4.51-v7+-armv7l-with-debian-10.6 uname: uname_result(system='Linux', node='raspberrypi', release='5.4.51-v7+', version='#1333 SMP Mon Aug 10 16:45:19 BST 2020', machine='armv7l', processor='') version: #1333 SMP Mon Aug 10 16:45:19 BST 2020 mac_ver: ('', ('', '', ''), '')
2020-10-22 16:44:31.102 (Zigate) + Checkint GPIO PINs
2020-10-22 16:44:31.127 Status: (Zigate) ==> Transport Mode: auto
2020-10-22 16:44:31.132 Status: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/serial0
2020-10-22 16:44:31.132 Status: (Zigate) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/serial0', Port: '', Baud: 115200, Connected: False, Parent: 'None'
2020-10-22 16:46:20.809 (Zigate) Debug Mode: -1, We do recommend to leave Verbors to None
2020-10-22 16:46:20.809 (Zigate) 'HardwareID':'2'
2020-10-22 16:46:20.809 (Zigate) 'HomeFolder':'/home/valideo/domoticz/plugins/Domoticz-Zigate/'
2020-10-22 16:46:20.809 (Zigate) 'StartupFolder':'/home/valideo/domoticz/'
2020-10-22 16:46:20.809 (Zigate) 'UserDataFolder':'/home/valideo/domoticz/'
2020-10-22 16:46:20.809 (Zigate) 'Database':'/home/valideo/domoticz/domoticz.db'
2020-10-22 16:46:20.809 (Zigate) 'Language':'fr'
2020-10-22 16:46:20.809 (Zigate) 'Version':'4.11'
2020-10-22 16:46:20.809 (Zigate) 'Author':'zaraki673 pipiche38'
2020-10-22 16:46:20.809 (Zigate) 'Name':'Zigate'
2020-10-22 16:46:20.809 (Zigate) 'Address':'0.0.0.0'
2020-10-22 16:46:20.809 (Zigate) 'Port':'9999'
2020-10-22 16:46:20.809 (Zigate) 'SerialPort':'/dev/serial0'
2020-10-22 16:46:20.809 (Zigate) 'Key':'Zigate'
2020-10-22 16:46:20.809 (Zigate) 'Mode1':'PI'
2020-10-22 16:46:20.809 (Zigate) 'Mode3':'False'
2020-10-22 16:46:20.809 (Zigate) 'Mode4':'9440'
2020-10-22 16:46:20.809 (Zigate) 'Mode6':'-1'
2020-10-22 16:46:20.809 (Zigate) 'DomoticzVersion':'2020.2 (build 12496)'
2020-10-22 16:46:20.809 (Zigate) 'DomoticzHash':'f18fc9720-modified'
2020-10-22 16:46:20.809 (Zigate) 'DomoticzBuildTime':'2020-10-21 12:12:39'
2020-10-22 16:46:20.809 (Zigate) Device count: 2
2020-10-22 16:46:20.809 (Zigate) Device: 1 - ID: 1, Name: 'Zigate - Zigate Status 2', nValue: 4, sValue: 'No Communication'
2020-10-22 16:46:20.809 (Zigate) Device ID: '1'
2020-10-22 16:46:20.809 (Zigate) Device Name: 'Zigate - Zigate Status 2'
2020-10-22 16:46:20.809 (Zigate) Device nValue: 4
2020-10-22 16:46:20.809 (Zigate) Device sValue: 'No Communication'
2020-10-22 16:46:20.809 (Zigate) Device LastLevel: 0
2020-10-22 16:46:20.809 (Zigate) Device Options: {}
2020-10-22 16:46:20.809 (Zigate) Device: 2 - ID: 2, Name: 'Zigate - Zigate Notifications 2', nValue: 0, sValue: ''
2020-10-22 16:46:20.809 (Zigate) Device ID: '2'
2020-10-22 16:46:20.809 (Zigate) Device Name: 'Zigate - Zigate Notifications 2'
2020-10-22 16:46:20.809 (Zigate) Device nValue: 0
2020-10-22 16:46:20.809 (Zigate) Device sValue: ''
2020-10-22 16:46:20.809 (Zigate) DomoticzVersion: 2020.2 (build 12496)
2020-10-22 16:46:20.914 (Zigate) runmode_with_gpiocommand
2020-10-22 16:46:20.914 (Zigate) + Checkint GPIO PINs
2020-10-22 16:46:20.197 Status: (Zigate) Stop directive received.
2020-10-22 16:46:20.198 Status: (Zigate) Exiting work loop.
2020-10-22 16:46:20.244 Status: (Zigate) onStop called
2020-10-22 16:46:20.244 Status: (Zigate) Connection close: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/serial0', Port: '', Baud: 115200, Connected: False, Parent: 'None'
2020-10-22 16:46:20.398 Status: (Zigate) Stopping threads.
2020-10-22 16:46:20.398 Status: (Zigate) Stopped.
2020-10-22 16:46:20.398 Status: (Zigate) Started.
2020-10-22 16:46:20.805 Status: (Zigate) Entering work loop.
2020-10-22 16:46:20.806 Status: (Zigate) Initialized version 4.11, author 'zaraki673 pipiche38'
2020-10-22 16:46:20.808 Status: (Zigate) Zigate plugin stable-4.11.007 started
2020-10-22 16:46:20.809 Status: (Zigate) Debug: -1
2020-10-22 16:46:20.810 Status: (Zigate) load PluginConf
2020-10-22 16:46:20.811 Status: (Zigate) enableWebServer set to 1
2020-10-22 16:46:20.811 Status: (Zigate) filename set to /home/valideo/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-02.json
2020-10-22 16:46:20.811 Status: (Zigate) pluginHome set to /home/valideo/domoticz/plugins/Domoticz-Zigate/
2020-10-22 16:46:20.812 Status: (Zigate) homedirectory set to /home/valideo/domoticz/plugins/Domoticz-Zigate/
2020-10-22 16:46:20.812 Status: (Zigate) pluginData set to /home/valideo/domoticz/plugins/Domoticz-Zigate/Data/
2020-10-22 16:46:20.812 Status: (Zigate) pluginConfig set to /home/valideo/domoticz/plugins/Domoticz-Zigate/Conf/
2020-10-22 16:46:20.812 Status: (Zigate) pluginOTAFirmware set to /home/valideo/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2020-10-22 16:46:20.812 Status: (Zigate) pluginReports set to /home/valideo/domoticz/plugins/Domoticz-Zigate/Reports/
2020-10-22 16:46:20.812 Status: (Zigate) pluginWWW set to /home/valideo/domoticz/plugins/Domoticz-Zigate/www/
2020-10-22 16:46:20.812 Status: (Zigate) pluginLogs set to /home/valideo/domoticz/plugins/Domoticz-Zigate/Logs/
2020-10-22 16:46:20.812 Status: (Zigate) Switching Heartbeat to 5 s interval
2020-10-22 16:46:20.812 Status: (Zigate) Python Version - 3.7.3 (default, Jul 25 2020, 13:03:44)
2020-10-22 16:46:20.812 [GCC 8.3.0]
2020-10-22 16:46:20.812 Status: (Zigate) DomoticzVersion: 2020.2 (build 12496)
2020-10-22 16:46:20.812 Status: (Zigate) DomoticzHash: f18fc9720-modified
2020-10-22 16:46:20.812 Status: (Zigate) DomoticzBuildTime: 2020-10-21 12:12:39
2020-10-22 16:46:20.812 Status: (Zigate) Opening DomoticzDB in raw
2020-10-22 16:46:20.819 Status: (Zigate) Plugin Database: DeviceList-2.txt
2020-10-22 16:46:20.826 Status: (Zigate) DeviceConf loaded
2020-10-22 16:46:20.881 Status: (Zigate) load ListOfDevice
2020-10-22 16:46:20.892 Status: (Zigate) Entries loaded from /home/valideo/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-2.txt
2020-10-22 16:46:20.893 Status: (Zigate) Transport mode: PI
2020-10-22 16:46:20.911 Status: (Zigate) Python version: ['3.7.3 (default, Jul 25 2020, 13:03:44) ', '[GCC 8.3.0]'] dist: ('debian', '10.6', '') linux_distribution: ('debian', '10.6', '') system: Linux machine: armv7l platform: Linux-5.4.51-v7+-armv7l-with-debian-10.6 uname: uname_result(system='Linux', node='raspberrypi', release='5.4.51-v7+', version='#1333 SMP Mon Aug 10 16:45:19 BST 2020', machine='armv7l', processor='') version: #1333 SMP Mon Aug 10 16:45:19 BST 2020 mac_ver: ('', ('', '', ''), '')
2020-10-22 16:46:20.244 Error: CConnection_disconnect, disconnection request from 'Zigate' ignored. Transport does not exist.
2020-10-22 16:46:21.004 (Zigate) + Checkint GPIO PINs
2020-10-22 16:46:21.031 Status: (Zigate) ==> Transport Mode: auto
2020-10-22 16:46:21.037 Status: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/serial0
2020-10-22 16:46:21.037 Status: (Zigate) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/serial0', Port: '', Baud: 115200, Connected: False, Parent: 'None'
Here's my config of the plugin :
https://ibb.co/HP1nh0p
I followed the following steps :
1 :
https://zigate.fr/documentation/compati ... et-zero-w/
2 :
https://zigate.fr/documentation/parametrer-la-pizigate/
3 :
https://github.com/pipiche38/Domoticz-Z ... llation.md
4:
https://github.com/pipiche38/Domoticz-Z ... uration.md
And also added this but not fixing the issue :
https://github.com/pipiche38/Domoticz-Z ... terface.md
