Page 1 of 3
Action LSC Smart Connect lights and sensors?
Posted: Sunday 08 September 2019 13:46
by FearNaBoinne
Does anyone have any Action LSC Smart Connect ("Powered by Tuya") light-bulbs (colorchanging, dimming and/or on/off options available), sensors, remotes or smart sirens connected to Domoticz?
I've tried searching, but "LSC" is too short and "Action" too generic...
Re: Action LSC Smart Connect lights and sensors?
Posted: Sunday 08 September 2019 15:39
by AllesVanZelf
Posted: Friday 13 September 2019 17:46
by FearNaBoinne
I just tried adding one of the smartplugs, and successfully retrieved ID and key, but am now getting:
Error: (Plug): Async Read Exception (192.168.164.169:6668): 104, Connection reset by peer
(The address is confirmed via tcpdump, the dhcp-leases and the wifi management, so that's not the issue, and the DevID from the tuyapi proxy matched the reported DevID in the app...)
I can switch it on/off using the app!
Interesting enough, an NMAP scan *does* show 6668 as open:
# nmap -Pn -sT 192.168.164.169 -p 1-9999
Starting Nmap 7.01 (
https://nmap.org ) at 2019-09-13 17:34 CEST
Nmap scan report for 192.168.164.169
Host is up (0.0031s latency).
Not shown: 9988 closed ports
PORT STATE SERVICE
23/tcp filtered telnet
53/tcp filtered domain
111/tcp filtered rpcbind
139/tcp filtered netbios-ssn
443/tcp filtered https
445/tcp filtered microsoft-ds
1025/tcp filtered NFS-or-IIS
1723/tcp filtered pptp
3306/tcp filtered mysql
6668/tcp open irc
8888/tcp filtered sun-answerbook
Nmap done: 1 IP address (1 host up) scanned in 58.06 seconds
Posted: Friday 13 September 2019 18:01
by AllesVanZelf
That what I found out
and that how I found the Tuya thread.
I have a light bulb. That one is not working yet. But the plug should work with the version in above thread.
Link
Have you tried the github plugin for the plug?
Posted: Friday 13 September 2019 20:18
by FearNaBoinne
That's the one I am using!
Posted: Friday 20 September 2019 10:00
by Wilco
Do you have a complete installation instruction for me? So i can use the LSC devices from the Action
Posted: Friday 20 September 2019 16:38
by FearNaBoinne
Well, as you can see, we never got them to work... I returned them!
Posted: Saturday 21 September 2019 9:39
by deennoo
LSC ude tuya 3.3 actual Tuya Plugin doesn't allow to choose which version to use
You have to update pytuya to 7.0.4 and force plugin to use tuya 3.3.
be join Tuya Plugin discution :
https://www.domoticz.com/forum/viewtopic.php?t=22528
Posted: Sunday 22 September 2019 22:05
by FearNaBoinne
Got it to work with 3.3...
Will continue in the other thread...
Posted: Saturday 26 October 2019 12:36
by Timdgr
FearNaBoinne wrote: Sunday 08 September 2019 13:46
Purchased two doorsensors and try to get IT to work with Domoticz
Is there a easy solution?
And how fast does the sensor trigger?
Posted: Sunday 19 January 2020 16:19
by martin82
flash the devices to tasmota and they all work with domoticz
i flasht the ledstrip and now the power plug.
and they working
Posted: Monday 20 January 2020 22:38
by FearNaBoinne
Is there an easy how to for flashing these to tasmota somewhere?
Posted: Thursday 23 January 2020 8:04
by FearNaBoinne
FearNaBoinne wrote: Monday 20 January 2020 22:38
Found Tuya-convert OTA flasher and successfully reflashed a smart plug to Tasmota... Works like a charm! Going to test with one of their filament bulbs next, and also have the RGBW lightsrips to test with...
Posted: Thursday 30 January 2020 21:59
by rolandbreedveld
Dit anybody get the proxy part for sniffing the id's working:
https://github.com/codetheweb/tuyapi/bl ... s/SETUP.md
all the steps went fine, but at step 6
the TuyaSmart app, gives a network unavailable error on my iphone
Posted: Friday 31 January 2020 1:04
by FearNaBoinne
Works fine for me every time...
The error does happen on the phone, that's ok though, as the proxy terminates once it has the IDs... The phone side isn't interesting, it's what the prxy output shows that is...
Posted: Friday 31 January 2020 1:05
by FearNaBoinne
BTW, I now have 2 (former) LSC RGB Strips, 1 (former) LSC filament bulb E17 and 1 (former) LSC plug converted to Tasmota...
Posted: Friday 31 January 2020 10:25
by Sammes
I have also this issue. The first 5 steps work, I can install and trust the certificate, but then I pull down in the app when connected to the proxy, I get an network error. The ID's and Keys won't show up eighter. Anyone who can help?
Posted: Friday 31 January 2020 11:24
by FearNaBoinne
Any errors shown at the proxy-app side?
What phone, os, etc.?
Any usedul Information you can think of to include, include it... None of us have magic crystal balls!
Posted: Friday 31 January 2020 16:31
by rolandbreedveld
FearNaBoinne wrote: Friday 31 January 2020 11:24
No errors at the proxy side,
I installed tuya-cli both on a Rapsberry Pi and a Linux pc
client running on an iPhone and an a android 5 phone
al the same issue
doing stacktracing of tuya-cli, I see more communication, with the android, but not the info we need
Posted: Friday 31 January 2020 16:50
by rolandbreedveld
FearNaBoinne wrote: Friday 31 January 2020 1:05
which plugin do you use to talk with tasmoto devices?
