Z-Wave and AEON Labs ZW100 MultiSensor 6
Micha123
Post by Micha123 »
hi, i havve an AEON Labs ZW090 Z-Stick Gen5 EU usb stick and an AEON Labs ZW100 MultiSensor 6
all is working fine, but i cannot change temperature settings on that sensor.
thats the values for temperature that domoticz shows in the config of the Multisensor 6
Temperature Reporting Threshold: 1310976
Set the upper limit value of temperature sensor: 18350336
Set the lower limit value of temperature sensor: 256
that isuse i have only on the Temp sensor, and i cannot change the values to real one.
all other sensor values are changeable and OK.
but the sensor reports the temperature correctly, i have it on usb Power, so it reports all values every minute. (i made that setting) also the temp to domoticz and the values are good.
but in the config what are the values means on the temperature sensor ?
