help with time dependant front door monitor
Dave21w
Domoticz version: Stable
Post by Dave21w »
Can someone tell me why this doesn't work / what I have done wrong, the notification part I know is fine because if I remove the time contraints it triggers evertime without fail.
Dave
front door monitor.jpg (26.3 KiB) Viewed 1015 times
DaanT
Re: time dependant front door monitor
Post by DaanT »
Hi Dave,
I had the same problem when using sunrise and sunset.
Think of the following: when it is 22.00, the third time check will say it is later than 21.00, but the 4the time check will say it is not before 06.00. The last part will never work, it needs to be an or statement.
Kind regards,
Daan
Dave21w
Re: help with time dependant front door monitor
Post by Dave21w »
Ah I see, yes it makes sense now, so changing both the "and" statements to "or" will be OK ?
DaanT
Post by DaanT »
Hi Dave,
No only the last statement needs to be an OR.
The time needs to be before 6 OR after 21.
but also between 7 AND 17.
Daan
Dave21w
Post by Dave21w »
Now I get it, thank you very much.
Dave
