New user - no devices shown
Rolandet
Domoticz version: 2021.1
Post by Rolandet »
I thought I'd try my luck and install Dashticz
Sofar I have the screen setup, and enabled the standard entries (bus departures, radio stations, tv programms)
At first I got the well known error that Domoticz wasn't found, but i've managed to work that out.
However.........I don't see any of my Domoticz devices :(
Here's my config
var config = {}
config['domoticz_ip'] = 'http://192.168.178.20:8080';
config['user_name'] = '**********';
config['pass_word'] = '***********';
config['app_title'] = 'Dashticz V3 Roland';
config['room_plan'] = 0;
config['default_news_url'] = 'http://www.nu.nl/rss/algemeen';
config['news_scroll_after'] = '7';
config['default_cors_url'] = 0;
config['dashticz_php_path'] = './vendor/dashticz/';
config['standby_call_url'] = 0;
config['standby_call_url_on_end'] = 0;
config['theme'] = 'default';
config['background_image'] = 'img/bg2.jpg';
config['standby_after'] = 0;
config['start_page'] = 1;
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '9';
config['auto_slide_pages'] = 0;
config['slide_effect'] = 'slide';
config['standard_graph'] = 'hours';
config['blink_color'] = '255, 255, 255, 1';
config['language'] = 'en_US';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'en_US';
config['calendarurl'] = 0;
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = 0;
config['gm_zoomlevel'] = 0;
config['gm_latitude'] = 0;
config['gm_longitude'] = 0;
config['speak_lang'] = 'en-US';
config['wu_api'] = 0;
config['wu_city'] = 'Amsterdam';
config['wu_name'] = 0;
config['wu_country'] = 'NL';
config['owm_api'] = 0;
config['owm_city'] = 'Mainaschaff';
config['owm_name'] = 0;
config['owm_country'] = 'de';
config['owm_lang'] = 0;
config['owm_cnt'] = '4';
config['idx_moonpicture'] = 0;
config['longfonds_zipcode'] = 0;
config['longfonds_housenumber'] = 0;
config['switch_horizon'] = 0;
config['host_nzbget'] = 0;
config['spot_clientid'] = 0;
config['sonarr_url'] = 0;
config['sonarr_apikey'] = 0;
config['sonarr_maxitems'] = 0;
config['garbage_company'] = 0;
config['garbage_icalurl'] = 0;
config['google_api_key'] = 0;
config['garbage_calendar_id'] = 0;
config['garbage_zipcode'] = 0;
config['garbage_street'] = 0;
config['garbage_housenumber'] = 0;
config['garbage_housenumberadd'] = 0;
config['garbage_maxitems'] = 0;
config['garbage_width'] = 0;
config['setpoint_min'] = '5';
config['setpoint_max'] = '40';
config['loginEnabled'] = 0;
config['disable_update_check'] = 0;
config['no_rgb'] = 0;
config['auto_positioning'] = 1;
config['use_favorites'] = 0;
config['disable_googleanalytics'] = 0;
config['last_update'] = 1;
config['hide_topbar'] = 0;
config['security_button_icons'] = 0;
config['edit_mode'] = 0;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['owm_days'] = 0;
config['owm_min'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 0;
config['hide_mediaplayer'] = 0;
config['garbage_icon_use_colors'] = 1;
config['garbage_use_colors'] = 0;
config['garbage_use_names'] = 0;
config['garbage_use_cors_prefix'] = 1;
Can anyone help me out?
Last edited by Rolandet on Saturday 28 September 2019 16:14, edited 1 time in total.
Custodes Septentrionum
HansieNL
Re: New user - no devices shown
Post by HansieNL »
If you create your own dashboard you have to change the following setting too:
config['auto_positioning'] = 0;
From the manual:
Configure the ability to define your own positioning for the buttons (in combination with config['use_favorites'])
0 Use this if you have defined your own columns
1 Default
You have also to create the columns and screens yourself.
See for documentation of latest beta: https://dashticz.readthedocs.io/en/beta ... ction.html
Blah blah blah
Rolandet
Post by Rolandet »
Thanks Hans,
I've added the auto position
however, I already defined blocks, columns and screens, so I'm not sure what's still to add? Maybe I'm not understand things right?
var config = {}
config['user_name'] = 'x';
config['pass_word'] = 'x.';
//Definition of blocks
blocks = {}
blocks[120] = {
  width: 6
blocks[121] = {
  width: 6
//Definition of columns
columns = {}
columns[1] = {
      width: 4
      columns[2] = {
        blocks : [120, 121],
          width: 8
//Definition of Screens
screens = {}
screens[1] = {
          columns: [1, 2]
config['use_favorites'] = 0;  //Request all Domoticz Devices, not only favorites
HansieNL
Post by HansieNL »
Can you try:
var config = {}
blocks = {}
blocks[120] = {
  width: 6
blocks[121] = {
  width: 6
columns = {}
columns[1] = {
      width: 4
      columns[2] = {
          width: 8
screens = {}
screens[1] = {
          columns: [1, 2]
Blah blah blah
Lokonli
Post by Lokonli »
Rolandet wrote: Saturday 28 September 2019 16:18 Thanks Hans,
var config = {}
blocks = {}
blocks[120] = {
  width: 6
blocks[121] = {
  width: 6
columns = {}
columns[1] = {
      width: 4
      columns[2] = {
          width: 8
screens = {}
screens[1] = {
          columns: [1, 2]
Set auto_positioning to 0
For 120 and 121 you have to fill in your own Domoticz device id's.
Rolandet
Post by Rolandet »
Allrighty, put in both your suggestions:
For ID's i tried the 'IDx' and 'ID" from my DEVICES
var config = {}
blocks = {}
blocks[2] = {
  width: 6
blocks[3] = {
  width: 6
columns = {}
columns[1] = {
      width: 4
      columns[2] = {
        blocks : [2, 3],
          width: 8
screens = {}
screens[1] = {
          columns: [1, 2]
No result I'm afraid.
Do I need to restart Apache or anything after these changes?
Rolandet
Post by Rolandet »
aaah never mind. I've figured things out
The example blocks/columns etc for the radio/tv/bus table was conflicting, cause it uses the same column numbers.
So I've got my stuff running.
Thanks guys !!
HansieNL
Post by HansieNL »
Good to know your problem is solved. Have fun configuring your own dashboard.
Blah blah blah
