Domoticz migration from x32 to x64 ubuntu 18.04 fails on ZWave
Posted: Wednesday 16 October 2019 22:30
I'm currently running Domoticz v4.10726 (OZW 1.4-3335-g74e05982-dirty) on Ubuntu 18.04 x32 in a VM with 3 USB devices (Z-Wave/RFX-433/P1-meter), OWM, SolarEdge API, Panasonic TV, Kodi and Philips Hue.
Recently I created a new VM with Ubuntu 18.04 x64 and installed the Stable Linux tar file v4.10717 (OZW 1.4-3335-g74e05982-dirty) from the download page of domoticz.com
I've created a seperate user domoticz (previously I used root), granted access to the ttyUSB*, added again sendxmpp option and so on.
Today I exported the database from my x32 VM and imported it into the x64 VM. Did a reboot of the x64 VM. All worked perfectly out in Domoticz and resumes like SolarEdge, RFX-433, P1-meter etc. except for the ZWave part. The ZWave devices are populated but manufacturer and the + sign for ZWave+ don't appear on the nodes page.
When a door/window sensor (Vision) is triggered "last seen" is updated on the ZWave & devices page except for the status open/closed on the dashboard/switches panels/tabs. Same for wall plugs (Fibaro). I cannot trigger the smoke and temp/hum sensors. However only two temp/hum sensors (Philio) got updated status on the temperature panel/tab.
What I've done so far:
- I let it to run for a couple of hours;
- Did a ZWave network heal a couple of times;
- Did a ZWave node reset for each device;
- Upgraded to non-stable/beta v4.11334 with OZW 1.6;
- Checked the log for errors;
- Double checked the ZWave network security key.
When I shutdown the x64 VM and spin the x32 VM back up, all ZWave devices are restored in a couple of minutes. Also the "manufacturer" column and the Zwave "+" sign are populated nearly instantly in nodes.
What do I do wrong / what did I miss / can someone help me? Thanks
Btw, FWIW I'm running those VM's on ESXi 6.7 update 3.
