Association in Domoticz with Z-Stick Gen 5
KroontjesPen
Domoticz version: 4.10717
Post by KroontjesPen »
Version: V4.10717 b386b49e5
Platform: Windows 10
RFXtrs433E Version: Ext2/1025
Z-Stick Gen 5 Version: 1.4.3244.gbb874f6a.dirty
Fibaro Wall Plug 5x
Like KaKu/COCO/Trust I want to use a wall switch remote control to switch a wall plug directly.
Later also a hand remote control for Qubino modules.
In Z-Wave they call it association I think.
My first try was the 8 button wall remote but I send it back because the manual was too difficult to read.
Set and unset associations:
(Note: All association information will be cleared automatically once the remote control is excluded from a
network.)
There are two methods to set associations:
1. Set association by operating primary controller/gateway to send association command to the remote control:
When set association from primary controller/gateway, the remote control shall be activated first, if it is not
activated, you should activate it manually.
The primary controller/gateway sends association command to the remote control using “Command Class
ASSOCIATION” or “Command Class Multi Channel Association”
2. Set association by operating the remote control and devices to be controlled:
To control a Z-Wave device from the remote control the node ID of this device needs to be assigned to one of
the two association groups. This is a three-step process:
1. Press and hold down both buttons and of Group 2 over 3 seconds, LED indicator turns on.
2. Short press ON button of any group within 7s to associate the device to this group, short press OFF button of
any group within 7s to remove association of the device from this group.
3. Operate the device to be controlled to send Node Information Frame (please refer to the device manual)
within 10 seconds, or set the device to exclusion mode within 10 seconds, since it will send Node Information
Frame in exclusion mode, LED indications are as follows:
LED blinks twice to indicate that the remote control failed to add the associated device (the association group
has already added maximum quantity associated devices that it supports ).
LED blinks 5 times to indicate that the remote control added the associated device successfully.
LED blinks 8 times to indicate that the remote control removed the associated device successfully.
Option 2 like to be that's needed here only I don't understand point 3.
Also for wiki under: 'Network and group info' the same.
https://www.domoticz.com/wiki/Zwave
Is it there where you do the association?
Can you then without Domoticz with the wall (remote) switch, really switched a wall plug on/off ?
Is there somewhere a more clearer manual for this?
Then I can decided to by the 8 button wall remote again and later the hand remote controls for the garden.
Bear with me, English is not my native language.
