state attribute and battery level evohome devices
Posted: Sunday 20 October 2019 21:58
by Bertvdw
I just did a fresh install on a rasberry pi and went to the last beta version of domoticz 4.11388
I connected my evohome system with the HGI80.
Now my scripts are not running anymore because the .state attribute has a value nil. The .active attribute does work for a HR92, but not for an extra relay i binded.
I did check the values with the <device>.dump() method and there i see the _state field is correctly filled.
I also don't see the battery levels anymore
Greetz Bert
Re: state attribute and battery level evohome devices
Posted: Sunday 20 October 2019 22:14
by waaren
Bertvdw wrote: Sunday 20 October 2019 21:58
I just did a fresh install on a rasberry pi and went to the last beta version of domoticz 4.11388. INow my scripts are not running anymore.
What was the version before this in which your scripts did work ?
Can you please enable debug logging in the script and share the logfile ?
Can you please share the script that is no longer working ?
Posted: Tuesday 22 October 2019 11:18
by Bertvdw
Thanks for reacting so quicly.
I don't know the exact beta version anymore, but i updated the last time in the beginning of july 2019.
I had to do a fresh install because my SD card was corrupt.
Tonight i will provide you the information you asked for.
Posted: Tuesday 22 October 2019 21:41
by Bertvdw
I did enable the logfile, can you tell me where i can find the log-file so i can share this?
Greetz Bert
Posted: Tuesday 22 October 2019 23:45
by waaren
Bertvdw wrote: Tuesday 22 October 2019 21:41
Greetz Bert
You can find the location of the logfile in the same file where you enabled it.
look in /etc/init.d/domoticz.sh
Posted: Saturday 26 October 2019 23:29
by Bertvdw
Hereby i send you the files you asked for
The first results are with the line ...device.state... enabled
Script file: Script_1.txt
Logfile : domoticz_1.lua.txt
domoticzData.lua.txt
In the second test i disabled the line ...device.state...
Script file Script_2.lua.txt
Logfile : domoticz_2.txt
I also tried ...device.active... , this always gives False
Remark: I had to add .txt to the lua file, otherwise i couldn't attach them
The last two file i put in a separete post
Greetz Bert
Posted: Saturday 26 October 2019 23:30
by Bertvdw
Herby the last two attachments.
Posted: Sunday 27 October 2019 8:56
by waaren
I just did a fresh install on a rasberry pi and went to domoticz 4.11388
Can you please test below modified evohome device adapter and report your findings ?
cp <domoticz dir>/dzVents/runtime/device-adapters/evohome_device.lua <domoticz dir>/dzVents/runtime/device-adapters/evohome_device.luaKeep
and replace it with this modified adapter. ( No need to restart domoticz or dzVents )
Can you explain in a bit more detail what you mean with his ? domoticz only reports a valid battery-level for device 'Woonkamer (V)'
local TimedCommand = require('TimedCommand')
baseType = 'device',
name = 'Evohome device adapter',
matches = function (device, adapterManager)
local res = (
device.hardwareTypeValue == 39 or
device.hardwareTypeValue == 40 or
device.hardwareTypeValue == 106 or
device.hardwareTypeValue == 75
if (not res) then
adapterManager.addDummyMethod(device, 'updateSetPoint')
adapterManager.addDummyMethod(device, 'setHotWater')
adapterManager.addDummyMethod(device, 'setMode')
return res
end,
process = function (device, data, domoticz, utils, adapterManager)
if device.deviceSubType == "Hot Water" then
if device.rawData[2] == "On" then device.state = "On" else device.state = "Off" end
device.mode = tostring(device.rawData[3] or "n/a")
device.untilDate = tostring(device.rawData[4] or "n/a")
function device.setHotWater(state, mode, untilDate)
if mode == 'TemporaryOverride' and untilDate then
mode = mode .. "&until=" .. untilDate
local url = domoticz.settings['Domoticz url'] ..
"/json.htm?type=setused&idx=" .. device.id ..
"&setpoint=&state=" .. state ..
"&mode=" .. mode ..
"&used=true"
return domoticz.openURL(url)
elseif device.deviceSubType == "Relay" then
if device._state == "On" then
device.state = "On"
device.active = true
device.active = false
device.state = device.rawData[2]
device.setPoint = tonumber(device.rawData[1] or 0)
device.mode = tostring(device.rawData[3])
function device.updateSetPoint(setPoint, mode, untilDate)
return TimedCommand(domoticz,
'SetSetPoint:' .. tostring(device.id),
tostring(setPoint) .. '#' ..
tostring(mode) .. '#' ..
tostring(untilDate) , 'setpoint')
function device.setMode(mode, dParm, action, ooc)
local function checkTimeAndReturnISO(tm)
local now = domoticz.time
local iso8601Pattern = "(%d+)-(%d+)-(%d+)T(%d+):(%d+):(%d+)Z"
local iso8601Format = "%Y-%m-%dT%TZ"
local function inFuture(tmISO)
local function makeFutureISOTime(str, hours)
local xyear, xmonth, xday, xhour, xminute, xseconds = str:match(iso8601Pattern)
local seconds = os.time({year = xyear, month = xmonth, day = xday, hour = xhour, min = xminute, sec = xseconds})
local offset = (seconds + ( hours or 0 ) * 3600)
return os.date(iso8601Format,offset), offset
local _, epoch = makeFutureISOTime(tmISO)
return epoch >= now.dDate and tmISO
if type(tm) == 'string' and tm:find(iso8601Pattern) then return inFuture(tm) end -- Something like '2016-04-29T06:32:58Z'
if type(tm) == 'table' and tm.getISO then return inFuture(tm.getISO()) end -- a dzVents time object
if type(tm) == 'table' and tm.day then return inFuture(os.date(iso8601Format,os.time(tm))) end -- a standard time object
if type(tm) == 'number' and tm > now.dDate then return inFuture(os.date(iso8601Format,tm)) end -- seconds since epoch
if type(tm) == 'number' and tm > 0 and tm < ( 365 * 24 * 60 ) then return inFuture(os.date(iso8601Format,now.dDate + ( tm * 60 ))) end -- seconds since epoch + tm
domoticz.log('dParm ' .. tostring(dParm) .. ' cannot be processed. (it will be ignored)',utils.LOG_ERROR)
return false -- not a time as we know it
local function isValid(mode)
for _, value in pairs(domoticz) do
local res = type(value) == 'string' and value == mode
if res then return res end
return mode == 'Busted' or false
local function binary(num, default)
if num == 0 or num == 1 then return num else return default end
if isValid( tostring(mode) ) then -- is it in the list of valid modes ?
local dParm = dParm and checkTimeAndReturnISO(dParm) -- if there is a dParm then check if valid and make a valid ISO date
dParm = ( dParm and '&until=' .. dParm ) or ''
local action = ( action and '&action=' .. binary(action, 1) ) or '&action=1'
local ooc = ( ooc and '&ooc=' .. binary(ooc, 0) ) or '&ooc=0'
'/json.htm?type=command¶m=switchmodal&idx=' .. device.id ..
"&status=" .. mode ..
dParm ..
action ..
ooc
utils.log('Unknown status for setMode requested: ' .. tostring(mode),utils.LOG_ERROR)
Posted: Tuesday 29 October 2019 23:11
by Bertvdw
I changed the evohome_device.lua file like you asked.
Now i can use the attibute state again.
There is still one strange thing the relay "Schuur (P)".
If i manually change the state on the physical device, then no event is triggered.
So the device attributes are not correct.
I bound the relay 'Schuur (P)' in the 'Hardware tab' with the 'Bind Relay' (See attachment).
About the batterylevel:
In the old environment all the evohome zone devices and some of the Relay devices showed the batterylevel in the devices tab.
Now only one zone device shows the batterylevel ( See attachments )
Greetz Bert
Posted: Wednesday 30 October 2019 0:03
by waaren
Bertvdw wrote: Tuesday 29 October 2019 23:11
I changed the evohome_device.lua file like you asked. Now i can use the attibute state again.
Will push the fix of the evohome device adapter to the next Beta
I have no clue on the relay stuf. Maybe one of the other forum members can help.
Reported the battery issue on Github. Hopefully someone can shed some light on this.
Re: state attribute and battery level evohome devices [SOLVED]
Posted: Thursday 31 October 2019 11:02
by Bertvdw
Thank you so far for your help.
Gr. Bert
