Blockly is not working?
Posted: Friday 11 October 2019 11:22
by Tweak
I have created this as test:
But it is not working?? When i turn a switch On or Off nothing happends.
Is this detection system broken?
Re: Blockly is not working?
Posted: Friday 11 October 2019 13:20
by HansieNL
I once had some strange reactions when a name was part of an other name.
Can you try to rename SomeoneHome to SoHome and see of that works ok.
Posted: Friday 11 October 2019 14:24
by Tweak
Thnx, but i think i found the problem.. I tried to do the same with LUA and didn't work either.
So i created a new switch but then i noticed this was not the same switch. This one is On/Off only…
Now LUA can control that switch with no problems. And LUA looks nice no drag and drop..
So im going to try to create the complete script in LUA.
Posted: Friday 11 October 2019 21:04
by Tweak
Works perfect now =)
(I never used LUA before so yes maybe its not pretty but it works)
if (otherdevices['Tel1'] == 'On' or otherdevices['Tel2'] == 'On') then
TelAanwezig = true
if (otherdevices['SomeoneHomeActief'] == 'On' and otherdevices['IemandThuis'] == 'Off' and TelAanwezig == true) then
print("SomeoneHomeActief staat aan en IemandThuis is off en een van de telefoons is verbonden met wifi dus zet IemandThuis On")
commandArray['IemandThuis']='Set Level: 10'
if (otherdevices['SomeoneHomeActief'] == 'On' and otherdevices['IemandThuis'] == 'On' and TelAanwezig == false) then
print("SomeoneHomeActief staat aan en IemandThuis is On en geen telefoons verbonden met wifi dus zet IemandThuis Off")
commandArray['IemandThuis']='Set Level: 0'
Posted: Tuesday 26 November 2019 16:40
by Smartie
Hey Maybe the same Problem
https://www.domoticz.com/forum/viewtopi ... ua#p229337
I Have a lot of Blocky events but only 2 LUA scripts for the Powerusage
I Can Use only one at the same time.
But newer version
