zigate set device as non-router or end-device
abroeders
I wonder if it is possible to set a zigbee device as non-router in the configuration that is persistent. I have an ikea bulb that is regularly powered off and some devices insist on routing through this device although a direct route is also possible. If i can configure this bulb as end-device i would be happy.
Re: zigate set device as non-router or end-device
Unfortunately this not under our control. This is cover by the Zigbee stack provided in a binary format by the NXP (chipset provider).
In short we don't have any control of the routing mecanism
abroeders
Thanks for your reply.. then I should take a look at powering this bulb constantly. Good to know it can't be tweaked.
