Which features require PHP ? Topic is solved
Masure
Post by Masure »
I'd like to test Dashticz. I read in the documentation that PHP i needed
Main reason is that for most functionality PHP support in the web server is needed... That means that Dashticz needs to be installed under a different web server with PHP enabled
But can Dashticz still run without PHP ? Which functionality are lost ?
I only need to show my Domoticz devices in different pages. No need for customs blocks. Is that possible ?
Best regards
Lokonli
Re: Which features require PHP ?
Post by Lokonli »
Masure wrote: Thursday 24 October 2019 14:02 Hi,
Best regards
yes
Lokonli
Post by Lokonli »
Lokonli wrote: Thursday 24 October 2019 17:13
Best regards
yes
Functionality that is lost without PHP:
* calendar
* garbage
* savings settings from Dashticz
* version check
* CORS proxy, which is used for TVguide, news, traffic info, frames, images in buttons
You can switch an external CORS proxy as well.
All Domoticz blocks should work without issues.
Masure
Post by Masure »
Thanks for detailed answer !
