fontsize of a block value
Posted: Friday 04 October 2019 11:10
by rene2716
I can change the fontsize of a block with custom.css, but it does not change the value fontsize, only the title text of the block.
Any tips or tricks?
tnx in advance
René
Re: fontsize of a block value
Posted: Sunday 10 May 2020 20:10
by hannuf
I am also trying to change font size of value in one block, did you find out how to? or can someone help with this?
Posted: Sunday 10 May 2020 20:22
by hannuf
Found it on other topic, .block_6_3 .title { font-size:12px ; }
Posted: Sunday 19 July 2020 0:24
by webrazor
This worked for me to, but after update to 3.5 it is not working anymore.
Now i use:
.block_78 .value {
font-size : 48px!important;
Posted: Saturday 01 August 2020 13:52
by Lokonli
Is this solved already?
What kind of device is it?
If the above is not working try with:
.block_78 .state{
Posted: Saturday 01 August 2020 14:07
by Lokonli
webrazor wrote: Sunday 19 July 2020 0:24
Now i use:
.block_78 .value {
From your other post I guess it's a temperature device. Correct?
On my system with device ID 2 as a temperature device the following is changing the size of the temperature value:
.block_2 .value {
font-size: 35px!important
However, if you defined a block in CONFIG.js with a custom identifier, then you have to use that identifier as well in custom.css.
So, in case your CONFIG.js contains:
then you have to add the following to custom.css:
.block_mytemp .value {
