Zigate problem
tjabas
Zigate problem
Post by tjabas »
Hi!
I just received my zigate usb version, Im running the latest stable version of domoticz.
I have installed the zigate plugin and plugged the zigate device in my raspberry, but i cant seem to connect to the device itself, i get this error message:
2019-08-26 15:42:22.321 Error: (Zigate) - unplug/plug the zigate
2019-08-26 15:42:27.379 Error: (Zigate) Plugin is not started ...
2019-08-26 15:42:27.379 Error: (Zigate) - Communication issue with the Zigate
2019-08-26 15:42:27.379 Error: (Zigate) - restart once the plugin, and if this remain the same
I have tried all of the usb alternatives in the plugin but it wont connect, or do i need to flash the zigate with any firmware before i use it or should it work sout of the box?
I have also tried all of the usb ports in the back of my raspberry with no luck.
Thanks in advance.
pipiche
Re: Zigate problem
Post by pipiche »
]can you stop domoticz and do the following command:
dmesg | grep tty
Can you try the Zigate on a PC with Windows ?
https://zigate.fr/documentation/tester- ... -usb-v1-1/
tjabas
Re: Zigate problem
Post by tjabas »
Thanks, Im at work right now, but i will test this later tonight. Is it also possible to uppdates the zigate through this Windows software?
tjabas
Re: Zigate problem
Post by tjabas »
pipiche wrote: Monday 26 August 2019 16:00 ]can you stop domoticz and do the following command:
dmesg | grep tty
What will happend with that command?
dmesg | grep tty
tjabas
Re: Zigate problem
Post by tjabas »
hi!
i managed to get it to work, but it seems like the version of domoticz that i use: 4.10717 dont work, it seems to freeze some minutes after i have managed to pair an Ikea lightbulb, after that i cant start domoticz without it freezing in the starting fase.
im getting an error message in the log where it says that the webserver doesnt work with my domoticz version,
i have installed the latest beta version of domoticz and the zigate seems to work as it should, but the new problem is that i cant get the z-wave network to work ok, suddenly my z-wave battery modes have disappeard, so i guess that the beta version wont work for me, is there a fix so i can use the old stable domoticz version with Zigate?
pipiche
Re: Zigate problem
Post by pipiche »
If you have several USB devices connected, you must configure your OS to have always the same device name for each USB devices.
This is an OS Linux configuration. Have a look to udev feature
tjabas
Re: Zigate problem
Post by tjabas »
is there anyone who use zigate with the latest stable version of Domoticz ?
i get som error with that stable version, it says somethimg like a web error in the log.
pipiche
Re: Zigate problem
Post by pipiche »
tjabas wrote:is there anyone who use zigate with the latest stable version of Domoticz ?
Can you share the errors?
tjabas
Re: Zigate problem
Post by tjabas »
i get this error: Error:
(Zigate) ATTENTION: the WebServer part is not supported with this version of Domoticz. Please upgrade to a version greater than 4.10901
and then when i try to ad an zigbee device the whole domoticz freezes and need to be rebooted,
but there must be a way to use zigate with the stable version of domoticz?
tjabas
Re: Zigate problem
Post by tjabas »
well now i have another problem, i was trying to instal an older firmware just to see if i could eliminate the webserver problem, but after update the zigate flashes blue rapidly, and wont connect to domoticz, any sugestions of what could be wrong?
pipiche
Re: Zigate problem
Post by pipiche »
The webserver message is not an error. The plugin is just telling that the web part is not supported with such version of domoticz.
To get a full supported plugin web part, you need to put a beta version of domoticz.
pipiche
Re: Zigate problem
Post by pipiche »
tjabas wrote:well now i have another problem, i was trying to instal an older firmware just to see if i could eliminate the webserver problem, but after update the zigate flashes blue rapidly, and wont connect to domoticz, any sugestions of what could be wrong?
Please provide the logs , we cannot really help you without.
Just attach the log file ( we need the all context)
tjabas
Re: Zigate problem
Post by tjabas »
Thanks you for your help, ok so it is not the web error i get in the stable version of domoticz, it seems like when i have openzwave (aeotech gen5 stick) and the zigate plugin activated at the same time , then domotics freezes, if i turn of openzwave plugin everything seems to work fine with the zgate, but as soon as i start openzwave domoticz freezes.
here are some of the logs:
2019-08-29 11:42:15.009 Status: (Zigate) Entering work loop.
2019-08-29 11:42:15.010 Status: (Zigate) Initialized version 4.5, author 'zaraki673 pipiche38'
2019-08-29 11:42:15.019 Status: (Zigate) Zigate plugin stable-4.5.4 started
2019-08-29 11:42:15.020 Status: (Zigate) Python Version - 3.4.2 (default, Sep 26 2018, 07:50:08)
2019-08-29 11:42:15.020 [GCC 4.9.2]
2019-08-29 11:42:15.020 Status: (Zigate) Switching Heartbeat to 5 s interval
2019-08-29 11:42:15.020 Status: (Zigate) DomoticzVersion: 4.10717
2019-08-29 11:42:15.020 Status: (Zigate) DomoticzHash: b38b49e5
2019-08-29 11:42:15.020 Status: (Zigate) DomoticzBuildTime: 2019-05-09 13:04:08
2019-08-29 11:42:15.020 Status: (Zigate) load PluginConf
2019-08-29 11:42:15.022 Status: (Zigate) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2019-08-29 11:42:15.022 Status: (Zigate) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2019-08-29 11:42:15.022 Status: (Zigate) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2019-08-29 11:42:15.022 Status: (Zigate) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-14.json
2019-08-29 11:42:15.022 Status: (Zigate) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2019-08-29 11:42:15.022 Status: (Zigate) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2019-08-29 11:42:15.022 Status: (Zigate) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-08-29 11:42:15.022 Status: (Zigate) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-08-29 11:42:15.022 Status: (Zigate) Opening DomoticzDB in raw
2019-08-29 11:42:15.026 Status: (Zigate) Plugin Database: DeviceList-14.txt
2019-08-29 11:42:15.057 Status: (Zigate) DeviceConf loaded
2019-08-29 11:42:15.057 Status: (Zigate) load ListOfDevice
2019-08-29 11:42:15.068 Status: (Zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-14.txt : 0
2019-08-29 11:42:15.069 Status: (Zigate) Transport mode: USB
2019-08-29 11:42:15.069 Status: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0
2019-08-29 11:42:15.086 Status: (Zigate) Zigate set Time Server
2019-08-29 11:42:15.093 Status: (Zigate) Configure Permit To Join
2019-08-29 11:42:15.093 Status: (Zigate) Request Accepting new Hardware for 254 seconds
2019-08-29 11:42:15.093 Status: (Zigate) Trigger a Topology Scan
2019-08-29 11:42:15.093 Status: (Zigate) Trigger a Energy Level Scan
2019-08-29 11:42:15.093 Status: (Zigate) Network Energy Level Report: 0000
2019-08-29 11:42:15.093 Status: (Zigate) -----------------------------------------------
2019-08-29 11:42:15.095 Status: (Zigate) router <- nwkid Tx Failure 11 15 19 20 25 26
2019-08-29 11:42:15.173 Status: OpenZWave: Value_Added: Unhandled Label: Distance, Unit: m
2019-08-29 11:42:15.202 Status: (Zigate) Major Version Num: 0003
2019-08-29 11:42:15.202 Status: (Zigate) Installer Version Number: 030f
2019-08-29 11:42:15.509 Status: (Zigate) Accepting new Hardware: On
2019-08-29 11:42:15.612 Status: (Zigate) Zigate addresses ieee: 00158d0001edea3c , short addr: 0000
2019-08-29 11:42:15.612 Status: (Zigate) Network state UP, PANID: 168a extPANID: 0x42345bd5086b4cc9 Channel: 11
2019-08-29 11:42:15.716 Status: (Zigate) Number of devices recently active in Zigate = 0
2019-08-29 11:42:15.966 Status: RFXCOM: retrying in 30 seconds...
2019-08-29 11:42:17.209 Status: Incoming connection from: 192.168.1.57
2019-08-29 11:42:18.497 Status: OpenZWave: Received timeout notification from HomeID: 3946733487, NodeID: 20 (0x14)
2019-08-29 11:42:25.034 Status: (Zigate) Zigate set to Certification : CE
2019-08-29 11:42:25.035 Status: (Zigate) Start Web Server connection
2019-08-29 11:42:25.075 Status: (Zigate) Web backend for Web User Interface started on port: 9440
2019-08-29 11:42:25.075 Status: (Zigate) Plugin with Zigate firmware 030f correctly initialized
pipiche
Re: Zigate problem
Post by pipiche »
I don't see any issue here.
At start, the plugin is setting the Zigate in pairing mode for 254 seconds ( which means the Blue Led will flash during that time , indicating that pairing is possible).
What I see, is for now you don't have any device paired and known by plugin.
As you have Domoticz 4.10717, the plugin webserver is not reachable (you might use a ssh tunnel way to reach it); or upgrade domoticz to a version above 4.10901
Now, I don't know how Zigate behave when downgrading firmware
As I mentioned earlier in the post, as you have 2 or more USB devices connected to your system, you might be in trouble after a restart where the ZWave key is going to the Zigate port and vice-versa.
You need to make sure that after a reboot each of your USB stick stay on the same device-port ( /dev/tty.... ) that could be the reason of your freeze.
https://www.domoticz.com/wiki/Assign_fi ... o_USB_port
tjabas
Re: Zigate problem
Post by tjabas »
Yes, i will try that dev/tty in the weekend.
Strangely enough so everything works great in the latest domoticz beta, no freezes at all, but there is my other problem with the open z-wave. The devices are all fucked up, but ill dive into that to.
tjabas
Re: Zigate problem
Post by tjabas »
pipiche wrote: Thursday 29 August 2019 13:14 I don't see any issue here.
I have now assigned the usb ports but domoticz still freezes, but i was thinking if it might be the zigbee channel?, vit is now set to 11, but how can i change it to 12? Just to try?
pipiche
Re: Zigate problem
Post by pipiche »
To change the Zigbee channel you need to use the Web Admin interface on port 9440 and go to Settings.
For more info, please check teh Wiki:
https://github.com/pipiche38/Domoticz-Z ... terface.md
https://github.com/pipiche38/Domoticz-Z ... igation.md
tjabas
Re: Zigate problem
Post by tjabas »
Thanks 🙂
