Whats most stable to put Domoticz on
Ptje
Post by Ptje »
After several years using Domoticz with much pleasure, I want it to install on a more stable device as the raspberry pi 3b. I had in the past years, several times that after a simple install of a plugin, Domoticz was not working anymore, ore with problems. Sometimes it does not work by it's self anymore.
I don't like that, because I have a lot of things working with Domoticz and I want that stays working for the most of the time. Now I did read it should be much more stable when the raspberry pi is running on a usb stick, so I did that installation. After installing "Buienradar" and "Sonos" and some updates, Domoticz does not boot anymore.
Witch device is mor stable ?
Greetings,
Peter
OedzesG
Re: Whats most stable to put Domoticz on
Post by OedzesG »
door Ptje »woensdag 02 oktober 2019 23:28
Take a look at: https://www.domoticz.com/forum/viewtopi ... 28&t=29583
For me Domoticz on Synology works great..
