I have been trying for hours to install Moroens's Tradfri plugin on my Domoticz install on Synology.
I tried to follow the steps stated on Moroens GIT page on https://github.com/moroen/IKEA-Tradfri-plugin but I can't get through them for the life of me!
I can't get past step 4:
$ python3 setup.py install
It fails every time with this feedback:
(env) root@DiskStation:/volume1/@appstore/domoticz/plugins/IKEA-Tradfri# python3 setup.py install
Unable to find pgen, not compiling formal grammar.
Compiling /tmp/easy_install-zqqkwv_e/Cython-0.29.13/Cython/Plex/Scanners.py because it changed.
Compiling /tmp/easy_install-zqqkwv_e/Cython-0.29.13/Cython/Plex/Actions.py because it changed.
Compiling /tmp/easy_install-zqqkwv_e/Cython-0.29.13/Cython/Compiler/Scanning.py because it changed.
Compiling /tmp/easy_install-zqqkwv_e/Cython-0.29.13/Cython/Compiler/Visitor.py because it changed.
Compiling /tmp/easy_install-zqqkwv_e/Cython-0.29.13/Cython/Compiler/FlowControl.py because it changed.
Compiling /tmp/easy_install-zqqkwv_e/Cython-0.29.13/Cython/Runtime/refnanny.pyx because it changed.
Compiling /tmp/easy_install-zqqkwv_e/Cython-0.29.13/Cython/Compiler/FusedNode.py because it changed.
Compiling /tmp/easy_install-zqqkwv_e/Cython-0.29.13/Cython/Tempita/_tempita.py because it changed.
[1/8] Cythonizing /tmp/easy_install-zqqkwv_e/Cython-0.29.13/Cython/Compiler/FlowControl.py
[2/8] Cythonizing /tmp/easy_install-zqqkwv_e/Cython-0.29.13/Cython/Compiler/FusedNode.py
[3/8] Cythonizing /tmp/easy_install-zqqkwv_e/Cython-0.29.13/Cython/Compiler/Scanning.py
[4/8] Cythonizing /tmp/easy_install-zqqkwv_e/Cython-0.29.13/Cython/Compiler/Visitor.py
[5/8] Cythonizing /tmp/easy_install-zqqkwv_e/Cython-0.29.13/Cython/Plex/Actions.py
[6/8] Cythonizing /tmp/easy_install-zqqkwv_e/Cython-0.29.13/Cython/Plex/Scanners.py
[7/8] Cythonizing /tmp/easy_install-zqqkwv_e/Cython-0.29.13/Cython/Runtime/refnanny.pyx
[8/8] Cythonizing /tmp/easy_install-zqqkwv_e/Cython-0.29.13/Cython/Tempita/_tempita.py
warning: no files found matching 'Doc/*'
warning: no files found matching '*.pyx' under directory 'Cython/Debugger/Tests'
warning: no files found matching '*.pxd' under directory 'Cython/Debugger/Tests'
warning: no files found matching '*.pxd' under directory 'Cython/Utility'
warning: no files found matching 'pyximport/README'
unable to execute '/opt/bin/gcc': No such file or directory
File "/volume1/@appstore/py3k/usr/local/lib/python3.5/distutils/unixccompiler.py", line 116, in _compile
extra_postargs)
File "/volume1/@appstore/py3k/usr/local/lib/python3.5/distutils/ccompiler.py", line 909, in spawn
spawn(cmd, dry_run=self.dry_run)
File "/volume1/@appstore/py3k/usr/local/lib/python3.5/distutils/spawn.py", line 36, in spawn
_spawn_posix(cmd, search_path, dry_run=dry_run)
File "/volume1/@appstore/py3k/usr/local/lib/python3.5/distutils/spawn.py", line 159, in _spawn_posix
% (cmd, exit_status))
distutils.errors.DistutilsExecError: command '/opt/bin/gcc' failed with exit status 1
During handling of the above exception, another exception occurred:
File "/volume1/@appstore/py3k/usr/local/lib/python3.5/distutils/core.py", line 148, in setup
dist.run_commands()
File "/volume1/@appstore/py3k/usr/local/lib/python3.5/distutils/dist.py", line 955, in run_commands
self.run_command(cmd)
File "/volume1/@appstore/py3k/usr/local/lib/python3.5/distutils/dist.py", line 974, in run_command
cmd_obj.run()
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/command/bdist_egg.py", line 172, in run
cmd = self.call_command('install_lib', warn_dir=0)
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/command/bdist_egg.py", line 158, in call_command
self.run_command(cmdname)
File "/volume1/@appstore/py3k/usr/local/lib/python3.5/distutils/cmd.py", line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/command/install_lib.py", line 11, in run
self.build()
File "/volume1/@appstore/py3k/usr/local/lib/python3.5/distutils/command/install_lib.py", line 107, in build
self.run_command('build_ext')
cmd_obj.run()
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/command/build_ext.py", line 84, in run
_build_ext.run(self)
File "/volume1/@appstore/py3k/usr/local/lib/python3.5/distutils/command/build_ext.py", line 338, in run
self.build_extensions()
File "/volume1/@appstore/py3k/usr/local/lib/python3.5/distutils/command/build_ext.py", line 447, in build_extensions
self._build_extensions_serial()
File "/volume1/@appstore/py3k/usr/local/lib/python3.5/distutils/command/build_ext.py", line 472, in _build_extensions_serial
self.build_extension(ext)
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/command/build_ext.py", line 205, in build_extension
_build_ext.build_extension(self, ext)
File "/volume1/@appstore/py3k/usr/local/lib/python3.5/distutils/command/build_ext.py", line 532, in build_extension
depends=ext.depends)
File "/volume1/@appstore/py3k/usr/local/lib/python3.5/distutils/ccompiler.py", line 574, in compile
self._compile(obj, src, ext, cc_args, extra_postargs, pp_opts)
File "/volume1/@appstore/py3k/usr/local/lib/python3.5/distutils/unixccompiler.py", line 118, in _compile
raise CompileError(msg)
distutils.errors.CompileError: command '/opt/bin/gcc' failed with exit status 1
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/sandbox.py", line 154, in save_modules
yield saved
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/sandbox.py", line 195, in setup_context
yield
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/sandbox.py", line 250, in run_setup
_execfile(setup_script, ns)
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/sandbox.py", line 45, in _execfile
exec(code, globals, locals)
File "/tmp/easy_install-zqqkwv_e/Cython-0.29.13/setup.py", line 285, in <module>
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/__init__.py", line 145, in setup
return distutils.core.setup(**attrs)
File "/volume1/@appstore/py3k/usr/local/lib/python3.5/distutils/core.py", line 163, in setup
raise SystemExit("error: " + str(msg))
SystemExit: error: command '/opt/bin/gcc' failed with exit status 1
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/command/easy_install.py", line 1144, in run_setup
run_setup(setup_script, args)
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/sandbox.py", line 253, in run_setup
raise
File "/volume1/@appstore/py3k/usr/local/lib/python3.5/contextlib.py", line 77, in __exit__
self.gen.throw(type, value, traceback)
yield
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/sandbox.py", line 166, in save_modules
saved_exc.resume()
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/sandbox.py", line 141, in resume
six.reraise(type, exc, self._tb)
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/_vendor/six.py", line 685, in reraise
raise value.with_traceback(tb)
yield saved
yield
File "setup.py", line 15, in <module>
scripts=[],
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/__init__.py", line 144, in setup
_install_setup_requires(attrs)
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/__init__.py", line 139, in _install_setup_requires
dist.fetch_build_eggs(dist.setup_requires)
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/dist.py", line 719, in fetch_build_eggs
replace_conflicting=True,
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/pkg_resources/__init__.py", line 782, in resolve
replace_conflicting=replace_conflicting
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/pkg_resources/__init__.py", line 1065, in best_match
return self.obtain(req, installer)
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/pkg_resources/__init__.py", line 1077, in obtain
return installer(requirement)
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/dist.py", line 786, in fetch_build_egg
return cmd.easy_install(req)
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/command/easy_install.py", line 679, in easy_install
return self.install_item(spec, dist.location, tmpdir, deps)
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/command/easy_install.py", line 705, in install_item
dists = self.install_eggs(spec, download, tmpdir)
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/command/easy_install.py", line 890, in install_eggs
return self.build_and_install(setup_script, setup_base)
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/command/easy_install.py", line 1158, in build_and_install
self.run_setup(setup_script, setup_base, args)
File "/volume1/@appstore/domoticz/plugins/IKEA-Tradfri/env/lib/python3.5/site-packages/setuptools/command/easy_install.py", line 1146, in run_setup
raise DistutilsError("Setup script exited with %s" % (v.args[0],))
distutils.errors.DistutilsError: Setup script exited with error: command '/opt/bin/gcc' failed with exit status 1The "workaround"; 'pip3 install -r requirements.txt'
Doesn't solve it either, failing with its own errors:
(env) root@DiskStation:/volume1/@appstore/domoticz/plugins/IKEA-Tradfri# pip3 install -r requirements.txt
Collecting aiocoap==0.4a1 (from -r requirements.txt (line 1))
Using cached https://files.pythonhosted.org/packages/19/7e/a407d251bb570b903b162f454760992a3c59cc1b81fe9a087e8cb4cc9eb8/aiocoap-0.4a1.tar.gz
Collecting aiohttp==4.0.0a0 (from -r requirements.txt (line 2))
ERROR: Could not find a version that satisfies the requirement aiohttp==4.0.0a0 (from -r requirements.txt (line 2)) (from versions: 0.1, 0.2, 0.3, 0.4, 0.4.1, 0.4.2, 0.4.3, 0.4.4, 0.5.0, 0.6.0, 0.6.1, 0.6.2, 0.6.3, 0.6.4, 0.6.5, 0.7.0, 0.7.1, 0.7.2, 0.7.3, 0.8.0, 0.8.1, 0.8.2, 0.8.3, 0.8.4, 0.9.0, 0.9.1, 0.9.2, 0.9.3, 0.10.0, 0.10.1, 0.10.2, 0.11.0, 0.12.0, 0.13.0, 0.13.1, 0.14.0, 0.14.1, 0.14.2, 0.14.3, 0.14.4, 0.15.0, 0.15.1, 0.15.2, 0.15.3, 0.16.0, 0.16.1, 0.16.2, 0.16.3, 0.16.4, 0.16.5, 0.16.6, 0.17.0, 0.17.1, 0.17.2, 0.17.3, 0.17.4, 0.18.0, 0.18.1, 0.18.2, 0.18.3, 0.18.4, 0.19.0, 0.20.0, 0.20.1, 0.20.2, 0.21.0, 0.21.1, 0.21.2, 0.21.4, 0.21.5, 0.21.6, 0.22.0a0, 0.22.0b0, 0.22.0b1, 0.22.0b2, 0.22.0b3, 0.22.0b4, 0.22.0b5, 0.22.0b6, 0.22.0, 0.22.1, 0.22.2, 0.22.3, 0.22.4, 0.22.5, 1.0.0, 1.0.1, 1.0.2, 1.0.3, 1.0.5, 1.1.0, 1.1.1, 1.1.2, 1.1.3, 1.1.4, 1.1.5, 1.1.6, 1.2.0, 1.3.0, 1.3.1, 1.3.2, 1.3.3, 1.3.4, 1.3.5, 2.0.0rc1, 2.0.0, 2.0.1, 2.0.2, 2.0.3, 2.0.4, 2.0.5, 2.0.6.post1, 2.0.7, 2.1.0, 2.2.0, 2.2.1, 2.2.2, 2.2.3, 2.2.4, 2.2.5, 2.3.0a4, 2.3.0, 2.3.1, 2.3.2b2, 2.3.2b3, 2.3.2, 2.3.3, 2.3.4, 2.3.5, 2.3.6, 2.3.7, 2.3.8, 2.3.9, 2.3.10, 3.0.0b0)
ERROR: No matching distribution found for aiohttp==4.0.0a0 (from -r requirements.txt (line 2))Can anyone please help with a description on how to get the Tradfri plugin to work on Synology?
I'm using a DS116 with DSM 6.2.2-24922 Update 3 and run Jamahl's Domoticz version 4.9700.
