Idlock 101 error in log
tjabas
Post by tjabas »
Hi!
a couple of days ago i upgraded to Version: 1.6-808-gbb0a4bf7-dirty .
and that gave me an huge amount of problems, but everything seems to have worked out pretty good at the end, my only problem is an error in the log, and its from my Idlock 101 front door lock.
the door seems to work good , i can lock and unlock from domoticz, but this error message is hauting me, can i disable it somehow?
and what does it mean?
2019-09-01 13:37:36.583 Error: OpenZWave: Value_Changed: Tried adding value, not succeeded!. Node: 160 (0xa0), CommandClass: DOOR LOCK, Label: Locked (Advanced), Instance: 1, Index: 1
this error is made when i lock and unlock the door.
thanks!
tjabas
Re: Idlock 101 error in log
Post by tjabas »
anyone that has a solution of this problem?
tjabas
Post by tjabas »
anyone?
peerkersezuuker
Post by peerkersezuuker »
I have the same error with my Popp Strike Lock Controll, some googling learned that it already has been addressed :
https://github.com/domoticz/domoticz/issues/3360 and https://github.com/domoticz/domoticz/issues/3397
and not solved.
But it does not interfere with the function of the door lock.
regards
Peer
tjabas
Post by tjabas »
thank you for the answer, the first link i have already found but not the other one, so it seems like the issue is noticed then, thanks
