There is no group or scene
Gianni
Post by Gianni »
hello
after rebuild my system i try to get my scripts back to work.
The most is done but i have a problem with my scene's
I get this error
There is no group or scene with that name or id: test. If you just created the scene or group you may have to restart Domoticz to make it become visible to dzVents.
but they exist
I have restart my system within domoticz and putty but still got this error.
If i look in the dzvenst hardware tab there are no scenes only my devices
i would try to use the idx instead of the name but i notice that idx 1 en 2 exist in domoticz and controller?
Is this normal?
 2019-09-09 08:24:34.520 Status: User: Admin initiated a switch command (7/Alles_Uit_Living/On)
2019-09-09 08:24:34.613 Status: dzVents: Debug: Dumping domoticz data to /home/gianni/domoticz/scripts/dzVents/domoticzData.lua
2019-09-09 08:24:34.671 Status: dzVents: Debug: Processing device-adapter for Alles_Uit_Living: Switch device adapter
2019-09-09 08:24:34.671 Status: dzVents: Debug: dzVents version: 2.4.19
2019-09-09 08:24:34.671 Status: dzVents: Debug: Event triggers:
2019-09-09 08:24:34.671 Status: dzVents: Debug: - Device: Alles_Uit_Living
2019-09-09 08:24:34.696 Status: dzVents: Info: Handling events for: "Alles_Uit_Living", value: "On"
2019-09-09 08:24:34.697 Status: dzVents: Info: ------ Start internal script: Gaan_Slapen: Device: "Alles_Uit_Living (Controller)", Index: 7
2019-09-09 08:24:34.697 Status: dzVents: Error (2.4.19): There is no group or scene with that name or id: test. If you just created the scene or group you may have to restart Domoticz to make it become visible to dzVents.
2019-09-09 08:24:34.697 Status: dzVents: Error (2.4.19): An error occured when calling event handler Gaan_Slapen
2019-09-09 08:24:34.697 Status: dzVents: Error (2.4.19): ...moticz/scripts/dzVents/generated_scripts/Gaan_Slapen.lua:8: attempt to index a nil value
2019-09-09 08:24:34.697 Status: dzVents: Info: ------ Finished Gaan_Slapen
This is the script
                devices = {"Alles_Uit_Living"}}, -- Change to the name of the switch that you want to use for controlling the group
    execute = function(dz,item)
        local myScene = "test"              -- Change to the name of the group that you want to control
        if item.state == "On" then
            dz.groups(myScene).switchOff()
            item.switchOff().afterSec(3).silent()       -- Masterswitch will return to On state after 3 seconds without triggering any script
            dz.groups(myScene).switchOn()
Re: There is no group or scene
Gianni wrote: Monday 09 September 2019 8:33 I get this error
Can you try after changing dz.groups to dz.scenes in your script ?
Is this normal?
Yes. Groups and devices have both their own range of ID's starting with 1 (same for uservariables, cameras, scripts, etc )
Gianni
Post by Gianni »
hey Waaren
i try that already
The only difference is that the switch (alles uit living) is initiated and go on but not go off
 2019-09-09 08:56:57.698 Status: User: Admin initiated a switch command (7/Alles_Uit_Living/On)
2019-09-09 08:56:57.795 Status: dzVents: Debug: Dumping domoticz data to /home/gianni/domoticz/scripts/dzVents/domoticzData.lua
2019-09-09 08:56:57.840 Status: dzVents: Debug: Processing device-adapter for Alles_Uit_Living: Switch device adapter
2019-09-09 08:56:57.841 Status: dzVents: Debug: dzVents version: 2.4.19
2019-09-09 08:56:57.841 Status: dzVents: Debug: Event triggers:
2019-09-09 08:56:57.841 Status: dzVents: Debug: - Device: Alles_Uit_Living
2019-09-09 08:56:57.865 Status: dzVents: Info: Handling events for: "Alles_Uit_Living", value: "On"
2019-09-09 08:56:57.865 Status: dzVents: Info: ------ Start internal script: Gaan_Slapen: Device: "Alles_Uit_Living (Controller)", Index: 7
2019-09-09 08:56:57.865 Status: dzVents: Error (2.4.19): There is no group or scene with that name or id: test. If you just created the scene or group you may have to restart Domoticz to make it become visible to dzVents.
2019-09-09 08:56:57.865 Status: dzVents: Error (2.4.19): An error occured when calling event handler Gaan_Slapen
2019-09-09 08:56:57.865 Status: dzVents: Error (2.4.19): ...moticz/scripts/dzVents/generated_scripts/Gaan_Slapen.lua:8: attempt to index a nil value
2019-09-09 08:56:57.865 Status: dzVents: Info: ------ Finished Gaan_Slapen
these ar all the devices in the dzvents
how can i use then the idx instead of the name in a script if the idx can exist more time's?
Gianni wrote: Monday 09 September 2019 8:59 how can i use then the idx instead of the name in a script if the idx can exist more time's?
Because you never use it in isolation. dz.devices(1) is something else as dz.groups(1) or dz.variables(1)
Can you try this ?
        local myScene = 2              -- Change to the name of the group that you want to control
        dz.log('Name of dz.scenes(myScene): "' .. dz.scenes(myScene) .. '"',dz.LOG_FORCE )
            -- dz.scenes(myScene).switchOff()   -- You cannot switch a scene to Off, only groups and devices
            dz.scenes(myScene).switchOn()
Gianni
Post by Gianni »
 2019-09-09 10:45:12.311 Status: User: Admin initiated a switch command (7/Alles_Uit_Living/On)
2019-09-09 10:45:12.397 Status: dzVents: Debug: Dumping domoticz data to /home/gianni/domoticz/scripts/dzVents/domoticzData.lua
2019-09-09 10:45:12.470 Status: dzVents: Debug: Processing device-adapter for Alles_Uit_Living: Switch device adapter
2019-09-09 10:45:12.470 Status: dzVents: Debug: dzVents version: 2.4.19
2019-09-09 10:45:12.470 Status: dzVents: Debug: Event triggers:
2019-09-09 10:45:12.470 Status: dzVents: Debug: - Device: Alles_Uit_Living
2019-09-09 10:45:12.494 Status: dzVents: Info: Handling events for: "Alles_Uit_Living", value: "On"
2019-09-09 10:45:12.494 Status: dzVents: Info: ------ Start internal script: Gaan_Slapen: Device: "Alles_Uit_Living (Controller)", Index: 7
2019-09-09 10:45:12.495 Status: dzVents: Debug: Processing device-adapter for test: Scene device adapter
2019-09-09 10:45:12.495 Status: dzVents: Error (2.4.19): An error occured when calling event handler Gaan_Slapen
2019-09-09 10:45:12.495 Status: dzVents: Error (2.4.19): ...moticz/scripts/dzVents/generated_scripts/Gaan_Slapen.lua:8: attempt to concatenate a table value
2019-09-09 10:45:12.495 Status: dzVents: Info: ------ Finished Gaan_Slapen
Gianni wrote: Monday 09 September 2019 10:45 2019-09-09 10:45:12.495 Status: dzVents: Error (2.4.19): ...moticz/scripts/dzVents/generated_scripts/Gaan_Slapen.lua:8: attempt to concatenate a table value
My bad. forgot the .name attribute. The error does already reveal that there is an object. Bug fixed in code below.
        dz.log('Name of dz.scenes(myScene): "' .. dz.scenes(myScene).name .. '"',dz.LOG_FORCE )
Gianni
Post by Gianni »
made some progress
the switch(Alles_Uit_Living/) go on and off but the scene is not triggered
The light living will not go off
this is my testscene
 2019-09-09 11:47:47.597 Status: User: Admin initiated a switch command (7/Alles_Uit_Living/On)
2019-09-09 11:47:47.685 Status: dzVents: Debug: Dumping domoticz data to /home/gianni/domoticz/scripts/dzVents/domoticzData.lua
2019-09-09 11:47:47.747 Status: dzVents: Debug: Processing device-adapter for Alles_Uit_Living: Switch device adapter
2019-09-09 11:47:47.747 Status: dzVents: Debug: dzVents version: 2.4.19
2019-09-09 11:47:47.748 Status: dzVents: Debug: Event triggers:
2019-09-09 11:47:47.748 Status: dzVents: Debug: - Device: Alles_Uit_Living
2019-09-09 11:47:47.773 Status: dzVents: Info: Handling events for: "Alles_Uit_Living", value: "On"
2019-09-09 11:47:47.774 Status: dzVents: Info: ------ Start internal script: Gaan_Slapen: Device: "Alles_Uit_Living (Controller)", Index: 7
2019-09-09 11:47:47.774 Status: dzVents: Debug: Processing device-adapter for test: Scene device adapter
2019-09-09 11:47:47.774 Status: dzVents: !Info: Name of dz.scenes(myScene): "test"
2019-09-09 11:47:47.775 Status: dzVents: Debug: Constructed timed-command: Off
2019-09-09 11:47:47.775 Status: dzVents: Debug: Constructed timed-command: Off AFTER 3 SECONDS
2019-09-09 11:47:47.775 Status: dzVents: Debug: Constructed timed-command: Off AFTER 3 SECONDS NOTRIGGER
2019-09-09 11:47:47.775 Status: dzVents: Info: ------ Finished Gaan_Slapen
2019-09-09 11:47:47.775 Status: dzVents: Debug: Commands sent to Domoticz:
2019-09-09 11:47:47.775 Status: dzVents: Debug: - Alles_Uit_Living = Off AFTER 3 SECONDS NOTRIGGER
may i ask,are you a programmer irl of did you learn this all by yourself :-)
Gianni
Post by Gianni »
i think it's works now
I add this to th cocde
            dz.scenes(myScene).switchOn()-- You cannot switch a scene to Off, only groups and devices
log
 2019-09-09 12:18:26.055 Status: dzVents: Debug: Processing device-adapter for Alles_Uit_Living: Switch device adapter
2019-09-09 12:18:26.055 Status: dzVents: Debug: dzVents version: 2.4.19
2019-09-09 12:18:26.055 Status: dzVents: Debug: Event triggers:
2019-09-09 12:18:26.055 Status: dzVents: Debug: - Device: Alles_Uit_Living
2019-09-09 12:18:26.082 Status: dzVents: Info: Handling events for: "Alles_Uit_Living", value: "On"
2019-09-09 12:18:26.082 Status: dzVents: Info: ------ Start internal script: Gaan_Slapen: Device: "Alles_Uit_Living (Controller)", Index: 7
2019-09-09 12:18:26.082 Status: dzVents: Debug: Processing device-adapter for test: Scene device adapter
2019-09-09 12:18:26.083 Status: dzVents: !Info: Name of dz.scenes(myScene): "test"
2019-09-09 12:18:26.083 Status: dzVents: Debug: Constructed timed-command: On
2019-09-09 12:18:26.083 Status: dzVents: Debug: Constructed timed-command: Off
2019-09-09 12:18:26.083 Status: dzVents: Debug: Constructed timed-command: Off AFTER 3 SECONDS
2019-09-09 12:18:26.083 Status: dzVents: Debug: Constructed timed-command: Off AFTER 3 SECONDS NOTRIGGER
2019-09-09 12:18:26.083 Status: dzVents: Info: ------ Finished Gaan_Slapen
2019-09-09 12:18:26.083 Status: dzVents: Debug: Commands sent to Domoticz:
2019-09-09 12:18:26.083 Status: dzVents: Debug: - Scene:test = On
2019-09-09 12:18:26.083 Status: dzVents: Debug: - Alles_Uit_Living = Off AFTER 3 SECONDS NOTRIGGER
2019-09-09 12:18:26.083 Status: dzVents: Debug: =====================================================
2019-09-09 12:18:26.084 Status: EventSystem: Script event triggered: /home/gianni/domoticz/dzVents/runtime/dzVents.lua
2019-09-09 12:18:26.139 Status: dzVents: Debug: Dumping domoticz data to /home/gianni/domoticz/scripts/dzVents/domoticzData.lua
2019-09-09 12:18:26.182 Status: dzVents: Debug: Processing device-adapter for test: Scene device adapter
2019-09-09 12:18:26.183 Status: dzVents: Debug: dzVents version: 2.4.19
2019-09-09 12:18:26.183 Status: dzVents: Debug: Event triggers:
2019-09-09 12:18:26.183 Status: dzVents: Debug: - Scene: test
2019-09-09 12:18:26.209 Status: dzVents: Debug: Scene-event for: test value: On
2019-09-09 12:18:26.255 Status: dzVents: Debug: Dumping domoticz data to /home/gianni/domoticz/scripts/dzVents/domoticzData.lua
2019-09-09 12:18:26.296 Status: dzVents: Debug: Processing device-adapter for Licht_Living: Switch device adapter
2019-09-09 12:18:26.297 Status: dzVents: Debug: Processing device-adapter for Licht_Eetplaats: Switch device adapter
2019-09-09 12:18:26.297 Status: dzVents: Debug: dzVents version: 2.4.19
2019-09-09 12:18:26.297 Status: dzVents: Debug: Event triggers:
2019-09-09 12:18:26.297 Status: dzVents: Debug: - Device: Licht_Living
2019-09-09 12:18:26.297 Status: dzVents: Debug: - Device: Licht_Eetplaats
2019-09-09 12:18:26.324 Status: dzVents: Info: Handling events for: "Licht_Living", value: "Off"
2019-09-09 12:18:26.324 Status: dzVents: Info: ------ Start internal script: Wissel_Living: Device: "Licht_Living (Controller)", Index: 6
2019-09-09 12:18:26.326 Status: dzVents: Debug: Processing device-adapter for Wissel_Living: Switch device adapter
2019-09-09 12:18:26.326 Status: dzVents: Debug: Constructed timed-command: Off
2019-09-09 12:18:26.326 Status: dzVents: Debug: Constructed timed-command: Off NOTRIGGER
2019-09-09 12:18:26.326 Status: dzVents: Info: ------ Finished Wissel_Living
2019-09-09 12:18:26.326 Status: dzVents: Debug: Commands sent to Domoticz:
2019-09-09 12:18:26.326 Status: dzVents: Debug: - Wissel_Living = Off NOTRIGGER
2019-09-09 12:18:26.326 Status: dzVents: Debug: =====================================================
Gianni wrote: Monday 09 September 2019 12:19 i think it's works now
And to answer your earlier question. Irl I am a retired IT guy who did a minor on programming in a previous life (around 1990). Only used that back then professional for a couple of months as a side job. So now only hobby. I am picking it up using Google and looking at domoticz sources and dzVents runtime modules.
