How to use a Trigger ID?
Posted: Monday 23 September 2019 13:38
by Marcjeok
I'm new to dzvents and scripting in general. In other words, I'm a real NOOB in scripting :oops:. But I like to learn to create scripts in dzvents, because is has some real potential ;) . I received some scripts from colleagues and try to recreate a script based on their examples. I'm trying to write a script to turn on the stairs lights when motion is detected and turn them off after a short period. I would like to use multiple triggers in the script and based on the trigger execute a command. In the example I've received, he uses the command 'if (trigger.id == IDSM) then' (this works on his Domoticz :? ). However, it doesn't work in my script. Can somebody help me with this?
The code I made so far (not finished yet)
SCRIPT DESCRIPTION:
This script turns the stairs lights on or off when there is motion and it's dark.
The lights will be turned off automatically after a period off time.
DEVICES USED:
Idx 67 = Trap sensor - Burglar
Idx 75 = Trapverlichting - Switch
Idx 22 = Daglicht
--SET USER INPUT VARIABLES:
IDSM = 67
IDSS = 75
IDDL = 22
SECSTOFF = 60   --turn off the stairs lights switch after xx seconds.
	active = true,
		devices = {
		    IDSM,
		    IDSS,
	execute = function(domoticz, triggeredItem, info)
        --SET VARIABLES:
        local STAIRSMOTION = domoticz.devices(IDSM)
        local STAIRSSWITCH = domoticz.devices(IDSS)
        local DAYLIGHTSWITCH = domoticz.devices(IDDL)
        -- EXECUTE SCRIPT
            domoticz.log('Stairs: There is motion in the dark, let me turn on the lights for you')
            STAIRSSWITCH.switchOn()
My log is showing the following:
2019-09-23 13:22:52.995 Status: dzVents: Info: Handling events for: "Trap sensor - Burglar", value: "On"
2019-09-23 13:22:52.995 Status: dzVents: Info: ------ Start internal script: Lights stairs: Device: "Trap sensor - Burglar (zwave)", Index: 67
2019-09-23 13:22:52.998 Status: dzVents: Info: ------ Finished Lights stairs
I'm running the latest version of domoticz:
Version: 4.11333
Build Hash: b2a5d9097
Compile Date: 2019-09-20 16:31:36
dzVents Version: 2.4.29
Python Version: 3.4.2 (default, Aug 18 2019, 00:35:45) [GCC 4.9.2]
Thanks in advance!
Re: How to use a Trigger ID?
Posted: Monday 23 September 2019 23:23
by waaren
Marcjeok wrote: Monday 23 September 2019 13:38 However, it doesn't work in my script. Can somebody help me with this?
You named the 2nd parm in the execute function triggeredItem but try to refer to it by using trigger.
You should change it to
	execute = function(domoticz, trigger, info)
or
        if (triggeredItem.id == IDSM) then
Re: How to use a Trigger ID?  [Solved]
Posted: Tuesday 24 September 2019 18:28
by Marcjeok
So simple, so effective.
Many thanks for your help and explanation.
Posted: Monday 30 September 2019 8:09
by Marcjeok
For me, it always helps to see scripts that works fine. So just for sharing, hereby the script I made to control the lights on my stairs.
SCRIPT DESCRIPTION:
This script turns the stairs lights on or off when there is motion and it's dark (sunset).
DEVICES USED:
Idx 67 = Stairs Motion sensor (Philio Technology Corp PST02-B PIR/Motion 3 in 1 Sensor+)
Idx 75 = Stairs Switch (FIBARO System FGWPE/F Wall Plug Gen5+)
local IDSM = 67
local IDSS = 75
local SECSTOFF = 60   --turn off the stairs lights switch after xx seconds.
	active = true,
		devices = {
		    IDSM,
		    IDSS,
        --SET VARIABLES:
        -- EXECUTE SCRIPT
        if (triggeredItem.id == IDSM) and (domoticz.time.isNightTime) and (STAIRSSWITCH.state == "Off") then
        elseif (triggeredItem.id == IDSM) and (domoticz.time.isNightTime) and (STAIRSSWITCH.state == "On") then
            domoticz.log('Stairs: Reset timer, turn off the lights in '..SECSTOFF..' seconds')
            STAIRSSWITCH.cancelQueuedCommands()
            STAIRSSWITCH.switchOff().afterSec(SECSTOFF)
        elseif (triggeredItem.id == IDSS) and (STAIRSSWITCH.state == "On") then
            domoticz.log('Stairs: Turn off the lights in '..SECSTOFF..' seconds')
07-10-2019: updated script
