switchSelector bug?
Posted: Saturday 24 August 2019 22:16
by darrepac
Trying to change a selector value through dzVents (beginner, was using directly LUA before), I read in the doc:
switchSelector(<[level]|[levelname]>): Function. Switches a selector switch to a specific level ( levelname or level(numeric) required ) levelname must be exact, for level the closest fit will be picked. See the edit page in Domoticz for such a switch to get a list of the values). Supports command options.
But either I am missunderstanding or it is not working as expected:
My selector has 4 values (Off is not activated):
Level 10: "20"
Level 20 : "30"
Level 30 : "45"
Level 40 : "50"
My understanding is that I have to give as parameter to switchSelector either a level (=integer) or levelname (= string) value.
so I used
switchSelector('20')
So I thought using levelName and so putting my selector to the level named "20" (which correspond to the level 10).
But the result was level named "30" which correspond to the level 20.
So even if I pass a string to switchSelector in order to use levelName, it has used the value (from string ?) as the level...
Sounds strange to me but I might missunderstand the doc.
Re: switchSelector bug?
Posted: Saturday 24 August 2019 22:23
by hoeby
I run the selectie switch in dzvents, without problems.
Is running on the last stable.
dz.devices('devicename').switchSelector(10)
Re: switchSelector bug?  [Solved]
Posted: Saturday 24 August 2019 22:43
by waaren
darrepac wrote: Saturday 24 August 2019 22:16 My understanding is that I have to give as parameter to switchSelector either a level (=integer) or levelname (= string) value.
so I used
Sounds strange to me but I might misunderstand the doc.
Using the levelname is only working correctly if you have not removed the 0 = "Off" level. Will update the wiki accoridingly.
Posted: Saturday 24 August 2019 22:50
by darrepac
waaren wrote: Saturday 24 August 2019 22:43
Ok! Here is the reason, thanks!
Posted: Sunday 25 August 2019 12:00
by darrepac
I kept the level 0 but I didn't name it "Off". Should I name it "Off" to make it works?
Posted: Sunday 25 August 2019 12:18
by waaren
darrepac wrote:I kept the level 0 but I didn't name it "Off". Should I name it "Off" to make it works?
Cannot check right now but do think that if it has a levelname (any name) it should work.
Posted: Sunday 25 August 2019 12:24
by darrepac
waaren wrote: Sunday 25 August 2019 12:18
I gave a try but it doesn't seem to work. I fall back to use "level" instead of "levelName" even if I find it less convenient.
Posted: Sunday 25 August 2019 12:42
by waaren
darrepac wrote: I gave a try but it doesn't seem to work. I fall back to use "level" instead of "levelName" even if I find it less convenient.
Can you please do a dump() of your device ?
Posted: Sunday 25 August 2019 13:33
by darrepac
2019-08-25 13:33:00.728 Status: dzVents: > LOG_MODULE_EXEC_INFO: 2
2019-08-25 13:33:00.728 Status: dzVents: > hsbToRGB()
2019-08-25 13:33:00.728 Status: dzVents: > DZVERSION: 2.4.19
2019-08-25 13:33:00.728 Status: dzVents: > osExecute()
2019-08-25 13:33:00.728 Status: dzVents: > fileExists()
2019-08-25 13:33:00.728 Status: dzVents: > log()
2019-08-25 13:33:00.728 Status: dzVents: > toJSON()
2019-08-25 13:33:00.728 Status: dzVents: > LOG_FORCE: 0.5
2019-08-25 13:33:00.728 Status: dzVents: > LOG_DEBUG: 4
2019-08-25 13:33:00.728 Status: dzVents: > hour: 12
2019-08-25 13:33:00.729 Status: dzVents: > isUTC: false
2019-08-25 13:33:00.729 Status: dzVents: > raw: 2019-08-25 12:23:00
2019-08-25 13:33:00.729 Status: dzVents: > day: 25
2019-08-25 13:33:00.729 Status: dzVents: > ruleIsBeforeCivilTwilightStart()
2019-08-25 13:33:00.729 Status: dzVents: > ruleIsAtCivilDayTime()
2019-08-25 13:33:00.729 Status: dzVents: > millisecondsAgo: 4200517
2019-08-25 13:33:00.729 Status: dzVents: > msAgo: 4200517
2019-08-25 13:33:00.729 Status: dzVents: > ruleIsAtCivilNight()
2019-08-25 13:33:00.729 Status: dzVents: > ruleIsAfterSunset()
2019-08-25 13:33:00.729 Status: dzVents: > ruleIsAfterCivilTwilightEnd()
2019-08-25 13:33:00.729 Status: dzVents: > rawTime: 12:23:00
2019-08-25 13:33:00.729 Status: dzVents: > ruleIsAfterSunrise()
2019-08-25 13:33:00.729 Status: dzVents: > wday: 1
2019-08-25 13:33:00.729 Status: dzVents: > isdst: true
2019-08-25 13:33:00.729 Status: dzVents: > ruleIsAtSunrise()
2019-08-25 13:33:00.729 Status: dzVents: > ruleIsBeforeSunset()
2019-08-25 13:33:00.729 Status: dzVents: > ruleIsAtNight()
2019-08-25 13:33:00.729 Status: dzVents: > ruleIsAfterCivilTwilightStart()
2019-08-25 13:33:00.729 Status: dzVents: > yday: 237
2019-08-25 13:33:00.730 Status: dzVents: > compare()
2019-08-25 13:33:00.730 Status: dzVents: > ruleIsAtCivilTwilightStart()
2019-08-25 13:33:00.730 Status: dzVents: > rawDate: 2019-08-25
2019-08-25 13:33:00.730 Status: dzVents: > dDate: 1566728580
2019-08-25 13:33:00.730 Status: dzVents: > ruleIsInWeek()
2019-08-25 13:33:00.730 Status: dzVents: > ruleIsBeforeCivilTwilightEnd()
2019-08-25 13:33:00.730 Status: dzVents: > getISO()
2019-08-25 13:33:00.730 Status: dzVents: > sec: 0
2019-08-25 13:33:00.730 Status: dzVents: > secondsSinceMidnight: 44580
2019-08-25 13:33:00.730 Status: dzVents: > dayAbbrOfWeek: sun
2019-08-25 13:33:00.730 Status: dzVents: > ruleIsOnDate()
2019-08-25 13:33:00.730 Status: dzVents: > week: 34
2019-08-25 13:33:00.730 Status: dzVents: > ruleIsOnDay()
2019-08-25 13:33:00.730 Status: dzVents: > ruleIsAtSunset()
2019-08-25 13:33:00.730 Status: dzVents: > min: 23
2019-08-25 13:33:00.731 Status: dzVents: > secondsAgo: 4200
2019-08-25 13:33:00.731 Status: dzVents: > isToday: true
2019-08-25 13:33:00.731 Status: dzVents: > minutesAgo: 70
2019-08-25 13:33:00.731 Status: dzVents: > milliseconds: 0
2019-08-25 13:33:00.731 Status: dzVents: > year: 2019
2019-08-25 13:33:00.731 Status: dzVents: > month: 8
2019-08-25 13:33:00.731 Status: dzVents: > unit: 1
2019-08-25 13:33:00.731 Status: dzVents: > hardwareType: Dummy (Does nothing, use for virtual switches only)
2019-08-25 13:33:00.731 Status: dzVents: > setState()
2019-08-25 13:33:00.731 Status: dzVents: > stop()
2019-08-25 13:33:00.731 Status: dzVents: > updateWetness()
2019-08-25 13:33:00.731 Status: dzVents: > disarm()
2019-08-25 13:33:00.731 Status: dzVents: > updateTempHum()
2019-08-25 13:33:00.731 Status: dzVents: > updateRain()
2019-08-25 13:33:00.731 Status: dzVents: > state: 45
2019-08-25 13:33:00.731 Status: dzVents: > isGroup: false
2019-08-25 13:33:00.731 Status: dzVents: > switchSelector()
2019-08-25 13:33:00.731 Status: dzVents: > updateSetPoint()
2019-08-25 13:33:00.731 Status: dzVents: > updateAlertSensor()
2019-08-25 13:33:00.731 Status: dzVents: > pause()
2019-08-25 13:33:00.732 Status: dzVents: > levelOffHidden: false
2019-08-25 13:33:00.732 Status: dzVents: > hardwareId: 8
2019-08-25 13:33:00.732 Status: dzVents: > name: Ballon ECS Bas
2019-08-25 13:33:00.732 Status: dzVents: > switchTypeValue: 18
2019-08-25 13:33:00.732 Status: dzVents: Info: ------ Finished Script #1
Posted: Sunday 25 August 2019 18:14
by waaren
darrepac wrote: Sunday 25 August 2019 12:24 I gave a try but it doesn't seem to work. I fall back to use "level" instead of "levelName" even if I find it less convenient.
You are on dzVents version 2.4.19. The use of levelName in switchSelector command is supported from dzVents 2.4.22 onwards. It was already in the (wiki) history but it seems that is was overwritten in the wiki in the description of the command itself. Re-added it now.
Posted: Sunday 25 August 2019 18:32
by darrepac
ok.. since 2 years I am no more playing with domoticz beta version and running on stable, so I would need to wait for the next stable version?
(Note: it works well with level for me and could interest others)
Posted: Sunday 25 August 2019 18:39
by waaren
darrepac wrote: Sunday 25 August 2019 18:32 ok.. since 2 years I am no more playing with domoticz beta version and running on stable, so I would need to wait for the next stable version?
Yes that is how the domoticz releases (including the integrated stuff like Open Zwave, dzVents and the likes) work. New features and bugfixes are not rolled into stable versions but will only make it to the next and future beta's and next and future stables
