Page 1 of 2
Help for dimming time script
Posted: Tuesday 10 September 2019 19:13
by djksage
hello,
I need some help to make dzvents script,
Between 21:30 to 06:30, when i press my switch, i would like light to 20%, other time at 100%
my first tink is, make dimTo(20) with a order swtichOff directly to setup level at 20% and when i press my switch, light is dimming to 20%
but not work, if i press my switch, light is always 100% ( or last manual state )
i read the wiki, and find maybee a solution quietOn/quietOff,
but when i use quietOn i have always a error
attempt to call field 'quieton' (a nil value)
can i use quietOn with a level or dimTo fonction?
sorry,i'm not good to make script for my test i make this :
timer = {
'at 16:53'
execute = function(domoticz, timer)
domoticz.log('Script Run')
domoticz.devices('SDB').quietOn.().dimTo(20)
domoticz.devices('SDB').switchOff()
thanks for your help
Re: Help for dimming time script
Posted: Tuesday 10 September 2019 20:22
by waaren
djksage wrote: Tuesday 10 September 2019 19:13
I need some help to make dzVents script,
Couple of questions.
- What is the name of your switch ?
- Should the script also switch the light Off and by the same switch or should it switch off after a certain time ?
- If the light is on at 21:30 or at 06:30 should it change dimlevel ?
Posted: Tuesday 10 September 2019 21:27
by djksage
the name is SDB but finaly is for 3 switch (bathroom, hall, my room)
script need only setup dimming value (20%) for turn On/Off/dimming is only manualy on pushing my switch buton.
Yes is the best solution but if it is too hard isn't matter, is only for use 5 or 10 min max (time to go on bathroom and go back on my bed)
Posted: Tuesday 10 September 2019 22:41
by waaren
djksage wrote: Tuesday 10 September 2019 21:27
Guess I mis something. switchname is SDB, What is the name of the dimmable light ?
Posted: Tuesday 10 September 2019 23:10
by djksage
hello,
my light name is SDB
sorry, my mistake, i use a qubino ZMNHSD1, my switch buton is connected directly on qubino so i don't have a switch declared on DZ to turn on my light
Posted: Wednesday 11 September 2019 0:16
by waaren
djksage wrote: Tuesday 10 September 2019 23:10
Hopefully domoticz will see the light switching. If not I don't know how to do what you described.
Can you try this ?
return
on =
devices = { 'SDB' },
logging =
level = domoticz.LOG_DEBUG,
marker = 'dim based on time'
execute = function(dz, item)
if item.active then
if dz.time.matchesRule('at 06:30-21:30') then
item.dimTo(100).silent()
item.dimTo(20).silent()
Posted: Wednesday 11 September 2019 20:04
by djksage
hello,
with your script, i can't turn off my light, but timing work fine
so :
-if light is off @ 21:28, if i turn on => light is 100% and i can't turn off (tested with switch, app and web gui) @ 21:30 DZ dimto 20% without possibility to turn off
-if light is off @ 21:32 (and last state is 100%) and i turn on => light is dim to 20% directly but always without possibility to turn off, i turn off this script for full control my light
Posted: Wednesday 11 September 2019 20:15
by waaren
djksage wrote: Wednesday 11 September 2019 20:04
can you please try this one and show what's in the domoticz log when switching and when switching off ?
return
on =
logging =
dz.log('SDB state' .. item.state,dz.LOG_DEBUG)
if item.active then
Posted: Wednesday 11 September 2019 21:12
by djksage
i make this test with my kitchen light (lumière cuisine)
Turn On
2019-09-11 21:04:01.742 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-09-11 21:04:01.954 Status: dzVents: Info: Handling events for: "Lumiere Cuisine", value: "On"
2019-09-11 21:04:01.954 Status: dzVents: Info: dim based on time: ------ Start internal script: testdim: Device: "Lumiere Cuisine (Clé USB ZWAVE+)", Index: 256
2019-09-11 21:04:01.955 Status: dzVents: Debug: dim based on time: Lumiere Cuisine stateOn
2019-09-11 21:04:01.956 Status: dzVents: Debug: dim based on time: Constructed timed-command: Set Level 20
2019-09-11 21:04:01.956 Status: dzVents: Debug: dim based on time: Constructed timed-command: Set Level 20 NOTRIGGER
2019-09-11 21:04:01.957 Status: dzVents: Info: dim based on time: ------ Finished testdim
Turn Off
2019-09-11 21:10:40.237 Status: User: Admin initiated a switch command (256/Lumiere Cuisine/Off)
2019-09-11 21:10:40.459 Status: dzVents: Info: Handling events for: "Lumiere Cuisine", value: "Off"
2019-09-11 21:10:40.459 Status: dzVents: Info: dim based on time: ------ Start internal script: testdim: Device: "Lumiere Cuisine (Clé USB ZWAVE+)", Index: 256
2019-09-11 21:10:40.460 Status: dzVents: Debug: dim based on time: Lumiere Cuisine stateOff
2019-09-11 21:10:40.461 Status: dzVents: Info: dim based on time: ------ Finished testdim
2019-09-11 21:10:40.585 Status: dzVents: Info: Handling events for: "Lumiere Cuisine", value: "On"
2019-09-11 21:10:40.585 Status: dzVents: Info: dim based on time: ------ Start internal script: testdim: Device: "Lumiere Cuisine (Clé USB ZWAVE+)", Index: 256
2019-09-11 21:10:40.586 Status: dzVents: Debug: dim based on time: Lumiere Cuisine stateOn
2019-09-11 21:10:40.586 Status: dzVents: Debug: dim based on time: Constructed timed-command: Set Level 20
2019-09-11 21:10:40.586 Status: dzVents: Debug: dim based on time: Constructed timed-command: Set Level 20 NOTRIGGER
2019-09-11 21:10:40.587 Status: dzVents: Info: dim based on time: ------ Finished testdim
2019-09-11 21:10:40.589 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-09-11 21:10:40.705 Status: dzVents: Info: Handling events for: "Lumiere Cuisine", value: "Off"
2019-09-11 21:10:40.706 Status: dzVents: Info: dim based on time: ------ Start internal script: testdim: Device: "Lumiere Cuisine (Clé USB ZWAVE+)", Index: 256
2019-09-11 21:10:40.707 Status: dzVents: Debug: dim based on time: Lumiere Cuisine stateOff
2019-09-11 21:10:40.709 Status: dzVents: Info: dim based on time: ------ Finished testdim
2019-09-11 21:10:40.822 Status: dzVents: Info: Handling events for: "Lumiere Cuisine", value: "On"
2019-09-11 21:10:40.823 Status: dzVents: Info: dim based on time: ------ Start internal script: testdim: Device: "Lumiere Cuisine (Clé USB ZWAVE+)", Index: 256
2019-09-11 21:10:40.823 Status: dzVents: Debug: dim based on time: Lumiere Cuisine stateOn
2019-09-11 21:10:40.824 Status: dzVents: Debug: dim based on time: Constructed timed-command: Set Level 20
2019-09-11 21:10:40.824 Status: dzVents: Debug: dim based on time: Constructed timed-command: Set Level 20 NOTRIGGER
2019-09-11 21:10:40.825 Status: dzVents: Info: dim based on time: ------ Finished testdim
after 5 or 6 min to try to turn off is working (1 time only)
2019-09-11 21:06:33.382 Status: User: Admin initiated a switch command (256/Lumiere Cuisine/Off)
2019-09-11 21:06:33.682 Status: dzVents: Info: Handling events for: "Lumiere Cuisine", value: "Off"
2019-09-11 21:06:33.682 Status: dzVents: Info: dim based on time: ------ Start internal script: testdim: Device: "Lumiere Cuisine (Clé USB ZWAVE+)", Index: 256
2019-09-11 21:06:33.684 Status: dzVents: Debug: dim based on time: Lumiere Cuisine stateOff
2019-09-11 21:06:33.686 Status: dzVents: Info: dim based on time: ------ Finished testdim
Posted: Wednesday 11 September 2019 22:26
by waaren
djksage wrote: Wednesday 11 September 2019 21:12
Thx, think I understand a bit better what is happening now.
Can you try this one.
return
on =
logging =
dz.log('SDB state: ' .. item.state,dz.LOG_DEBUG)
if item.active then
item.dimTo(0).silent()
Posted: Thursday 12 September 2019 19:59
by djksage
hello
same problem, i can't turn off, light start to turn off but script switch light on
2019-09-12 19:55:11.521 (Clé USB ZWAVE+) Light/Switch (Lumiere Cuisine)
2019-09-12 19:55:11.702 OpenZWave: Domoticz has send a Switch command!, Level: 0, NodeID: 26 (0x1a)
2019-09-12 19:55:11.706 (Clé USB ZWAVE+) Usage (Cuisine)
2019-09-12 19:55:11.710 (Clé USB ZWAVE+) General/kWh (Cuisine kWh)
2019-09-12 19:55:11.715 (Clé USB ZWAVE+) Light/Switch (Lumiere Cuisine)
2019-09-12 19:55:11.807 (Clé USB ZWAVE+) Light/Switch (Lumiere Cuisine)
2019-09-12 19:55:11.957 OpenZWave: Domoticz has send a Switch command!, Level: 99, NodeID: 26 (0x1a)
2019-09-12 19:55:11.962 (Clé USB ZWAVE+) Light/Switch (Lumiere Cuisine)
2019-09-12 19:55:11.695 Status: dzVents: Info: Handling events for: "Lumiere Cuisine", value: "Off"
2019-09-12 19:55:11.695 Status: dzVents: Info: dim based on time: ------ Start internal script: testdim: Device: "Lumiere Cuisine (Clé USB ZWAVE+)", Index: 256
2019-09-12 19:55:11.696 Status: dzVents: Debug: dim based on time: Lumiere Cuisine state: Off
2019-09-12 19:55:11.696 Status: dzVents: Debug: dim based on time: Constructed timed-command: Set Level 0
2019-09-12 19:55:11.696 Status: dzVents: Debug: dim based on time: Constructed timed-command: Set Level 0 NOTRIGGER
2019-09-12 19:55:11.698 Status: dzVents: Info: dim based on time: ------ Finished testdim
2019-09-12 19:55:11.700 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-09-12 19:55:11.942 Status: dzVents: Info: Handling events for: "Lumiere Cuisine", value: "On"
2019-09-12 19:55:11.942 Status: dzVents: Info: dim based on time: ------ Start internal script: testdim: Device: "Lumiere Cuisine (Clé USB ZWAVE+)", Index: 256
2019-09-12 19:55:11.943 Status: dzVents: Debug: dim based on time: Lumiere Cuisine state: On
2019-09-12 19:55:11.944 Status: dzVents: Debug: dim based on time: Constructed timed-command: Set Level 100
2019-09-12 19:55:11.944 Status: dzVents: Debug: dim based on time: Constructed timed-command: Set Level 100 NOTRIGGER
2019-09-12 19:55:11.945 Status: dzVents: Info: dim based on time: ------ Finished testdim
2019-09-12 19:55:11.946 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
Posted: Thursday 12 September 2019 20:22
by waaren
djksage wrote: Thursday 12 September 2019 19:59
What I see in the log is that Zwave send two signals directly after each other. Only way to deal with that would be to build in a check to exclude actions directly after an earlier one.
Hopefully this will do it.
return
on =
logging =
if item.active and item.lastUpdate.secondsAgo > 4 then
elseif item.lastUpdate.secondsAgo > 4 then
Re: Help for dimming time script [Solved]
Posted: Thursday 12 September 2019 22:21
by djksage
IT'S work! turn on directly of good % and turn off also
thanks for your script !
i setup DZ for control my hall and bathroom, not in my room because i can't dim after power on, if i dim to 100% script go back on 20% quickly
Posted: Monday 27 April 2020 17:35
by djdevil
waaren wrote: Thursday 12 September 2019 20:22
return
on =
logging =
Hello Waaren I have been using this script for some time to dim my lights, but with the latest release 2020-04-26, the script no longer works, the problem thinks it is this part of code "and item.lastUpdate.secondsAgo> 4" because when I exclude it it works but then as you already know then you make me in loop, how can I do thanks!
Posted: Monday 27 April 2020 21:11
by waaren
djdevil wrote: Monday 27 April 2020 17:35
Can you show me the domoticzlog when you activate the SDB with this script and the with the modified one ?
What was the version you used before the latest one and where this script still worked ?
Posted: Tuesday 28 April 2020 11:02
by djdevil
waaren wrote: Monday 27 April 2020 21:11
Hello Waaren thx for reply, yes this the code that always work,
I noticed that with the latest version of domoticz, the update of the zwave devices is very fast in fact the script seems to work by lowering the control time of the last update to 0.1 but this sometimes messes up the whole network! do you know any other way to do what i need?
if item.active and item.lastUpdate.secondsAgo > 0.1 then
Posted: Tuesday 28 April 2020 14:43
by djdevil
Maybe that's the problem
https://github.com/domoticz/domoticz/issues/4112, in any case I can only downgrade Dzvents?
Posted: Tuesday 28 April 2020 15:09
by waaren
No that is not possible because of the close integration. Anyway the issue is in the domoticz core code. Not in the dzVents part.
Posted: Tuesday 28 April 2020 15:35
by djdevil
waaren wrote: Tuesday 28 April 2020 15:09
Can I do something for now or wait for the fix?
Posted: Tuesday 28 April 2020 15:41
by waaren
djdevil wrote: Tuesday 28 April 2020 15:35
Probably it is best to wait for a fix because when you downgrade to build 11865 you will have an incompatibel database.
