RFXcom FUNK bus protocol support
Posted: Thursday 17 October 2019 23:58
I have been working with the RFXmngr on a laptop to control my GIRA lights (system 2000 dimmers). After a long journey of trial and error, it which works fine. The RFXmngr has a tab for FUNKbus which enables the controls, including the dimming levels. The lights can also be controlled using the ANSLUT protocol, but this is limited to switch on/off. Dimming does not work.
So far the RFXmngr. Now I want to use this FUNK protocol from teh RFXcom in my Domoticz setup (running on raspberry Pi 3). I tried to define a switch manually, but the FUNK protocol cannot be selected from the drop down menu. Why is it missing there (since it is a built in protocol of the RFXcom?). I need this setting to control my dimmers. Now I am using the ANSLUT protocol which at least enables me to switch the lights on and off, but it remains a work around....
I also tried to work with VeraPlus, but the protocol is not supported either in that hub.
Hope someone can help out!
Raspberry Pi3
Domoticz 4.10717
RFXcom 433XL firmware ProXL1_SpecialFunkbus_1042
Raspberry Pi3
Domoticz 4.10717
