Problems with 2 events SOLVED and the log-file NOT Topic is solved
KroontjesPen
Domoticz version: 4.10717
Post by KroontjesPen »
Version: V4.10717 b386b49e5
Platform: Windows 10
RFXtrs433E, Z-Stick Gen 5
1) Event Bel: start without the normal activation by the push-button.
2) Event Kamer Raamzijde Aan: starts 30 minutes to early. (Room Window-side on) Solved by waaren. Leading 0 for time 6:30 missing.
3) After I set event Bel off all the event notes in the log-file where gone.
Comments are in the log-file after --
For the first impression I put part of the log-file output above the pictures.
On 3: Lucky I had all the event notes already copied.
2019-09-21 06:25:10.293 (RFXCOM) Lighting 2 (Kamer Midden)
1)
2019-09-20 05:48:55.901 EventSystem: Event triggered: Bel_1
2019-09-20 05:48:55.985 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-20 05:49:25.973 (RFXCOM) Lighting 2 (Kamer Midden))
Later
2019-09-21 03:10:09.140 EventSystem: Event triggered: Bel_1
2019-09-21 03:25:09.123 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 03:25:09.125 EventSystem: Event triggered: Bel_1
2019-09-21 03:25:09.218 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 03:25:09.219 EventSystem: Event triggered: Bel_1
2019-09-21 03:30:11.594 (Zwave) Temp (Temperature)
2019-09-21 03:40:09.216 (RFXCOM) Lighting 2 (Kamer Midden)
2) Solved
2019-09-21 06:00:00.472 EventSystem: Event triggered: Kamer Raamzijde Aan_1
This is the one that's on time
2019-09-21 06:31:00.288 EventSystem: Event triggered: Tuin Aan. Ochtend_1
2019-09-20 00:00:00.296 Status: EventSystem: reset all events...
2019-09-20 00:00:01.323 Status: Schedule item started! Name: Kamer Keukenzijde, Type: On Time, DevID: 4, Time: 2019-09-20 00:00:01
2019-09-20 00:30:01.087 Status: Schedule item started! Name: Kamer Midden, Type: On Time, DevID: 5, Time: 2019-09-20 00:30:01
2019-09-20 01:00:01.535 Status: Schedule item started! Name: Keuken Midden, Type: On Time, DevID: 6, Time: 2019-09-20 01:00:01
2019-09-20 01:15:01.668 Status: Schedule item started! Name: Keuken Aanrecht, Type: On Time, DevID: 7, Time: 2019-09-20 01:15:01
2019-09-20 05:48:55.900 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-20 05:48:55.901 EventSystem: Event triggered: Bel_1						-- ┐ no activation of the bell
2019-09-20 05:48:55.985 (RFXCOM) Lighting 2 (Kamer Midden)						-- │ Light on
2019-09-20 05:49:25.973 (RFXCOM) Lighting 2 (Kamer Midden))						-- ┘ Light off   timer in event was then 0.5 seconden
2019-09-20 05:49:25.974 EventSystem: Event triggered: Bel_1						-- ┐
2019-09-20 05:49:26.115 (RFXCOM) Lighting 2 (Kamer Midden						-- │
2019-09-20 05:49:56.031 (RFXCOM) Lighting 2 (Kamer Midden)						-- ┘
2019-09-20 05:49:56.032 EventSystem: Event triggered: Bel_1
2019-09-20 05:49:56.157 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-20 05:50:26.109 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-20 05:50:26.110 EventSystem: Event triggered: Bel_1
2019-09-20 05:50:26.207 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-20 05:50:56.157 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-20 05:50:56.159 EventSystem: Event triggered: Bel_1
2019-09-20 05:58:57.218 EventSystem: Event triggered: Bel_1
2019-09-20 05:58:57.218 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-20 05:58:57.296 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-20 05:59:27.309 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-20 05:59:27.309 EventSystem: Event triggered: Bel_1
2019-09-20 05:59:27.386 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-20 05:59:57.436 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-20 05:59:57.439 EventSystem: Event triggered: Bel_1
2019-09-20 05:59:57.521 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-20 [b]06:00:00.262[/b] EventSystem: Event triggered: Kamer Raamzijde Aan_1		-- Blockly event: Time = 6:30 and Time < Sunrise
2019-09-20 06:00:00.335 (RFXCOM) Lighting 2 (Kamer Raamzijde)
2019-09-20 06:00:27.023 (RFXCOM) Lighting 2 (Kamer Keukenzijde)					-- by me
2019-09-20 06:00:27.482 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-20 06:00:27.482 EventSystem: Event triggered: Bel_1
2019-09-20 06:00:27.565 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-20 06:00:28.762 (RFXCOM) Lighting 2 (Keuken Aanrecht)
2019-09-20 06:00:57.519 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-20 06:00:57.520 EventSystem: Event triggered: Bel_1
2019-09-20 06:00:57.604 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-20 06:01:27.626 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 00:15:08.120 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 00:15:08.122 EventSystem: Event triggered: Bel_1						-- timer 10 minuten
2019-09-21 00:15:08.205 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 00:15:08.207 EventSystem: Event triggered: Bel_1
2019-09-21 00:15:20.838 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 00:15:20.795 Status: User: Admin initiated a switch command (5/Kamer Midden/On)  -- By me
2019-09-21 00:17:11.620 Status: EventSystem: reset all events...					-- timer 15 minutes
2019-09-21 00:25:08.221 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 00:25:08.222 EventSystem: Event triggered: Bel_1
2019-09-21 00:25:08.294 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 00:25:08.294 EventSystem: Event triggered: Bel_1
2019-09-21 00:26:08.266 Status: Incoming connection from: 127.0.0.1
2019-09-21 00:29:10.690 (Zwave) Temp (Temperature)
2019-09-21 00:30:01.840 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 00:30:01.843 EventSystem: Event triggered: Bel_1
2019-09-21 00:30:01.769 Status: Schedule item started! Name: Kamer Midden, Type: On Time, DevID: 5, Time: 2019-09-21 00:30:01
2019-09-21 02:55:09.030 EventSystem: Event triggered: Bel_1
2019-09-21 03:10:09.021 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 03:10:09.023 EventSystem: Event triggered: Bel_1
2019-09-21 03:10:09.138 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 03:10:09.140 EventSystem: Event triggered: Bel_1						--
2019-09-21 03:25:09.123 (RFXCOM) Lighting 2 (Kamer Midden)						--  on
2019-09-21 03:25:09.125 EventSystem: Event triggered: Bel_1						--
2019-09-21 03:25:09.218 (RFXCOM) Lighting 2 (Kamer Midden)						--  on
2019-09-21 03:25:09.219 EventSystem: Event triggered: Bel_1						--  ?
2019-09-21 03:40:09.216 (RFXCOM) Lighting 2 (Kamer Midden)						--  Light off because timer 10 minutes
2019-09-21 03:40:09.218 EventSystem: Event triggered: Bel_1
2019-09-21 03:40:09.319 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 03:40:09.320 EventSystem: Event triggered: Bel_1
2019-09-21 03:45:47.974 (Zwave) Lux (Lichtsensor LUX)
2019-09-21 03:55:09.302 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 03:55:09.304 EventSystem: Event triggered: Bel_1
2019-09-21 03:55:09.403 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 03:55:09.405 EventSystem: Event triggered: Bel_1
2019-09-21 04:10:09.365 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 04:10:09.366 EventSystem: Event triggered: Bel_1
2019-09-21 04:10:09.464 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 04:10:09.465 EventSystem: Event triggered: Bel_1
2019-09-21 04:14:33.466 (Zwave) Lux (Lichtsensor LUX)
2019-09-21 04:14:33.512 (Zwave) Lux (Lichtsensor LUX)
2019-09-21 04:14:33.559 (Zwave) Lux (Lichtsensor LUX)
2019-09-21 04:14:33.631 (Zwave) Light/Switch (Alarm Type)
2019-09-21 04:14:33.705 (Zwave) Light/Switch (Alarm Level)
2019-09-21 04:14:33.735 (Zwave) General/Alarm (Alarm Type: Burglar 7 (0x07))
2019-09-21 04:14:33.823 (Zwave) Light/Switch (Burglar)
2019-09-21 04:14:33.860 (Zwave) Light/Switch (General)
2019-09-21 04:25:09.459 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 04:25:09.460 EventSystem: Event triggered: Bel_1
2019-09-21 04:25:09.577 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 04:25:09.579 EventSystem: Event triggered: Bel_1
2019-09-21 04:30:32.014 (Zwave) Temp (Temperature)
2019-09-21 04:40:09.538 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 04:40:09.540 EventSystem: Event triggered: Bel_1
2019-09-21 04:40:09.611 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 04:40:09.611 EventSystem: Event triggered: Bel_1
2019-09-21 04:46:08.659 (Zwave) Lux (Lichtsensor LUX)
2019-09-21 04:55:09.615 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 04:55:09.617 EventSystem: Event triggered: Bel_1
2019-09-21 04:55:09.703 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 04:55:09.704 EventSystem: Event triggered: Bel_1
2019-09-21 05:10:09.722 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 05:10:09.724 EventSystem: Event triggered: Bel_1
2019-09-21 05:10:09.811 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 05:10:09.812 EventSystem: Event triggered: Bel_1
2019-09-21 05:25:09.851 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 05:25:09.852 EventSystem: Event triggered: Bel_1
2019-09-21 05:25:09.918 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 05:25:09.919 EventSystem: Event triggered: Bel_1
2019-09-21 05:30:55.013 (Zwave) Temp (Temperature)
2019-09-21 05:40:09.903 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 05:40:09.904 EventSystem: Event triggered: Bel_1
2019-09-21 05:40:09.974 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 05:40:09.975 EventSystem: Event triggered: Bel_1
2019-09-21 05:46:32.563 (Zwave) Lux (Lichtsensor LUX)
2019-09-21 05:55:09.994 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 05:55:09.996 EventSystem: Event triggered: Bel_1
2019-09-21 05:55:10.145 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 05:55:10.145 EventSystem: Event triggered: Bel_1
2019-09-21 06:00:00.472 EventSystem: Event triggered: Kamer Raamzijde Aan_1		-- Blockly event: Time = 6:30 and Time < Sunrise
2019-09-21 06:00:00.586 (RFXCOM) Lighting 2 (Kamer Raamzijde)
2019-09-21 06:10:10.093 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 06:10:10.094 EventSystem: Event triggered: Bel_1
2019-09-21 06:10:10.232 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 06:10:10.233 EventSystem: Event triggered: Bel_1
2019-09-21 06:15:20.381 (Zwave) Lux (Lichtsensor LUX)
2019-09-21 06:15:20.428 (Zwave) Lux (Lichtsensor LUX)
2019-09-21 06:15:20.473 (Zwave) Lux (Lichtsensor LUX)
2019-09-21 06:15:20.534 (Zwave) Light/Switch (Alarm Type)
2019-09-21 06:15:20.584 (Zwave) Light/Switch (Alarm Level)
2019-09-21 06:15:20.615 (Zwave) General/Alarm (Alarm Type: Burglar 7 (0x07))
2019-09-21 06:15:20.664 (Zwave) Light/Switch (Burglar)
2019-09-21 06:15:20.713 (Zwave) Light/Switch (General)
2019-09-21 06:25:10.179 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 06:25:10.181 EventSystem: Event triggered: Bel_1
2019-09-21 06:25:10.293 (RFXCOM) Lighting 2 (Kamer Midden)						-- First line after stop Blockly event Bel, all above gone
2019-09-21 06:25:10.296 EventSystem: Event triggered: Bel_1
2019-09-21 06:31:00.288 EventSystem: Event triggered: Tuin Aan. Ochtend_1			-- Blockly event: Time = 6:31 and Time < Sunrise and DLS Buiten 2 Aan   worked on time. (DummyLightCensor outside 2 on)
2019-09-21 06:31:00.436 (RFXCOM) Lighting 2 (Tuin Noord II - 1)
2019-09-21 06:31:00.439 EventSystem: Event triggered: Tuin Oost Aan_1
2019-09-21 06:31:00.569 (RFXCOM) Lighting 2 (Tuin Oost II - 2)
2019-09-21 06:31:10.409 (RFXCOM) Lighting 2 (Tuin Noord II - 1)
2019-09-21 06:31:10.410 EventSystem: Event triggered: Tuin Oost Aan_1
2019-09-21 06:31:10.523 (RFXCOM) Lighting 2 (Tuin Oost II - 2)
2019-09-21 06:31:19.083 (Zwave) Temp (Temperature)
2019-09-21 06:40:10.260 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 06:40:10.261 EventSystem: Event triggered: Bel_1
2019-09-21 06:40:10.390 (RFXCOM) Lighting 2 (Kamer Midden)
2019-09-21 06:40:10.391 EventSystem: Event triggered: Bel_1
2019-09-21 06:44:47.696 (RFXCOM) Lighting 2 (Keuken Aanrecht)
2019-09-21 06:44:48.485 (RFXCOM) Lighting 2 (Kamer Keukenzijde)
2019-09-21 06:46:55.614 (Zwave) Lux (Lichtsensor LUX)
-- Putting Motion Censor in box and in aluminum foil
2019-09-22 06:00:00.344 EventSystem: Event triggered: Kamer Raamzijde Aan_1		-- Blockly event: Time = 6:30 and Time < Sunrise
2019-09-22 06:00:00.420 (RFXCOM) Lighting 2 (Kamer Raamzijde)
In the log-file I have set remarks after --
Last edited by KroontjesPen on Monday 23 September 2019 16:06, edited 2 times in total.
Bear with me, English is not my native language.
KroontjesPen
Re: Problems with 2 evens and the log-file
Because I don't for now to use the Attachment method so I take the code block.
1) Bel
<xml xmlns="http://www.w3.org/1999/xhtml"><block type="domoticzcontrols_if" id="G`^5~tY|)1|d#L6XWBf[" x="-607" y="-48"><value name="IF0"><block type="logic_operation" id="u8Vu,_Lw98YF,E,xDh{k" inline="false"><field name="OP">AND</field><value name="A"><block type="logic_compare" id="rLF0al0[|TIkNd;M5xh="><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id="?!1$n?G7K**B.RBc}S8w"><field name="Switch">46</field></block></value><value name="B"><block type="logic_states" id="$3-uW%ld4|#GBo5vlVI_"><field name="State">Chime</field></block></value></block></value><value name="B"><block type="logic_compare" id="-wVCtBZEhVXEMVW:U.~k"><field name="OP">EQ</field><value name="A"><block type="switchvariablesGL" id="le-px-T7iDU=BlQnN]ge"><field name="Switch">5</field></block></value><value name="B"><block type="logic_states" id="Le:4VBfkAdJDSxx_pyz,"><field name="State">Off</field></block></value></block></value></block></value><statement name="DO0"><block type="logic_setdelayed" id="4D.2cbi}sceedw]iRXM~"><value name="A"><block type="switchvariablesGL" id="$D5ZU%/WZs%*FJk`|F?T"><field name="Switch">5</field></block></value><value name="B"><block type="logic_states" id="@m442;2hsMKw*u]vVP{2"><field name="State">On</field></block></value><value name="C"><block type="logic_timevalue" id="+}X#5d?2}$VTqN2gVUCl"><field name="TEXT">.5</field></block></value></block></statement></block></xml>
2) Kamer Raamzijde Aan Solved
<xml xmlns="http://www.w3.org/1999/xhtml"><block type="domoticzcontrols_if" id="g)[OzRYTk:$d,iS-c@^u" x="-66" y="-4"><value name="IF0"><block type="logic_operation" id="CpYvzuCEbq2C[(~Ww_{|" inline="false"><field name="OP">AND</field><value name="A"><block type="logic_timeofday" id="7{lECtz_7gh.$D%;BDt^"><field name="OP">EQ</field><value name="Time"><block type="logic_timevalue" id="msA^)FfSs}lZ%|XXH[Y*"><field name="TEXT">6:30</field></block></value></block></value><value name="B"><block type="logic_timeofday" id="o:IA2gqDKDl:P?!P2]*B"><field name="OP">LT</field><value name="Time"><block type="logic_sunrisesunset" id="}ipq2Eja;;_kt(#qD/Z1"><field name="SunriseSunset">Sunrise</field></block></value></block></value></block></value><statement name="DO0"><block type="logic_set" id="(rPoeUnkNkeTNxIV~vgj"><value name="A"><block type="switchvariablesGL" id="8gB_]lZ2hDrWh^%p%lSz"><field name="Switch">3</field></block></value><value name="B"><block type="logic_states" id="#ip$O/;e)gn8G{_|C8?Q"><field name="State">On</field></block></value></block></statement></block></xml>
3) Tuin Aan. Ochtend
<xml xmlns="http://www.w3.org/1999/xhtml"><block type="domoticzcontrols_if" id="kpO{e:VTl)wbO9$LX8ae" x="-119" y="-21"><value name="IF0"><block type="logic_operation" id="xv2?J1G@(:MO0bjbt@g}" inline="false"><field name="OP">AND</field><value name="A"><block type="logic_timeofday" id="xlk[Q%1YQHHQEKp1kot{"><field name="OP">EQ</field><value name="Time"><block type="logic_timevalue" id="C_2|c!sDn|g.Xv_!ttcg"><field name="TEXT">06:31</field></block></value></block></value><value name="B"><block type="logic_operation" id="Ce,I~S`g(}:#1~/U9lUH" inline="false"><field name="OP">AND</field><value name="A"><block type="logic_timeofday" id="kN.TxtmBMq:0q^uPXunN"><field name="OP">LT</field><value name="Time"><block type="logic_sunrisesunset" id="D=t3[:|#yX+Jm[s[/|Oj"><field name="SunriseSunset">Sunrise</field></block></value></block></value><value name="B"><block type="logic_compare" id="oTA?WzEX)8h;hT2*yBnP"><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id="{g^#*3Y$$JJHx;O)B`#_"><field name="Switch">50</field></block></value><value name="B"><block type="logic_states" id="dBmbH@bkv=^U2~#[_`kd"><field name="State">On</field></block></value></block></value></block></value></block></value><statement name="DO0"><block type="logic_set" id="%]yG74kh;!],OTfo0Y8f"><value name="A"><block type="switchvariablesSZ" id="9pdl`RjEwuNs,At0r5Lr"><field name="Switch">11</field></block></value><value name="B"><block type="logic_states" id="d%0i8Z*lgd/Wym7X,G^l"><field name="State">On</field></block></value><next><block type="logic_setafter" id="oH085bQ`YuuTcfLv4;2f"><value name="A"><block type="switchvariablesSZ" id="!zweg*ojkm#jv`rVq,A:"><field name="Switch">9</field></block></value><value name="B"><block type="logic_states" id="K|}ovt(-WQI%`RT`9_Rk"><field name="State">On</field></block></value><value name="C"><block type="logic_timevalue" id="ipC4AZ-M$lVa:A*R9REd"><field name="TEXT">5</field></block></value><next><block type="logic_setafter" id="}VRJ`bhD{k9{Z=uh?kh$"><value name="A"><block type="switchvariablesSZ" id="We)D;o,=@9:1#WP]K,W!"><field name="Switch">11</field></block></value><value name="B"><block type="logic_states" id="UNb_6,jh[u?.1B%uzP9X"><field name="State">On</field></block></value><value name="C"><block type="logic_timevalue" id="G9-SJW?VJ[4{dS!QdEva"><field name="TEXT">10</field></block></value><next><block type="logic_setafter" id="ZM[R{VHlY{g/xr3|;(a~"><value name="A"><block type="switchvariablesSZ" id="Ln#kT{~12TOv?55!U/(S"><field name="Switch">9</field></block></value><value name="B"><block type="logic_states" id="Wlog+/z[HC(T45}CN0@0"><field name="State">On</field></block></value><value name="C"><block type="logic_timevalue" id="GU{IhT=b_opG,%_T*%eX"><field name="TEXT">15</field></block></value></block></next></block></next></block></next></block></statement></block></xml>
Last edited by KroontjesPen on Monday 23 September 2019 8:20, edited 1 time in total.
KroontjesPen wrote: Sunday 22 September 2019 8:44 2) Event Kamer Raamzijde Aan: starts 30 minutes to early. (Room Window-side on)
Please have a look at this post where you will find that in the domoticz version you use entering the time without a leading zero wil result in the Blockly executing at the wrong time.
Bug is fixed but until you switch to a newer version enter times with a leading zero when time < 10:00
KroontjesPen
Re: Problems with 2 events and the log-file
Thanks for you answer waaren, for problem 2) wrong starting time event.
Try to check it on 07:30 was just too late because of the sunrise time 07:28 :)
Problem 1) an event that started on his own on a variable times, is a very tricky one.
KroontjesPen wrote: Monday 23 September 2019 7:37 Thanks for you answer waaren, for problem 2) wrong starting time event.
Don't know the AND block you use but can you try
<xml xmlns="http://www.w3.org/1999/xhtml"><block type="domoticzcontrols_if" id="yuhoO))ktUPp|/Ix5EQC" x="-568" y="-8"><value name="IF0"><block type="logic_operation" id="E58cdTQKw-Ytda=c}5dl"><field name="OP">AND</field><value name="A"><block type="logic_compare" id="rLF0al0[|TIkNd;M5xh="><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id="?!1$n?G7K**B.RBc}S8w"><field name="Switch">46</field></block></value><value name="B"><block type="logic_states" id="$3-uW%ld4|#GBo5vlVI_"><field name="State">Chime</field></block></value></block></value><value name="B"><block type="logic_compare" id="-wVCtBZEhVXEMVW:U.~k"><field name="OP">EQ</field><value name="A"><block type="switchvariablesGL" id="le-px-T7iDU=BlQnN]ge"><field name="Switch">5</field></block></value><value name="B"><block type="logic_states" id="Le:4VBfkAdJDSxx_pyz,"><field name="State">Off</field></block></value></block></value></block></value><statement name="DO0"><block type="logic_setdelayed" id="4D.2cbi}sceedw]iRXM~"><value name="A"><block type="switchvariablesGL" id="$D5ZU%/WZs%*FJk`|F?T"><field name="Switch">5</field></block></value><value name="B"><block type="logic_states" id="@m442;2hsMKw*u]vVP{2"><field name="State">On</field></block></value><value name="C"><block type="logic_timevalue" id="+}X#5d?2}$VTqN2gVUCl"><field name="TEXT">.5</field></block></value></block></statement></block></xml>
KroontjesPen
If you have change something on that script I can't see it in Blockly.
It was a simple test.
That lamp I don't use it often but when I have to then I don't want it to switch off when the doorbell is activated.
KroontjesPen
Re: Problems with 0 events and the log-file
1)Solved
When the lamp IS ON then it's NOT switched off, but the time on the icon under the LightSwitches tap is WELL UPDATED by this event.
So only the log-file problem is over.
KroontjesPen wrote: Monday 23 September 2019 16:04 So only the log-file problem is over.
from you description I don't understand what the problem is. Maybe if you rephrase the problem description, I would be able to help.
KroontjesPen
Re: Problems with 2 events SOLVED and the log-file NOT
When I switched the Bel event to off (uit) all the log data of that event was gone.
Because I had first set the off timer up to 30 minutes so it was not that disturbing.
Later I decided, for a kind of safety, to switched it off.
