Timed device trigger not working...  [Solved]
FearNaBoinne
Domoticz version: 2021.1
Post by FearNaBoinne »
I am trying to use a timed device trigger, but it's not working...
Can anyone tell me what I am doing wrong?
	    devices = { ['Voordeur Entry Sensor'] = { 'at nighttime' } }
		domoticz.log('Hal licht aan/uit.', domoticz.LOG_INFO)
		if ( device.status == "open" ) then
		    -- turn light on
		    domoticz.devices('Ganglicht BG').setState("On")
	    	elseif ( device.status == 'closed' ) then
	       	    -- turn light off after one minute
		    domoticz.devices('Ganglicht BG').setState("Off").afterMin(1)
It is not triggering at all, even though the device name is correct and the time is between sunset and sunrise...
RasPi, Raspbian , Domoticz v2021.1, Z-Wave Stick, RFLink, RFXtrx433e, Hue, Tuya (Tasmota/Mosquitto with Discovery), ESP(easy), MySensors.org, OTGW
Re: Timed device trigger not working...
FearNaBoinne wrote: Friday 04 October 2019 22:36 I am trying to use a timed device trigger, but it's not working...
I can't see anything wrong with your script. Just tested below (domoticz V4.11350 / dzVents 2.4.29
        devices = { ['my Trigger'] = { 'at nighttime' } }
    execute = function(dz, item)
        dz.log(item.name .. ' triggered this script.', dz.LOG_FORCE)
Log
]2019-10-04 23:18:41.149  Status: dzVents: Info: Handling events for: "my Trigger", value: "On"
2019-10-04 23:18:41.150  Status: dzVents: Info: ------ Start external script: dumper499 (combined trigger).lua: Device: "my Trigger (Virtual)", Index: 2355
2019-10-04 23:18:41.152  Status: dzVents: !Info: my Trigger triggered this script.
2019-10-04 23:18:41.156  Status: dzVents: Info: ------ Finished dumper499 (combined trigger).lua
BOverdevest
Domoticz version: 4.11307
Re: Timed device trigger not working...  [Solved]
Post by BOverdevest »
Is the use of "status" correct? I think it should be ".state"
Below my script for a similar situation. The OD's are the Open/Close devices.
--Voordeur of zijdeur open
	on = { devices = {['OD Voordeur'] = {'at nighttime'},['OD Zijdeur'] = {'at nighttime'}}},
        domoticz.devices('Voordeur Lamp').switchOn().checkFirst().forMin(10)
HUE, Tradfri, Zwave, RFXCOM, rooted TOON, PS4
FearNaBoinne
BOverdevest wrote: Friday 04 October 2019 23:28 Is the use of "status" correct? I think it should be ".state"
Weird, I missed that, and as soon as I changed it, the script started triggering... Very strange that it didn't even trigger when it said .status instead of .state, but did not show any errors in the editor NOR in the logs!...
FearNaBoinne wrote: Friday 04 October 2019 23:48 Weird, I missed that, and as soon as I changed it, the script started triggering... Very strange that it didn't even trigger when it said .status instead of .state, but did not show any errors in the editor NOR in the logs!...
The triggering of the script should not be influenced by this. And
is formally not an error. It will just always evaluates to false because device.status is not equal to "open" (it is nil)
Can you check your dzVents loglevel ? Do you see other scripts being triggered if they do not have an explicit logging = section ?
FearNaBoinne
waaren wrote: Friday 04 October 2019 23:58 The triggering of the script should not be influenced by this.
I know, and I was about to respond with that, but then I thought I'd try fixing that error anyway, and after that it worked... And the *only* thing I did was replace 'us' with 'e' (twice)...
waaren wrote: Friday 04 October 2019 23:58 Can you check your dzVents loglevel ? Do you see other scripts being triggered if they do not have an explicit logging = section ?
Yup, and once I changed the .status-es for .state-s, so did this one (even without the domoticz.log line), but not before that! I don't understand either...
