How to configure Fibaro binary sensor in Domoticz
Posted: Saturday 28 September 2019 21:53
I am fairly new to Domoticz, so I like to apologize in advance when this is a silly question.
I recently bought an Fibaro Binary Sensor (the old one).
My idea is, to connect this sensor to a pulse switch, to make a smart switch, wich looks like any other normal switch in the room.
The idea is like this.
Binary-switch 1, if scene 1 is of, then switch scene 1 on.
Binary-switch 1, if scene 1 is on, then switch scene 1 off.
So, just like a normal switch, but now it switches scenes on and off. and because the sensor has 2 switches, I can switch 2 scenes.
That is the idea at least.
My problem is, that I can program 1 action. So when, the switch is pressed, it turns the scene on.
The problem starts when I make it relative to the state of the scene (on or off)
Then it falls in a loop. When I press the switch the scene goes on, off, on, off, on, off, on, well, you get the idea.
I have the settings of the binary sensor on default, except the type of input, that is "normal open" (made more sense)
However when I put it on NC, normal closed, it makes absolutely no difference.
Also I noticed, (see picture with log) when I press the switch, the sensor gives 2 reactions. No idea why.
What am I doing wrong?
Hope you guys have any ideas!
Thanks a lot...
Thanks a lot...
