user variables in blockly
Posted: Tuesday 03 September 2019 20:15
by jenicek
Hello.
I create in blockly control of boiler operation. When I enter data for switching times in numbers, everything is OK. When I use a variable, the system is not working properly. Example: switch on after 60 sec. works correctly.
but
turn on after entering the user variable in the integer format NO.
Other variables work (temperatures).
What am I doing wrong?
Thank you
J.
yet: user variables in blockly
Posted: Tuesday 03 September 2019 20:29
by jenicek
yet: it's about process timing, breaks, etc. When entered into fields in blockly data in numbers, everything is functional. If I replace the number field with a variable, the system behaves differently and badly. The logic in blockly is the same
Re: user variables in blockly
Posted: Saturday 14 September 2019 18:48
by DaanT
Hi jenicek,
A user variable does not trigger events when changed.
Maybe that's your problem, an event with just a user variable in the if statement will never run.
Daan
