display transparancy block for garbage
Posted: Thursday 22 August 2019 12:43
by pvklink
Is it possible to change the block transparancy for only the garbage background block ?
see attachment, the text and the icon is hardly readible
Re: display transparancy block for garbage
Posted: Thursday 22 August 2019 14:27
by HansieNL
pvklink wrote: Thursday 22 August 2019 12:43 Is it possible to change the block transparancy for only the garbage background block ?
If you put this code in your custom.css you can change the background to the color/transparancy you like:
[data-id='garbage'] {
    background-color: rgba(0,0,0,0.5) !important;
You can change the red value from 0.1 till 1.0 to see what's best for you.
Posted: Thursday 22 August 2019 15:29
by pvklink
is it also possible to turn off the background block ?
so that the garbage displays as a sort of icom on the desk
Posted: Thursday 22 August 2019 15:46
by HansieNL
pvklink wrote: Thursday 22 August 2019 15:29 is it also possible to turn off the background block ?
Another one to try...
    opacity: 1.0 !important;
Posted: Thursday 22 August 2019 16:36
by pvklink
wat doet dat?
zie niet veranderen...
Heb overigens nog zo'n raar gevalletje dat de kleur vervaagd.
zie bijgevoegd image. Ik heb de blinds png zelf gemaakt en gekoppeld aan open en dicht. dat werkt goed.
vwb de kleuren heb ik de zelfde kleuren met een kleurenpicker gepkt van de iconen eronder..
en toch is het vele malen vager.....
is daar een verklaring voor en een oplossing?
Posted: Thursday 22 August 2019 17:25
by HansieNL
pvklink wrote: Thursday 22 August 2019 16:36 wat doet dat?
Do you have the effect in both statuses of the rolluik item?
Posted: Thursday 22 August 2019 17:50
by HansieNL
For the garbage block I think this is the one we need to completely remove the background...
    background: none !important
Hope this makes your text more readable.
Posted: Thursday 22 August 2019 17:52
by pvklink
no, when it is open it is sharp....closed is foggy
so it lookes that dashticz uses some kind of fog filter when the switch is off...
would be nice when you could put this on or off.
i want the bright color when my blind is closed....
Posted: Thursday 22 August 2019 18:43
by Lokonli
pvklink wrote: Thursday 22 August 2019 17:52 no, when it is open it is sharp....closed is foggy
Dashticz applies the following styling:
.off.icon {
	opacity:0.4 !important;
So indeed all off icons have limited opacity.
You can overrule this for all off icons by adding the following to your custom.css:
.off.icon {
	opacity:1 !important;
or, if you only want to change it for a block with device id 123:
.block_123 .off.icon {
Posted: Thursday 22 August 2019 19:43
by pvklink
wunderful!
Curious if this works with blinds,doors etc. open, closed
i am gonna play with this!
Thanks guys!
Lot off issues from my to-to-list solved!
Posted: Thursday 22 August 2019 20:26
by pvklink
it works for on / off devices
but not for open /close
see accu, there it works (is on off)
and blinds (rolluik) is open/close
Posted: Thursday 22 August 2019 21:17
by pvklink
you wont believe this..
i have two switches that are presented after each other.
I want them both with opacity 1.
But only 1 off them works. It concerns 1303 and 1423. When i change them first 1423 and then 1303 :
.block_1423 .off.icon {opacity:1 !important;}
.block_1303 .off.icon {opacity:1 !important;}
then the switch does work! so there must be a thing with tow together or something else...
// de grijze sluier bij off verwijderen
//.block_86 .off.icon {opacity:1 !important;}		does not work for a blind
//.block_86 .closed.icon {opacity:1 !important;}	does not work for a blind
.block_1163 .off.icon {opacity:1 !important;}
.block_354 .off.icon {opacity:1 !important;}
Posted: Thursday 22 August 2019 21:25
by pvklink
ok solved it!
both the blinds and the switch that did not work, do work now!
it had something to do with the part of my code that i disabled with: // signs
i removed that part and all works!
i now use /* .... */ for documenting code // is for the .js part... :oops: .
Posted: Thursday 22 August 2019 21:48
by HansieNL
pvklink wrote: Thursday 22 August 2019 21:25 ok solved it!
Javascript single line comments start with //
Javascript multi-line comments start with /* and end with */
CSS comments starts always with /* and always ends with */
Tip: if you have some spare time check https://www.w3schools.com
Posted: Thursday 22 August 2019 21:52
by pvklink
thanks for the advise !
gonna read (just to late for holiday)
for what about css, do i have to look at css or w3.css ?
Posted: Thursday 22 August 2019 22:07
by pvklink
the result:
Posted: Thursday 22 August 2019 22:18
by HansieNL
pvklink wrote: Thursday 22 August 2019 21:52 thanks for the advise !
Take a look at CSS. Have fun coding. Oh... and don't forget: your dashboard will never be finished. ;)
Posted: Thursday 22 August 2019 22:23
by pvklink
:lol: don't tell my wife!
And again, thanks (and lokonli) for the all the help!
