Dzvents as sprinkler controler
Posted: Saturday 19 October 2019 0:24
by Dembe
Hello everyone,,
i would like to control my sprinkler system (4 valves visible as switches in domoticz)
what would be best approach to create dummy switch controlled with dzvents
i want to run (on switch)
https://www.quickppsr.com.au/
1 valve (x min on then switch off)
2 valve (x min on then switch off)
3 valve (x min on then switch off)
4 valve (x min on then switch off)
it even possible to run script for so long?
problem is that i want to be able switch off at anytime and interrupt program and disable valves anytime....?
Re: Dzvents as sprinkler controler
Posted: Saturday 19 October 2019 0:48
by waaren
Dembe wrote: Saturday 19 October 2019 0:24
I would like to control my sprinkler system (4 valves visible as switches in domoticz)
Sorry but I don't understand your requirement. Can you please explain in a bit more words what you try to to achieve ?
Posted: Saturday 19 October 2019 13:07
by hoeby
Could this be a start?
--Script version: 19101902
local valve1dummy = dz.devices("Valve1dummy") -- Change name between " " to your dummy device name.
local valve1name = dz.devices("Valve1name") -- Change name between " " to your valve device name.
local valve1on = "5" -- Change number between " ", this is time valve is ON, in minutes.
local valve2dummy = dz.devices("Valve2dummy") -- Change name between " " to your dummy device name.
local valve2name = dz.devices("Valve2name") -- Change name between " " to your valve device name.
local valve2on = "5" -- Change number between " ", this is time valve is ON, in minutes.
local valve3dummy = dz.devices("Valve3dummy") -- Change name between " " to your dummy device name.
local valve3name = dz.devices("Valve3name") -- Change name between " " to your valve device name.
local valve3on = "5" -- Change number between " ", this is time valve is ON, in minutes.
local valve4dummy = dz.devices("Valve4dummy") -- Change name between " " to your dummy device name.
local valve4name = dz.devices("Valve4name") -- Change name between " " to your valve device name.
local valve4on = "5" -- Change number between " ", this is time valve is ON, in minutes.
debug = false -- Set to true to enable extra log-info, set to false to disable extra log-info.
------------ Do not modify below this line ------------
devices = {
Valve1dummy,
Valve2dummy,
Valve3dummy,
Valve4dummy,
execute = function(dz, device)
--Valve 1 script
if dz.devices(Valve1dummy).state == 'On' then
valve1name.switchOn().forMin(valve1on)
if debug then
print ('Debug valve-script, ' ..valve1name.. ' is switch on for ' ..valve1on.. ' minutes.')
valve1name.switchOff()
if debug then
print ('Debug valve-script, ' ..valve1name.. ' is switch off.')
--Valve 2 script
if dz.devices(Valve2dummy).state == 'On' then
valve2name.switchOn().forMin(valve2on)
if debug then
print ('Debug valve-script, ' ..valve2name.. ' is switch on for ' ..valve2on.. ' minutes')
valve2name.switchOff()
if debug then
print ('Debug valve-script, ' ..valve2name.. ' is switch off.')
--Valve 3 script
if dz.devices(Valve3dummy).state == 'On' then
valve3name.switchOn().forMin(valve3on)
if debug then
print ('Debug valve-script, ' ..valve3namen.. ' is switch on for ' ..valve3on.. ' minutes')
valve3name.switchOff()
if debug then
print ('Debug valve-script, ' ..valve3name.. ' is switch off.')
--Valve 4 script
if dz.devices(Valve4dummy).state == 'On' then
valve4name.switchOn().forMin(valve4on)
if debug then
print ('Debug valve-script, ' ..valve4namen.. ' is switch on for ' ..valve4on.. ' minutes')
valve4name.switchOff()
if debug then
print ('Debug valve-script, ' ..valve4name.. ' is switch off.')
Release notes:
V19101901: Script is made. Not tested.
V19101902: Debug added.
Posted: Wednesday 23 October 2019 22:25
by pvklink
Is this what you want? (i have 6 irrigation zones, each zone has his own timers)
- irri.png (130.43 KiB) Viewed 577 times
Posted: Wednesday 23 October 2019 22:52
by besix
pvklink wrote: Wednesday 23 October 2019 22:25
Can you share a solution? It's interesting.
Thanks in advance
