is it possible to create a local variable out of a parameter
Posted: Tuesday 24 September 2019 20:32
by Gravityz
maybe i try to solve something the wrong way but here is my question
if i call a global helper function like this
domoticz.helpers.test(domoticz,'switch A','On','Variable-switch-A')
how can i crete a local variable in that helper function that uses one of the passed information as the name of the local variable
eg
helpers = {
test = function(domoticz, Device, command, variable)
local $variable= "On"
so local definition needs to be
local Variable-switch-A="On"
so how can i create a local variable by using the name of a parameter
Re: is it possible to create a local variable out of a parameter
Posted: Tuesday 24 September 2019 22:25
by boum
It would help to know what you want to do with this variable. You cannot do that directly.
The easiest way to do something like that would be to use a table (local) instead of just a local variable.
local values = {
Variable-switch-A = 'Off',
Variable-switch-B = 'Off',
values[variable] = command
-- and you can access it later with by iterating on the full table: for key,value in pairs(values) do ... end
-- or access each value by doing
if values.Variable-switch-A == 'On' then ... end
Posted: Tuesday 24 September 2019 23:17
by waaren
Also possible without knowing the list of possible variables in advance.
local values = { [variable] = command }
if values[variable] == 'On' then
domoticz.log('On: content of values[' .. variable .. '] is ' .. tostring(values[variable]) , domoticz.LOG_FORCE)
domoticz.log('not On: content of values[' .. variable .. '] is ' .. tostring(values[variable]) , domoticz.LOG_FORCE)
Posted: Wednesday 25 September 2019 7:51
by Gravityz
ok thanks, both might be good solutions.
the reason i wanted this is i wanted to save the last state of a light and in case it switches on again(while it is still on) it is ignored.
one helper for all switches would be nice but then again i do not have that many switches so defining them upfront(example boum) would do the trick.
waarens example looks like exactly what i was looking for.
i know it is killing a mosquito with a tank(solving a jitter problem) but clean code is always nicer to look at
if this happens a lot i would have asked dannybloe to think about an .nojitter option in dzvents but this is killing the symptoms instead of killing the problem.
but still would look really nice if you could do domoticz.devices('test').switchon().nojitter
my qubino switch used to have that jitter problem as well but it seems to be gone
thanks guys
Posted: Wednesday 25 September 2019 8:41
by waaren
Gravityz wrote: Wednesday 25 September 2019 7:51
This would require the use of
(global) persistent storage
If only used to prevent an unneeded switch then consider the use of checkFirst():
checkFirst(): Function. Checks if the current state of the device is different than the desired new state. If the target state is the same, no command is sent. If you do mySwitch.switchOn().checkFirst(), then no switch command is sent if the switch is already on. This command only works with switch-like devices.
Posted: Wednesday 25 September 2019 8:54
by Gravityz
i looked at checkFirst some time ago for something else.
will test if this works because i do not know if the switchon will go fast enough to register as ON before the next ON command fires.
i believe Zwave does an acknowlegde before it registers as ON
let you know, this would be indeed the easiest way
