Greetings!
I ran into an interesting problem within Domoticz.
By default, there is a kitchen counter light controlled by an RF relay controlled by an RF link.
Normal pre-counter lighting goes from a Sonoff T1 Eu to Tasmota (6.6.0).
The problem is the following is the ON action when Sonoff is turned on: http: //192.168.xx.xx: 8080 / json.htm? Type = command & param = switchlight & idx = 116 & switchcmd = On
Whatever you do, if I set the switch in Domoticz. (Turns on kitchen counter light via RF link)
However, if I use the physical switch to turn on the Sonoff T1, even if it changes its status in Domoticz, it will not execute the ON action.
What makes this possible?
On action execution error!
