Ping script / Alive check
Posted: Wednesday 14 August 2019 21:37
I have trouble with system alive checker so i wrote a little shell script...
A script for alive system check that post json to Domoticz dummy switch. No need for edit crontab
Make some dummy switch in Domoticz
Edit the settings in the script
Save script file in /home/pi/domoticz/scripts
Give the script ritghs to execute (sudo chmod 777 filename) or (sudo chmod -R 777 dir name ) or (sudo chmod u+x filename)
Test the script in terminal
Make the script to run at startup: https://www.dexterindustries.com/howto/ ... t-startup/
#!/bin/bash
#-------------SETINGS----------------
# Devices:
# To add devices just copy/paste and edit the new lines
NAME[1]="1. Samsung A8" #Name of device
HOST[1]="192.168.1.124" #Ip
IDX[1]="56" #Domoticz IDX (dummy switch)
STATE[1]="0" #Allways 0 (dont edit!)
RETRY[1]=2 #Cycles to fail before sending json off to domoticz
NAME[2]="2. ESP8266 / Sunheat"
HOST[2]="192.168.1.202"
IDX[2]="57"
STATE[2]="0" #Allways 0
RETRY[2]=2
NAME[3]="3. Chromecast / TV"
HOST[3]="192.168.1.125"
IDX[3]="58"
STATE[3]="0" #Allways 0
RETRY[3]=2
NAME[4]="4. 433 Mhz Gateway"
HOST[4]="192.168.1.200"
IDX[4]="59"
STATE[4]="0" #Allways 0
RETRY[4]=2
NAME[5]="5. Current Meter"
HOST[5]="192.168.1.201"
IDX[5]="60"
STATE[5]="0" #Allways 0
RETRY[5]=2
NAME[6]="6. Floor Heating"
HOST[6]="192.168.1.203"
IDX[6]="61"
STATE[6]="0" #Allways 0
RETRY[6]=2
# Script settings:
# Domotics Host IP/Port
DOMOTICZ="192.168.1.131"
PORT="8080"
# No of devices to check:
DEVICES="6"
#Packets to send
COUNT=1
#Cycle time between runs in sec
TIMER=60
#Loging to file on/off (1 = on)
LOGING=0
#Setting up the devices, retrys, settings and showing host info. (dont edit below)
RETRYz=0
i="1"
echo ""
printf '\e[1m'
if [ "${LOGING}" = "1" ]; then
echo "Loging to file = on"
fi
echo ""
echo ""
echo "Devices to ping:"
while [ "$i" -le "$DEVICES" ]; do
let "RETRYz[$i] = RETRY[$i]" #setting up devices retrys
#echo ${RETRYz[i]} #$RETRY[$i] #debugging...
echo ""
#echo "$i".""
echo ${NAME[$i]}
echo ${HOST[i]}
i=$(( $i + 1 ))
done
echo ""
echo "Press ctrl+c to exit"
printf '\e[0m'
x="0" # run once / # when script run once it increment to 1
while true; do
i="1"
#-le
echo ""
printf '\e[32m'
echo "Pinging Devices..."
echo ""
printf '\e[0m'
sleep 0.5
#if [ $x = "0" ]; then
#RETRY[$i]=RETRYz
#fi
for myHost in ${HOST[i]}
do
count=$(ping -c $COUNT $myHost | grep 'received' | awk -F',' '{ print $2 }' | awk '{ print $1 }')
if [ $count -eq 0 ]; then
# 100% failed
#echo "$i".""
printf '\e[1m'
echo ${NAME[$i]}
printf '\e[0m'
printf '\e[31m'
echo "Host : $myHost is down (ping failed) at $(date)" >> panglog.log
fi
printf '\e[0m'
if [ "${STATE[i]}" = "1" ] || [ $x = "0" ] # if [ "${STATE[i]}" = "1" ] || [ $x = "0" ]
then
if [ $x = "1" ]; then #shuld be 1
#echo ${RETRYz[i]}
(( RETRYz[i]-- ))
#echo ${RETRYz[i]}
fi
if [ "${RETRYz[$i]}" = "0" ] || [ $x = "0" ]
then
printf '\e[32m'
echo "Sending JSON Off"
printf '\e[0m'
curl http://$DOMOTICZ:$PORT/json.htm?"type=command¶m=switchlight&idx=${IDX[i]}&switchcmd=Off"
STATE[$i]=0
fi
echo "--------------------------------------------------------------"
echo ""
fi
#echo "$i".""
printf '\e[1m'
echo ${NAME[$i]}
printf '\e[0m'
echo "Host : $myHost Sucess! at $(date)" >> panglog.log
fi
if [ "${STATE[i]}" = "0" ] || [ $x = "0" ]
then
printf '\e[32m'
echo "Sending JSON On"
printf '\e[0m'
curl http://$DOMOTICZ:$PORT/json.htm?"type=command¶m=switchlight&idx=${IDX[i]}&switchcmd=On"
STATE[$i]=1
#RETRY[$i]=RETRYz
echo ""
fi
fi
i=$(( $i + 1 ))
# echo "$i"
done
done
x="1" # first cycle done
#-------------------------------------------------------- Remove this if you want to use cronetab to run the script!
printf '\e[31m'
#printf '\e[1m'
echo ""
echo " Sleep for $TIMER""s"
echo ""
#echo "| |"
printf '|'
(( $TIMER - 2 ))
#Sript indicator..
y=0
#intf '\e[41m'
while [ "$y" -le "$TIMER" ] ; do
printf ' '
y=$(( $y + 1 ))
done
printf '|'
(( $TIMER + 2 ))
echo ""
printf ' '
#Sript indicator..
y=0
#intf '\e[41m'
printf '#'
y=$(( $y + 1 ))
sleep 1
done
printf '\e[0m'
#----------------------------------------------------------------------------- End remove!
done # Save this!
