How to add a new device to openzwave
Posted: Sunday 01 September 2019 19:23
by Gianni
hello
i have a new neo coolcam device.
It's working with domoticz but in cannot configure it.
its about this device
https://www.szneo.com/en/products/show.php?id=234
I have contact with neo and i want to try to get it in the openzwave DB
What information do in need to ask to build it myself?
I had a pull request on git but i have closed it because i dint think this was the right place to ask
now its see as
Shenzhen Neo Electronics Co Ltd Unknown: type=0200, id=102c
and in the openzwave cpl it's
31 LBR Routing Slave Motor Control Class B Shenzhen Neo Electronics Co Ltd Unknown: type=0200, id=102c
i need to configure it because when is set the endpoint with the hardware buttons it's out if sync when you close and open it again by 15 cm.
grts
Re: How to add a new device to openzwave
Posted: Monday 02 September 2019 8:01
by lost
Gianni wrote: Sunday 01 September 2019 19:23
I suppose you already checked OZW GIT for someone that could have already done the job after your OZW version was merged in Domoticz?
Usually, all parameters are described in the documentation provided with the device. To make a new XML in the OZW Config directory, there may be some directions on OZW wiki but you can also use some config file for other devices with same functions (or even, sometimes, a previous version that may be quite close). Don't forget to modify manufacturers file that make the link between manufacturer/device IDs and the config file you'll have written.
Another source of informations may be the z-wave alliance: All devices that have been certified have their config parameters described with the certification data.
Posted: Monday 02 September 2019 8:27
by Gianni
lost wrote: Monday 02 September 2019 8:01
nope did not.
i opened a pull request on git openzwave but i don't think this was the place to ask this.
So i closed it again.
How en who do i need to contact this is my first time i have a device that is not in the list because it's a new device from Neo.
it's not in the zwave alliance DB
https://products.z-wavealliance.org/Sea ... =on&order=
grts gianni
Posted: Tuesday 03 September 2019 10:31
by lost
Gianni wrote: Monday 02 September 2019 8:27
nope did not.
For Neo manufacturer ID, looks there is no 102c device ID at the moment even for current OZW:
https://github.com/OpenZWave/open-zwave ... ecific.xml
At line 1464 starts Neo devices and per device config file list.
This is where, in domoticz/Config, you'll have to add your device with device description xml file added in shenzen_neo directory. You can find a device that looks close to yours as an exemple. I have some PIRs from neo that were delivered with a short documentation with parameters and command set described.
If the device is not in the OZW alliance DB and no documentation, you'll not be able to do this job. If Neo or seller does not help, just return the device...
Looking at the conf file comments, we can see this manufacturer does not always follow strict procedures, for instance:
https://github.com/OpenZWave/open-zwave/issues/1866
2 different devices with same IDs = odd jobs to support them.
As well, some devices from this brand does not go for the certification process.
In the todo list before buying z-wave devices, presence in open-zwave alliance certification DB should be verified.
Posted: Sunday 15 September 2019 17:36
by xeonpj
the team has this documentation
https://drive.google.com/file/d/1kmMc8T ... sp=sharing
[HOW] according to the documentation attached:
I add the following line to "manufacturer_specific.xml"
<Product type="0200" id="102c" name="Z curtain switch" config="shenzen_neo/zctst.xml"/>
en el apartado
<Manufacturer id="0258" name="Shenzhen Neo Electronics Co Ltd">
NOTE: I have invented the name of the xml
I create the file "zctst.xml" and add it to the domoticz / config / shenzen_neo folder with the following content
<?xml version="1.0" encoding="utf-8"?>
<Product xmlns='
http://code.google.com/p/open-zwave/'>
<!-- Configuration Parameters -->
<CommandClass id="112">
<Value type="byte" genre="config" instance="1" index="1" label="UP/down SWAP" value="1" size="1">
<Help>Cambia el orden de los botones, si pulsas UP baja y viceversa</Help>
<Item label="Desactivado" value="0"/>
<Item label="Activado" value="1"/>
</Value>
<Value type="byte" genre="config" instance="1" index="2" label="Motor rotation SWAP" value="1" size="1">
<Help>Cambia la direccion de rotacion del motor</Help>
</Value>
<Value type="byte" genre="config" instance="1" index="3" label="Backlight Enable" value="1" size="1">
<Help>Activa o desactiva la luz del boton central</Help>
</Value>
<Value type="byte" genre="config" instance="1" index="4" label="Curtain Moving indicate Enable" value="1" size="1">
<Help>Activa o desactiva la luz indicando la direccion de la persiana.</Help>
</Value>
<Value type="byte" genre="config" instance="1" index="5" label="Button switch function disable" value="1" size="1">
<Help>Desactiva la botonera fisica si coloca este valor en "Desactivado"</Help>
</Value>
</CommandClass>
<!-- Association Groups -->
<CommandClass id="133">
<Associations num_groups="1">
<Group index="1" max_associations="5" label="Lifeline"/>
</Associations>
</CommandClass>
</Product>
Posted: Thursday 19 September 2019 8:26
by Gianni
hey
no it's stil not working for me.
The contact with the seller who is a member of coolcam did not respond anymore.
I will try you xml and see if i can fix it.
Posted: Thursday 19 September 2019 15:53
by xeonpj
With what I've happened to you it works, I don't know if all your options, but the basics work. I think they are missing adding some command class
Posted: Monday 06 January 2020 20:37
by pfwolbers
XML file was not working for me so I made a new one:
<Product xmlns='http://code.google.com/p/open-zwave/'>
<Value genre="config" instance="1" index="1" value="1" label="Up/Down Button Swap Enable" units="" size="1" min="0" max="1" type="list">
<Help>Up/Down Button Swap Enable</Help>
<Item value="0" label="Disabled"/>
<Item value="1" label="Enabled"/>
</Value>
<Value genre="config" instance="1" index="2" value="0" label="Motor Rotation Direction Swap Enable" units="" size="1" min="0" max="1" type="list">
<Help>Motor Rotation Direction Swap Enable</Help>
</Value>
<Value genre="config" instance="1" index="3" value="1" label="Backlight Enable" units="" size="1" min="0" max="1" type="list">
<Help>Backlight Enable</Help>
<Item value="0" label="LED Disabled"/>
<Item value="1" label="LED ON when Switch is ON"/>
</Value>
<Value genre="config" instance="1" index="4" value="1" label="Curtain Moving Indicate Enable" units="" size="1" min="0" max="1" type="list">
<Help>Curtain Moving Indicate Enable</Help>
<Item value="1" label="LED Enabled"/>
</Value>
<Value genre="config" instance="1" index="5" value="1" label="Button Switch" units="" size="1" min="0" max="1" type="list">
<Help>Button Switch</Help>
<Item value="0" label="Button Switch Disabled"/>
<Item value="1" label="Button Switch Enabled"/>
</Value>
</CommandClass>
<Group index="1" label="Lifeline" max_associations="5" auto="true"/>
</Associations>
</CommandClass>
</Product>
Posted: Monday 13 July 2020 13:56
by Regis68
Hi I've also this device (
https://www.szneo.com/en/products/show.php?id=234) .
But I have 2 disturbing problems with it :
First problem : when I use the multi level command for partial opening (Not 100% opened/closed) each time I reopen it is not opened completely. (If I close completely then reopen it's ok)
Second problem some of my devices lose their switch on switch off ability after some time (the blue led blinks).
I want to know if you guys also have faced this problems.
For the xml I have opened a pull request
https://github.com/OpenZWave/open-zwave/pull/2241: but I need to add the MetaData Block
But you can get the 2 files from here :
https://github.com/Arty68/open-zwave/ra ... ecific.xml and
https://github.com/Arty68/open-zwave/ra ... -cs01z.xml
Thanks for your answer
Posted: Wednesday 15 July 2020 18:06
by pfwolbers
If it's not connected to the server, after some time it starts blinking again. I had the same problem. As long as it is connected, I've no problems.
Also my screen is not completely open, tried to fix it many times. But cannot get it right.
Posted: Sunday 25 October 2020 16:10
by erich
Sorry for the stupid question but have you done anything special to make the switch work in manual mode right after the installation?
I have not even reached the zwave integration but the switch does not work when pushing up or down button.
No light, nothing...
I was just wondering if I need some app to activate the manual mode? Neo on their website and the package are talking about the APP but never mention which app.
I don't think I have wired it wrong. I removed the old switch and the 2 motor leads are clearly marked as well as the main L and N...
Eric
Posted: Monday 26 October 2020 20:22
by erich
Hi again, ok I made a mistake in the wiring and now it is ok
However as I have seen in this post, it is working in domoticz but I have no config information on my Aeon Z-Stick dongle.
I was wondering if I can load one of the xml file you've been talking about in order to get those config items (like switching off the blue led etc...)?
Posted: Monday 09 August 2021 16:33
by Pvhpsb
Hey,
Do you already have the Neo Coolcam Roller Shutter working in Domoticz?
Sincerely,
Patrick
