Controling a blinder
Posted: Monday 02 September 2019 17:59
by Varazir
I'm trying to control a blinder
2019-09-02 17_57_14-Domoticz.png (23.4 KiB) Viewed 614 times
2019-09-02 14:00:02	Sun	West	2/20
2019-09-02 17:52:55	Molnighet	18.00	0/18.00
2019-09-02 06:13:01	DayNight	On	1/0
Nothing happens
Re: Controling a blinder
Posted: Wednesday 11 September 2019 15:32
by knielen
Looks like you used a switch called 'Sun', a switch can not have a value. Wat kind of device is 'Sun'?
Posted: Sunday 13 October 2019 12:02
by Varazir
knielen wrote: Wednesday 11 September 2019 15:32 Looks like you used a switch called 'Sun', a switch can not have a value. Wat kind of device is 'Sun'?
As the logs was showing a numeric value I tried that, this is the current one.
The devise is a dummy selector switch.
2019-10-13 11_58_56-Domoticz.png (24.42 KiB) Viewed 558 times
2019-10-13 12_00_59-Domoticz.png (12.19 KiB) Viewed 558 times
Posted: Monday 21 October 2019 14:48
by knielen
Not sure if this works.
But in this case you want to know if the sun in on the same side as your screen. Maybe you can try to make this time based? In your case after midday?
Posted: Wednesday 23 October 2019 22:50
by Varazir
knielen wrote: Monday 21 October 2019 14:48 Not sure if this works.
I have a timers on the Sun dummy switch as you can see. It changes the status based on the time
