[SOLVED] Timer on selector switch
Posted: Friday 11 October 2019 15:07
by Andrex
I'm trying to use the timer function on a selector switch, but the value presented on the "Level" are all but the first (Level 0).
I use it as a season selector for the conditioning system , so I have "Summer" as level 0 and "Winter" on Level 10.
Re: Timer on selector switch
Posted: Friday 25 October 2019 15:53
by cyberclwn
I think because it needs a Level (higher then 0) combined with the "on" command.
And the "off"-command means level 0.
Gr.
Posted: Friday 25 October 2019 17:10
by Andrex
Hi cyberclwn,
thanks for your post.
You are right, using off as a command, it goes at level 0.
It's working for me, but it's a bit confusing.
Re: [SOLVED] Timer on selector switch
Posted: Thursday 29 September 2022 23:35
by psubiaco
This post is a bit old (Sep 2022, now), but still useful.
Setting timer for Selector switch device works well, now.
Please take care that to test it, you have to set at least 2 minute offset from now.
For example, if current time is 23:32 and you want to test now the Selector Switch set to a certain level, try setting OnTime 23:34 or later. If you set 23.33 (less than 1 minute from now) it will not work.
Posted: Monday 07 November 2022 10:00
by Andrex
Thanks for the info!
