Hi people,
i have a lot of Eurotronic thermostat valves and fibaro motion sensors in every room.
I'm using these temperature sensors to control my heating.
but the temperature of the thermostat valve is not good to know the temperature in the room.
also the one from the motion sensor is not good (it hangs on the ceiling and the heat is allways warmer there)
so i put a normal temperature meter and put it on the table in the middle of the room, it is different that the 2 (thermostat valve and motion sensor)
is there any temperature sensor i could use (and place it somewhere), i prefer a zwave one, but if it doesn't exists, another type will do.
Or does anyone of you has an idea how i could solve my problem
thanks
Temperature sensor
wouterlet
Re: Temperature sensor
Most decides you can set an offset in the temperature. In the eurotronic I'm sure you can. That way you can adjust his measured temp to the right value.
kimot
- Domoticz version: v3.8153
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
1 x Shelly 1
1 x RFLink
4x Cam IPC-T240H
