RFLink-WIFI does not work
Posted: Tuesday 22 October 2019 20:29
I try to get my RFLink-WIFI to work, but this does not work.
I have configured the NodeMCU as indicated in the manual NodeMCU v4.
Because of the slightly older RFLink version I have connected the RX and TX of the coupling board via 2 wires to the RX and TX of the Arduino. I have checked that these are not wrong.
However, I do not know whether / (how) it can be further checked whether the RFLink-WIFI works properly outside Domoticz. I have doubts whether the NodeMCU communicates with the Arduino. How can I test this?
In Domoticz I can neatly add the RFLink and connect works, but it seems that it does not work properly. See log below.
I don't see a signal coming in and can't send a signal. Is it possible to read logs from the RFLink, for example?
The RFLink's firmware is R48. Do I have to do anything to run the communication about the NodeMCU?
Are there other ideas that can help me further?
Hardware:
Raspberry Pi
RFlink-WIFI
(Arduino mega
RFLink 1.1 firmware R48
Wifi koppelprint
NodeMCU)
USB lader 5V 1A
Software:
Domoticz 4.11352
This continues endlessly.2019-10-20 14:41:24.244 Status: RFLink: trying to connect to 192.168.1.37:8080
2019-10-20 14:41:24.248 Status: RFLink: connected to: 192.168.1.37:8080
2019-10-20 14:42:04.249 Error: RFLink: Nothing received for more than 30 seconds, restarting...
2019-10-20 14:42:24.251 Status: RFLink: trying to connect to 192.168.1.37:8080
2019-10-20 14:42:54.254 Status: RFLink: trying to connect to 192.168.1.37:8080
2019-10-20 14:42:54.257 Status: RFLink: connected to: 192.168.1.37:8080
2019-10-20 14:43:44.259 Error: RFLink: Nothing received for more than 30 seconds, restarting...
2019-10-20 14:43:54.260 Status: RFLink: trying to connect to 192.168.1.37:8080
2019-10-20 14:44:24.263 Status: RFLink: trying to connect to 192.168.1.37:8080
2019-10-20 14:44:24.266 Status: RFLink: connected to: 192.168.1.37:8080
Hardware:
Raspberry Pi
RFlink-WIFI
(Arduino mega
Wifi koppelprint
NodeMCU)
USB lader 5V 1A
Software:
Domoticz 4.11352
