Device to store time
Posted: Wednesday 09 October 2019 12:34
by Andrex
I need to have a device where I can store/change a time that is in seconds or minutes.
I need this to manage the time some light stays on or the time some light should be turned off after the alarm system is engaged.
That value would be used in NodeRed.
Which virtual device should I use?
Re: Device to store time
Posted: Wednesday 09 October 2019 14:19
by waaren
Andrex wrote: Wednesday 09 October 2019 12:34 I need to have a device where I can store/change a time that is in seconds or minutes.
Would it not be easier to store it in a type time uservariable ?
Posted: Wednesday 09 October 2019 14:38
by Andrex
Tha fact is that I would like to have those variables to be quickly editable by my colleague, so a device would be really nice.
It would be cool to be able to "enable" a user variable to become a device
Posted: Wednesday 09 October 2019 18:21
by waaren
Andrex wrote:Tha fact is that I would like to have those variables to be quickly editable by my colleague, so a device would be really nice.
A dimmer can be set to a number between 1-100.
A selector has a limited number of steps but content can be set to any number.
Posted: Wednesday 09 October 2019 19:22
by Andrex
waaren wrote: Wednesday 09 October 2019 18:21 A dimmer can be set to a number between 1-100.
Right!!!
I'll try, thanks for the suggestion!
But still, a device of plain editable number would be great!
Posted: Thursday 10 October 2019 20:05
by Andrex
waaren wrote: Wednesday 09 October 2019 18:21 A selector has a limited number of steps but content can be set to any number.
Is there a way to change the level of the selector? Because retrieving the value with the API only gives the level and not the level name.
Also it would be much easier for me to use the level directly with the numbers I need.
Posted: Thursday 10 October 2019 20:38
by waaren
Andrex wrote: Thursday 10 October 2019 20:05
I use dzvents for both setting and retrieving this information. .(attribute levelname(s) and method switchSelector)
Using the API the level of the selector can be set with
https:/<domoticz ip>:domoticz port>/json.htm?type=command&param=switchlight&switchcmd=Set%20Level&level=<LEVEL>&idx=<ID>
Using the API, the level names can be retrieved using
https:/<domoticz ip>:domoticz port>/json.htm?type=devices&rid=<ID >
For one of my selector devices this returns
"ActTime": 1570732049,
"AstrTwilightEnd": "20:52",
"AstrTwilightStart": "06:06",
"CivTwilightEnd": "19:34",
"CivTwilightStart": "07:24",
"DayLength": "11:03",
"NautTwilightEnd": "20:13",
"NautTwilightStart": "06:45",
"ServerTime": "2019-10-10 20:27:29",
"SunAtSouth": "13:29",
"Sunrise": "07:58",
"Sunset": "19:01",
"app_version": "4.11360",
"result": [
"AddjMulti": 1,
"AddjMulti2": 1,
"AddjValue": 0,
"AddjValue2": 0,
"BatteryLevel": 255,
"CustomImage": 159,
"Data": "Off",
"Description": "",
"DimmerType": "none",
"Favorite": 0,
"HardwareID": 14,
"HardwareName": "Sonos",
"HardwareType": "Sonos Players",
"HardwareTypeVal": 94,
"HaveDimmer": true,
"HaveGroupCmd": true,
"HaveTimeout": false,
"ID": "000E0004",
"Image": "Sonos",
"IsSubDevice": false,
"LastUpdate": "2019-10-08 22:10:37",
"Level": 0,
"LevelActions": "fHx8fHw=",
"LevelInt": 0,
"LevelNames": "T2ZmfE5QTyBSYWRpbyAxfE5QTyBSYWRpbyAyIDkyLjkgKFBvcCl8UmFkaW8gMTB8UmFkaW8gUmlqbm1vbmR8U3VibGltZSBTbW9vdGg=",
"LevelOffHidden": false,
"MaxDimLevel": 100,
"Name": "Sonos - Radio",
"Notifications": "false",
"PlanID": "0",
"PlanIDs": [
0
"Protected": false,
"SelectorStyle": 1,
"ShowNotifications": true,
"SignalLevel": "-",
"Status": "Off",
"StrParam1": "",
"StrParam2": "",
"SubType": "Selector Switch",
"SwitchType": "Selector",
"SwitchTypeVal": 18,
"Timers": "false",
"Type": "Light/Switch",
"TypeImg": "Light",
"Unit": 4,
"Used": 1,
"UsedByCamera": false,
"XOffset": "0",
"YOffset": "0",
"idx": "2593"
"status": "OK",
"title": "Devices"
If you decode the Base64 coded Levelnames you get
Off|NPO Radio 1|NPO Radio 2 92.9 (Pop)|Radio 10|Radio Rijnmond|Sublime Smooth
Posted: Friday 11 October 2019 15:04
by Andrex
I wouldn't mark this as solved since it's still not possible to store a plain number into a device
