How to integrate this power measurement sensor in Domoticz?
Posted: Monday 16 September 2019 8:47
by acaonweb
i've found this project
https://github.com/alcar21/WemosEM
and i can't understand if possible to integrate it into domoticz, because looking screenshots, i understand MQTT is supported but i can't see any idx field to fill, so i can't understand the way to use it in Domoticz.
Any expert could explain more?
Thanx in advance
Fabrizio
Re: How to integrate this power measurement sensor in Domoticz?
Posted: Monday 16 September 2019 10:19
by mvzut
I don't know this project, you can probably get it to work but it doesn't seem to be developed with Domoticz in mind, so it will probably involve extra work to integrate it.
Alternatively, you can have a look at this project:
https://www.letscontrolit.com/wiki/index.php/ESPEasy
Also uses ESP8266 modules, and integration in Domoticz is flawless! I am using this for a few sensors, for instance a water meter.
Posted: Monday 16 September 2019 10:41
by emme
espeasy will format the telegram for domoticz already...
I think that's the best choice
Posted: Monday 16 September 2019 11:32
by LouiS22
acaonweb wrote: Monday 16 September 2019 8:47
Thanx in advance
Fabrizio
Why don't you simply buy a shelly EM? It contains everything you need and it also supports Domoticz out of the box via MQTT (and a python plugin).
Posted: Monday 30 September 2019 16:43
by acaonweb
well, i have a bunch of wemos to use
Posted: Monday 30 September 2019 16:45
by acaonweb
emme wrote: Monday 16 September 2019 10:41
yes, but i'd like to understand how measure power
Posted: Monday 30 September 2019 17:03
by emme
the best way to do that is using a line analyzer with modbus
I'm succesfully using a Eastron SDM120C and I'm pretty happy with it!
The meter is connected to a ESPEASY Mega (nodeMCU 4Mb) linked to my WiFi and then to domoticz.
