aqara wall switch selector switch
tjabas
Hi!
i have an Aqara zigbee wireless wall switch with 2 buttons, in domoticz it shows an an selector switch, in the device manager it shows as only one switch, my plan was to use this aqara switch to control 2 diferent lights but with only one selector switch in domoticz i really dont know how i can use it in blocky.
do you have any suggestions?
domogijs
Re: aqara wall switch selector switch
Aqara wall swich uses 4 states; off, switch 1, switch 2, BothClick
I dont use blocky but dzevents. the script looks something like this:
Hopes this helps
Greets Gijs (noob but trying to contribute to the community)
devices = {
'wallswitch'
if (switch.state == 'Switch 2') then
domoticz.devices('lamp').toggleSwitch()
}Greets Gijs (noob but trying to contribute to the community)
Raspberry Pi3, RFlink, PiZigate, Yeelight, klikaanklikuit, Kodi, harmony hub, Zwave, ThermoSmart, XiaomiGateway (Aqara), Google home hub, roomba,
tjabas
thanks, but i dont use script, i really dont know how to use it, im stuck with blocky, is it possible to do all in blocky?
gerbenvanasselt
- Domoticz version: Beta 4.1
Hi Tjabas,
This is an example of a blocky with using a selector switch. I hope this is what you are searching for.
Just place a variable in domosettings --> uservariables.
this is the xml to import it:
- blockly.JPG (73.75 KiB) Viewed 5320 times
tjabas
Thank you, that is exactly what im looking for
gerbenvanasselt
You're welcome, if I can save you the research time it is great.
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
tjabas
sorry but i didnt have any luck with this blocky, i made an user variable, like this: 6 toggle switch String [0,1,2] 2019-08-30 23:08:28
i dont know if its right.
but i cant seem to understand where i should ad the light buld that i want to turn on by this aqara switch. in blocky i mean
gerbenvanasselt
You have to replace the url part with the light name and add status on or of.
You can use json url to dim a bulb.
tjabas
i found this: http://127.0.0.1:8080/json.htm?type=com ... cmd=Toggle
works great , thank you all for the help
gerbenvanasselt
Yes indeed, did not know about the json toggle version. Thanks for sharing. But nowadays I start dzvents which has a toggling option in it.
joostvanwijk
Thanks for the xml! I was looking for a way to use the aqara switch as a dimmer. Is this the right blocky script to do this?gerbenvanasselt wrote: Friday 30 August 2019 22:10 This is an example of a blocky with using a selector switch. I hope this is what you are searching for.
Blocklyxml.txt
I don't get the togglecount though... where do you use this for? This is not a value in my domoticz? Do I need something to do first in order to get this?
Thanks in advance!
gerbenvanasselt
The toggle count is used for creating a circle which will take it off state when highest number is reached.
This way you can use one button to do more actions. Every toggle count number is another action with one button.
tjabas
can i use this switch to dim up or down a light?
gerbenvanasselt
I think you can do a cycle with dimming from minimal bright to bright in the number off steps you want and then ending with off.
Valiran
Sorry to dig this, but I'm facing an issue with my dual wallswitch Aqara model WXKG02LM.
I'm on rPi4 + ZigateDin.
When I add the switch, it's defined as a selector with switch 1, switch 2, BothClick. Off is hidden by default.
The problem I'm facing is that the switch stay un position.
So when I click on left (Switch 1), it stays on Left even if I release. That mean the blockly script given upper is rolling in infinte loop because the Switch value is always equal to the last button you push.
Do you know I can "park" the switch value when not pressing?
EDIT: physically, the switch is not broken, the blue light is off when I release and is blue when I press, so I believe it's only on domoticz side, or Zigate plugin side maybe?
- Domoticz version: 2026.3
In zigate there is a advanced setting about the off value related to Domoticz issue #4143. You can try to switch on the setting and restart plugin.
Valiran
Hello!
That still doesn't work, the selector stays on "Switch 1" for like 2-4 seconds, and during this time, the light blink because there are 2 actions on the button: on and off
Valiran
Nevermind...
A simple "http://IP_DOMO:PORT_DOMO/json.htm?type=command¶m=switchlight&idx=IDX_OF_LIGHT&switchcmd=Toggle" did the trick.
Now each of my switch on my 2 gangs Aqara work like and old fashioned dual light switch and that's exactly what I wanted
If light is off, a push put light on, and vice versa
